I have a 15-d051su Hp laptop, I just installed ubuntu 14.04 LTC and I am new to Linux. Everything is fine except the wifi. When I am using too much internet(downloading) after a couple of minutes my wifi connection crashes and the only way I can again get connected is to disable manualy wifi and enable it again and the process repeats after a couple of minutes.
I noticed that the more internet I use, the faster my connection crashes, also I found that if I download with a speed lower than the 100KB/s, my connection does not crash. Also if my connection does not crash at all if I have a wired connection.
The wifi works perfectly on windows
Wifi hardware info is:
       *-network
            description: Wireless interface
            product: RT3290 Wireless 802.11n 1T/1R PCIe
            vendor: Ralink corp.
            physical id: 0
            bus info: pci@0000:03:00.0
            logical name: wlan0
            version: 00
            serial: 9c:d2:1e:d2:e2:d3
            width: 32 bits
            clock: 33MHz
            capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
            configuration: broadcast=yes driver=rt2800pci driverversion=3.19.0-42-generic firmware=0.37 latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
            resources: irq:19 memory:90510000-9051ffff
Wireless info script output
Elder Geek
  • 36,752
murloc
  • 63
A number of Linux drivers seem to be sensitive to the access point to which they attach. First, check the settings in the router. WPA2-AES is preferred; not any WPA and WPA2 mixed mode and certainly not TKIP. Second, if your router is capable of N speeds, you may have better connectivity with a channel width of 20 MHz in the 2.4 GHz band instead of automatic 20/40 MHz, although it is likely to affect N speeds. I also have better luck with a fixed channel, either 1, 6 or 11, rather than automatic channel selection. Also, be certain the router is not set to use N speeds only; auto B, G and N is preferred. After making these changes, reboot the router.
Next, I'd set IPv6 to Ignore in Network Manager: http://docs.fedoraproject.org/en-US/Fedora/18/html/Installation_Guide/images/netconfig/network-connections-ipv6-ignore.png This example is for ethernet, but you want wireless.
If these changes do not help, please try:
sudo modprobe -r rt2800pci
sudo modprobe rt2800pci nohwcrypt=Y
If it helps, make it permanent:
sudo -i
echo "options rt2800pci nohwcrypt=Y"  >  /etc/modprobe.d/rt2800pci.conf
exit
Finally, Network Manager will default to ethernet if it's available. Please make your tests with the ethernet detached.
chili555
  • 61,330
