I have a strange issue. I moved to another city with different Internet and now after being connected to Wi-fi for few minutes (~5) Internet stops working, but wi-fi is still connected. Disconnecting and connecting back does not help - no Internet. The only thing that works is to turn off networking completely and then turn it back on. After this procedure I can to connect to wifi with Internet, but Internet works only for several minutes and then I lose it again. A very strange issue, I never had it before (using Linux for ~10 years). Btw wifi works perfectly fine on Chromebook. Any suggestion? Thanks!
Here is my info generated using the script from here.
Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
~$ iwconfig
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"BLABLA"
      Mode:Managed  Frequency:2.437 GHz  Access Point: 68:EF:BD:2D:BE:A3
      Bit Rate=72.2 Mb/s   Tx-Power=16 dBm
      Retry  long limit:7   RTS thr:off   Fragment thr:off
      Power Management:off
      Link Quality=61/70  Signal level=-49 dBm
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:0   Missed beacon:0
Yuri
  • 346
You have a few things that we can change to help your connection. First you have many networks in your area so their is a lot of channel congestion. Go into your router and try channel 2,4, or 9. We usually recommend 1,6 or 11 but to many other people are using those channel. Set encryption to just wpa2 AES personal not TKIP. Then save your router configuration.
Go into network manager top right corner of the screen and change IPV6 to ignore then reboot.
Edit:
Run
sudo iwlist scan
that will show all networks available find the Mac Address of the network you want to connect too then open network manager and put the Mac Address in the BSSID column, save the setting of network manager then reboot computer.
Wild Man
  • 8,327
