All of a sudden, this morning I don't have wifi on my laptop. I have a Thinkpad E14.
I don't know what caused this. The wifi is working, I can turn it on and off, but it searches for available networks and it doesn't find any. I turned the wifi off and on,sudo nmcli networking off && sudo nmcli networking on and sudo service network-manager - didn't work.
Kernel: 5.13.0-39-generic
When i go to Software and Updates > Additional Software I get "no additional drivers available".
I also updated and upgraded, rebooted but still the same problem.
lspci gives 03:00.0 Network controller: MEDIATEK Corp. Device 7961
More info:
$ lshw -C network
WARNING: you should run this program as super-user.
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 10
       serial: 88:a4:c2:b2:ce:85
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.13.0-39-generic duplex=full firmware=rtl8168g-3_0.0.1 04/23/13 ip=192.168.1.186 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:39 ioport:2000(size=256) memory:fd404000-fd404fff memory:fd400000-fd403fff
  *-network
       description: Wireless interface
       product: MEDIATEK Corp.
       vendor: MEDIATEK Corp.
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 00
       serial: 10:6f:d9:df:16:3d
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=mt7921e driverversion=5.13.0-39-generic firmware=____010000-20220209150915 latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: iomemory:60-5f iomemory:60-5f iomemory:60-5f irq:74 memory:670200000-6702fffff memory:670300000-670303fff memory:670304000-670304fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
None of the online fixes helped.
Maybe an update broke it? Maybe the kernel is bad? Maybe I should reinstall it?
EDIT
Ran the WIFI diagnose script from WinEunuuchs2Unix's comment: https://pastebin.com/5kALkQi5
