Wireless Info Script
The easiest and most complete method of gathering information to help diagnose wireless issues is to run the wireless info script we created at the Ubuntu Forums to collect all the most common information needed while masking all sensitive data.
Open a terminal with Ctrl+Alt+T and run these commands:
wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info &&
chmod +x wireless-info &&
./wireless-info
This will create the file "wireless-info.txt" at the location it is run from, and depending on its size, an additional archive called "wireless-info.tar.gz". Sensitive information like MAC addresses and WPA/WEP keys are masked automatically.
If you cannot connect to the internet with the affected system, including via a wired connection, you will have to move files between it and a system connected to the internet. A USB stick would likely be the easiest method for this.
Post the results on paste.ubuntu.com or pastebin.com, and link to it here in your question.
Further details on the script: GitHub page.
Here is an example of the information that the script will collect:
########## wireless info START ##########
Report from: 02 May 2015 23:04 CDT -0500
Booted last: 01 May 2015 00:44 CDT -0500
Script from: 30 Apr 2015 17:23 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 14.04.2 LTS
Release: 14.04
Codename: trusty
##### kernel ############################
Linux 3.13.0-49-generic #81-Ubuntu SMP Tue Mar 24 19:29:48 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
GNOME Flashback (Compiz)
##### lspci #############################
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM57785 Gigabit Ethernet PCIe [14e4:16b5] (rev 10)
Subsystem: Acer Incorporated [ALI] Device [1025:0647]
Kernel driver in use: tg3
03:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
Subsystem: Lite-On Communications Inc Device [11ad:6617]
Kernel driver in use: ath9k
##### lsusb #############################
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 1bcf:2c18 Sunplus Innovation Technology Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
##### PCMCIA card info ##################
##### rfkill ############################
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
##### lsmod #############################
acer_wmi 32522 0
sparse_keymap 13948 1 acer_wmi
ath9k 164164 0
ath9k_common 13551 1 ath9k
ath9k_hw 453856 2 ath9k_common,ath9k
ath 28698 3 ath9k_common,ath9k,ath9k_hw
mac80211 630669 1 ath9k
cfg80211 484040 3 ath,ath9k,mac80211
wmi 19177 1 acer_wmi
video 19476 2 i915,acer_wmi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0 Link encap:Ethernet HWaddr
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:16
wlan0 Link encap:Ethernet HWaddr
inet addr:192.168.43.63 Bcast:192.168.43.255 Mask:255.255.255.0
inet6 addr: 2600:100c:b004:3fa3:2216:d8ff:fe89:5871/64 Scope:Global
inet6 addr: fe80::2216:d8ff:fe89:5871/64 Scope:Link
inet6 addr: 2600:100c:b004:3fa3:9db3:d3ca:cda7:6666/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:227572 errors:0 dropped:0 overruns:0 frame:0
TX packets:200363 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:162556355 (162.5 MB) TX bytes:31143668 (31.1 MB)
##### iwconfig ##########################
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:"scubby"
Mode:Managed Frequency:2.437 GHz Access Point:
Bit Rate=12 Mb/s Tx-Power=16 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-33 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:150 Missed beacon:0
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.43.1 0.0.0.0 UG 0 0 0 wlan0
192.168.43.0 0.0.0.0 255.255.255.0 U 9 0 0 wlan0
##### resolv.conf #######################
nameserver 127.0.1.1
#ubuntuforums-mods
##### NetworkManager info ###############
NetworkManager Tool
State: connected (global)
- Device: wlan0 [scubby] -------------------------------------------------------
Type: 802.11 WiFi
Driver: ath9k
State: connected
