I recently installed a Ubuntu Server from live ISO. During installation I configured a Wi-Fi network. However now, post-installation I am unable to use network manager (nmcli/nmtui) at all as it does not list Wi-Fi connections and my Wi-Fi interface shows as unavailable. My Wi-Fi works just fine and I am also able to scan for Wi-Fi networks just fine with:
sudo iwlist wlp108s0 scanning
Any ideas?
Attaching relevant snippet from the following network debugging script:
##### network managers ##################
Installed:
NetworkManager
Running:
root 1129 1 0 22:09 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: wlp108s0
GENERAL.TYPE: wifi
GENERAL.NM-TYPE: NMDeviceWifi
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2
GENERAL.VENDOR: Intel Corporation
GENERAL.PRODUCT: Wireless 8265 / 8275
GENERAL.DRIVER: iwlwifi
GENERAL.DRIVER-VERSION: 5.15.0-92-generic
GENERAL.FIRMWARE-VERSION: 36.ca7b901d.0 8265-36.ucode
GENERAL.HWADDR: <MAC 'wlp108s0' [IF1]>
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
GENERAL.REASON: 41 (The device's existing connection was assumed)
GENERAL.IP4-CONNECTIVITY: 1 (none)
GENERAL.IP6-CONNECTIVITY: 1 (none)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.4/0000:6c:00.0/net/wlp108s0
GENERAL.PATH: pci-0000:6c:00.0
GENERAL.IP-IFACE: --
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
CAPABILITIES.SPEED: unknown
CAPABILITIES.IS-SOFTWARE: no
CAPABILITIES.SRIOV: no
INTERFACE-FLAGS.UP: yes
INTERFACE-FLAGS.LOWER-UP: yes
INTERFACE-FLAGS.CARRIER: yes
INTERFACE-FLAGS.PROMISC: no
WIFI-PROPERTIES.WEP: yes
WIFI-PROPERTIES.WPA: yes
WIFI-PROPERTIES.WPA2: yes
WIFI-PROPERTIES.TKIP: yes
WIFI-PROPERTIES.CCMP: yes
WIFI-PROPERTIES.AP: yes
WIFI-PROPERTIES.ADHOC: yes
WIFI-PROPERTIES.2GHZ: yes
WIFI-PROPERTIES.5GHZ: yes
WIFI-PROPERTIES.MESH: no
WIFI-PROPERTIES.IBSS-RSN: yes
IP4.ADDRESS[1]: 192.168.1.14/24
IP4.GATEWAY: 192.168.1.1
IP4.ROUTE[1]: dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 600
IP4.ROUTE[2]: dst = 192.168.1.1/32, nh = 0.0.0.0, mt = 600
IP4.ROUTE[3]: dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 600
IP6.ADDRESS[1]: fe80::<IP6 'wlp108s0' [IF1]>/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: --
SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY ACTIVE IN-USE
NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-31-mac-addr-change]
match-device=driver:eagle_sdio,driver:wl
NetworkManager profiles (empty)
