I have three separate USB wifi adapters. All work in Windows. One says Linux compatible on the package (I'll call it "A"). It even comes with Linux drivers.
I used lsusb.
I see the two of the adapters, but not the one which specifies linux compatability and came with drivers.
I copied the drivers for "A" to a folder in my home folder I called wifi. I clicked properties on install.sh and clicked 'allow executing'. I executed it and it seemed to install some drivers, I was asked for my password twice. But still, the USB is not showing up in lsusb.
The other two usb adapters (I don't really care which one I use, as long as it works) show up on lsusb. How do I install the drivers?
One is an Asus (Broadcom BCM43526) The other just says ID: 2001:331a D-Link Corp. (Its the Death Star looking USB3 usb wifi adapters..Yes, its pretty cool).
So, I know you all get asked this many times a day, but I am stuck on this one. I would love to use the one that has the drivers on the dvd. But, I will use any of them.
I am using the latest version of Ubuntu Mate. Bionic Beaver 18.04. The motherboard is an Asrock970m Pro3 (crap) CPU: FX-6350, not overclocked. (crap too, but it was sitting around). 8 gigs ram. Want to use this rig as a media server/file server.
In an semi-related issue, I have an Nvidia GTX760 in here and its not giving me any option to install the proprietary drivers from Nvidia.
Thanks again, any help is appreciated.
DanL.
  • 31
For the ASUS BCM43526 try:
In terminal...
sudo apt-get update
sudo apt-get install broadcom-sta-dkms
For the D-Link DWA-192:
In terminal...
sudo apt-get install build-essential git
sudo git clone https://github.com/zebulon2/rtl8814au.git
create dkms.conf in the rt8814au folder, and add these lines...
# rtl8814AU-4.3.21_17997.20160531
PACKAGE_NAME="rtl8814au"
PACKAGE_VERSION="4.3.21_17997.20160531"
MAKE[0]="'make' all KVER=${kernelver}"
BUILT_MODULE_NAME[0]="8814au"
DEST_MODULE_LOCATION[0]="/updates/dkms"
AUTOINSTALL="YES"
REMAKE_INITRD="NO"
then...
sudo cp -r rtl8814au /usr/src/rtl8814au-4.3.21
sudo dkms add rtl8814au/4.3.21
sudo dkms build rtl8814au/4.3.21
sudo dkms install rtl8814au/4.3.21
dkms status
note: you may have to adjust the version numbers if a newer release exists
heynnema
  • 73,649
With a temporary working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
sudo apt-get update
git clone https://github.com/ulli-kroll/rtl8814au.git
cd rtl8814au
make
sudo make installfw
sudo insmod rtl8814au.ko
Please tell us if the device is now working as I will have further instructions to add in an edit.
EDIT: We see this message in your make:
Makefile:976: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
Please do:
sudo apt update
sudo apt install libelf-dev
A series of dependencies will also be installed. Follow with:
cd rtl8814au
make clean
make
Post any errors.
chili555
  • 61,330