Default: yes
HW Address:
Capabilities:
Speed: 54 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points (* = current AP)
ATT9156: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 37 WPA2
taarakian: Infra, , Freq 2417 MHz, Rate 54 Mb/s, Strength 29 WPA2
NETGEAR: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 19 WPA WPA2
suddenlink.net-1140: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 7 WPA2
RSS-351540: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 12 WPA2
suddenlink.net-9572: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 12 WPA WPA2
SJI: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 20 WPA2
NETGEAR70: Infra, , Freq 2447 MHz, Rate 54 Mb/s, Strength 5 WPA2
SUDDENLINK.NET-6E3D: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 39 WEP
*scubby: Infra, , Freq 2437 MHz, Rate 54 Mb/s, Strength 85 WPA2
SJI Guest: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 12
ATT677: Infra, , Freq 2452 MHz, Rate 54 Mb/s, Strength 24 WPA WPA2
IPv4 Settings:
Address: 192.168.43.63
Prefix: 24 (255.255.255.0)
Gateway: 192.168.43.1
DNS: 192.168.43.1
- Device: eth0 -----------------------------------------------------------------
Type: Wired
Driver: tg3
State: unavailable
Default: no
HW Address:
Capabilities:
Carrier Detect: yes
Wired Properties
Carrier: off
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/DIRECT-roku-067-072A4B]] (600 root)
[connection] id=DIRECT-roku-067-072A4B | type=802-11-wireless
[802-11-wireless] ssid=DIRECT-roku-067-072A4B | mac-address=
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: America/Chicago (based on set time zone)
country 00:
(2402 - 2472 @ 40), (3, 20)
(2457 - 2482 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(2474 - 2494 @ 20), (3, 20), NO-OFDM, PASSIVE-SCAN, NO-IBSS
(5170 - 5250 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(5735 - 5835 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
##### iwlist channels ###################
eth0 no frequency information.
lo no frequency information.
wlan0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Current Frequency:2.437 GHz (Channel 6)
##### iwlist scan #######################
Channel occupancy:
2 APs on Frequency:2.412 GHz (Channel 1)
1 APs on Frequency:2.417 GHz (Channel 2)
1 APs on Frequency:2.437 GHz (Channel 6)
2 APs on Frequency:2.462 GHz (Channel 11)
eth0 Interface doesn't support scanning.
lo Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address:
Channel:6
Quality=30/70 Signal level=-80 dBm
Encryption key:on
ESSID:"Larry"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=0000000028511003
Extra: Last beacon: 20ms ago
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
Cell 02 - Address:
Channel:1
Quality=29/70 Signal level=-81 dBm
Encryption key:on
ESSID:"ATT9156"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=00000371b6618537
Group Cipher : CCMP
Cell 03 - Address:
Channel:1
Quality=28/70 Signal level=-82 dBm
Encryption key:off
ESSID:"SJI Guest"
Mode:Master
Extra:tsf=000000149eca5197
Extra: Last beacon: 2304ms ago
Cell 04 - Address:
Channel:2
Quality=20/70 Signal level=-90 dBm
Encryption key:on
ESSID:"taarakian"
Mode:Master
Extra:tsf=00000268fbeb2d80
Extra: Last beacon: 1996ms ago
Group Cipher : CCMP
Cell 05 - Address:
Channel:11
Quality=37/70 Signal level=-73 dBm
Encryption key:on
ESSID:"SUDDENLINK.NET-6E3D"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
18 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=000001765a3e4af3
Cell 06 - Address:
Channel:11
Quality=23/70 Signal level=-87 dBm
Encryption key:on
ESSID:"NETGEAR"
Mode:Master
Extra:tsf=00000092d136ec9e
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
IE: WPA Version 1
Group Cipher : TKIP
##### module infos ######################
[ath9k]
filename: /lib/modules/3.13.0-49-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license: Dual BSD/GPL
description: Support for Atheros 802.11n wireless LAN cards.
