I know there is a lot of threads about this, but I followed a great number of them and none worked.
I installed ubuntu 20.04 on a live usb using rufus for a mackbook pro late 2013. After a while, I noticed the driver is there by default, but : it only works once. Here is how I made it work once : I made the install by clicking the icon on the desktop up to the part where it asks where to make the install -> wifi worked until reboot. An other way was to go on the additional driver panel, disable it, reboot, enable it -> wifi worked until reboot.
I dont know why it is there and doesnt work...
I also tried the b43 firmware installer, following other threads, but nothing worked.
Suggested commands in ubuntu 20.04.3 lts:
lsmod | grep -e b43 -e wl
wl 6455296 0
cfg80211 888832 1 wl
And
grep -e b43 -e wl /etc/modprobe.d/*
/etc/modprobe.d/blacklist-bcm43.conf:# Warning: This file is autogenerated by bcmwl. All changes to this file will be lost.
/etc/modprobe.d/blacklist-bcm43.conf:blacklist b43
/etc/modprobe.d/blacklist-bcm43.conf:blacklist b43legacy
/etc/modprobe.d/blacklist.conf:# replaced by b43 and ssb.
/etc/modprobe.d/iwlwifi.conf:# /etc/modprobe.d/iwlwifi.conf
/etc/modprobe.d/iwlwifi.conf:# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
/etc/modprobe.d/iwlwifi.conf:# microcode file installed on the system. When removing iwlwifi, first
/etc/modprobe.d/iwlwifi.conf:# remove the iwl?vm module and then iwlwifi.
/etc/modprobe.d/iwlwifi.conf:remove iwlwifi \
/etc/modprobe.d/iwlwifi.conf:(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
And
sudo dmesg | grep wl
[ 59.790911] wl: loading out-of-tree module taints kernel.
[ 59.790920] wl: module license 'MIXED/Proprietary' taints kernel.
[ 59.793410] wl: module verification failed: signature and/or required key missing - tainting kernel
And
sudo dmesg | grep -e wl -e bcma
[ 1.141227] bcma-pci-bridge 0000:03:00.0: bus0: Found chip with id 0x4360, rev 0x03 and package 0x00
[ 1.141271] bcma-pci-bridge 0000:03:00.0: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
[ 1.141296] bcma-pci-bridge 0000:03:00.0: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
[ 1.141342] bcma-pci-bridge 0000:03:00.0: bus0: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
[ 1.141392] bcma-pci-bridge 0000:03:00.0: bus0: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
[ 1.141417] bcma-pci-bridge 0000:03:00.0: bus0: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
[ 1.196936] bcma: Unsupported SPROM revision: 11
[ 1.197064] bcma-pci-bridge 0000:03:00.0: bus0: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
[ 1.197070] bcma-pci-bridge 0000:03:00.0: bus0: Using fallback SPROM failed (err -2)
[ 1.197075] bcma-pci-bridge 0000:03:00.0: bus0: No SPROM available
[ 1.200300] bcma-pci-bridge 0000:03:00.0: bus0: Bus registered
[ 45.291300] wl: loading out-of-tree module taints kernel.
[ 45.291307] wl: module license 'MIXED/Proprietary' taints kernel.
[ 45.293675] wl: module verification failed: signature and/or required key missing - tainting kernel
And
journalctl -b | grep bcma
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Found chip with id 0x4360, rev 0x03 and package 0x00
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
déc 19 19:11:03 ubuntu kernel: bcma: Unsupported SPROM revision: 11
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Using fallback SPROM failed (err -2)
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: No SPROM available
déc 19 19:11:03 ubuntu kernel: bcma-pci-bridge 0000:03:00.0: bus0: Bus registered
Debug script log : https://pastebin.ubuntu.com/p/ZhR4QRSpDp/
Commands done in 21.10 :
The driver was at first not enabled in the additional drivers window. I enabled it, worked fine until reboot. Then, I tried remove bcma, just in case, but nothing changed.
sudo dmesg | grep bcma
[ 1.496684] bcma-pci-bridge 0000:03:00.0: bus0: Found chip with id 0x4360, rev 0x03 and package 0x00
[ 1.496731] bcma-pci-bridge 0000:03:00.0: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
[ 1.496757] bcma-pci-bridge 0000:03:00.0: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
[ 1.496802] bcma-pci-bridge 0000:03:00.0: bus0: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
[ 1.496851] bcma-pci-bridge 0000:03:00.0: bus0: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
[ 1.496876] bcma-pci-bridge 0000:03:00.0: bus0: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
[ 1.555428] bcma: Unsupported SPROM revision: 11
[ 1.555512] bcma-pci-bridge 0000:03:00.0: bus0: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
[ 1.555515] bcma-pci-bridge 0000:03:00.0: bus0: Using fallback SPROM failed (err -2)
[ 1.555518] bcma-pci-bridge 0000:03:00.0: bus0: No SPROM available
[ 1.559096] bcma-pci-bridge 0000:03:00.0: bus0: Bus registered