author: Atheros Communications
srcversion: 274594FBD61F5DF88102A4C
depends: ath9k_hw,mac80211,ath9k_common,cfg80211,ath
intree: Y
vermagic: 3.13.0-49-generic SMP mod_unload modversions
signer: Magrathea: Glacier signing key
sig_key: A2:F2:B9:84:B0:F0:3D:B6:0B:A1:EA:08:10:49:37:4C:1A:C3:D9:02
sig_hashalgo: sha512
parm: debug:Debugging mask (uint)
parm: nohwcrypt:Disable hardware encryption (int)
parm: blink:Enable LED blink on activity (int)
parm: btcoex_enable:Enable wifi-BT coexistence (int)
parm: bt_ant_diversity:Enable WLAN/BT RX antenna diversity (int)
parm: ps_enable:Enable WLAN PowerSave (int)
[ath9k_common]
filename: /lib/modules/3.13.0-49-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
description: Shared library for Atheros wireless 802.11n LAN cards.
srcversion: 93644B269B570BC55CF5154
depends: ath,ath9k_hw
intree: Y
[ath9k_hw]
filename: /lib/modules/3.13.0-49-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
srcversion: 65C14EF588BF1A68181643C
depends: ath
intree: Y
[ath]
filename: /lib/modules/3.13.0-49-generic/kernel/drivers/net/wireless/ath/ath.ko
description: Shared library for Atheros wireless LAN cards.
srcversion: 88A67C5359B02C5A710AFCF
depends: cfg80211
intree: Y
[mac80211]
filename: /lib/modules/3.13.0-49-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: 29A87AE7782ED3657631C32
depends: cfg80211
intree: Y
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename: /lib/modules/3.13.0-49-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: 176113E009F723E69BE9BAB
depends:
intree: Y
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[ath9k]
blink: 0
bt_ant_diversity: 0
btcoex_enable: 0
nohwcrypt: 0
ps_enable: 0
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
probe_wait_ms: 500
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
exit 0
##### pm-utils ##########################
[/etc/pm/power.d/disable_wol] (777 root)
CONFFILE=/etc/default/tlp
LIBDIRS='/usr/lib /usr/lib64'
for d in ${LIBDIRS}; do
if [ -d "${d}/pm-utils/power.d" ]; then
blocked="${d}/pm-utils/power.d/${0##*/}"
break
fi
done
if [ -n "$blocked" ] && [ -x "$blocked" ]; then
# else nothing to disable -> don't read $CONFFILE
if [ -e "$CONFFILE" ] && . "$CONFFILE" && [ "$TLP_ENABLE" = '1' ]; then
# TLP is enabled -> disable $blocked
echo "Notice: '${blocked}' disabled by TLP."
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/laptop-mode] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/pci_devices] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/pcie_aspm] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/sched-powersave] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/usb_bluetooth] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/wireless] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
[/etc/pm/power.d/xfs_buffer] (777 root)
break
fi
done
else
exec "$blocked" $*
fi
fi
exit 0
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x14e4:0x16b5 (tg3)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x168c:0x0032 (ath9k)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
# USB device 0x:0x (rndis_host)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth1"
##### dmesg #############################
[53764.123272] wlan0: deauthenticating from by local choice (reason=3)
[53766.341705] ath: phy0: ASPM enabled: 0x43
[53769.663996] ath9k 0000:03:00.0: no hotplug settings from platform
[53770.839058] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[53772.588289] wlan0: authenticate with
[53772.612650] wlan0: send auth to (try 1/3)
[53772.614687] wlan0: authenticated
[53772.614954] wlan0: AP has invalid WMM params (AIFSN=1 for ACI 2), disabling WMM
[53772.615474] wlan0: associate with (try 1/3)
[53772.618314] wlan0: RX AssocResp from (capab=0x411 status=0 aid=1)
[53772.618513] wlan0: associated
[53772.618541] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[53772.771949] wlan0: deauthenticating from by local choice (reason=2)
[53772.783893] wlan0: authenticate with
[53772.801865] wlan0: send auth to (try 1/3)
[53772.803896] wlan0: authenticated
[53772.804020] wlan0: AP has invalid WMM params (AIFSN=1 for ACI 2), disabling WMM
[53772.807642] wlan0: associate with (try 1/3)
[53772.810355] wlan0: RX AssocResp from (capab=0x411 status=0 aid=1)
[53772.810561] wlan0: associated
########## wireless info END ############
