I run Ubuntu 20.04 and this script every day:
sudo apt update && sudo apt full-upgrade -y && sudo apt -f install && sudo apt autoremove -y && sudo apt autoclean && sudo snap refresh
After the end of every day, I power down my desktop. Maybe not the smartest script, but this is the first problem it's caused in 2 years or so... (I assume this problem is due to an update.)
This morning, when I booted, when I search for Wi-Fi in settings:
No Wi-Fi Adapter Found
I've been using the wireless adapters on my motherboard, which I'm assuming an update broke the drivers for. For now I'm using the sub-optimal powerline Ethernet.
Nothing shows up for sudo rfkill list all and the wireless device is not show when using ip a or ifconfig. (This also goes for Bluetooth, which is also on the motherboard and also enabled in the BIOS.)
Here's some partial output showing my wireless adapter being unclaimed.
$ sudo lshw -C network
*-network UNCLAIMED description: Network controller product: Dual Band Wireless-AC 3168NGW [Stone Peak] vendor: Intel Corporation physical id: 0 bus info: pci@0000:03:00.0 version: 10 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress cap_list configuration: latency=0 resources: memory:ab300000-ab301fff
Here's the logs from my /var/log/apt/history.log with yesterday's date:
Start-Date: 2021-06-23  10:11:24
Commandline: /usr/bin/unattended-upgrade
Upgrade: gcc-10-base:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), gcc-10-base:i386 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libitm1:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libquadmath0:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libtsan0:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libubsan1:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), liblsan0:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libgomp1:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libgcc-s1:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libgcc-s1:i386 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libatomic1:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libatomic1:i386 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libcc1-0:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libstdc++6:amd64 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04), libstdc++6:i386 (10.2.0-5ubuntu1~20.04, 10.3.0-1ubuntu1~20.04)
End-Date: 2021-06-23  10:11:25
Start-Date: 2021-06-23 10:27:38 Commandline: apt full-upgrade -y Requested-By: micah (1000) Install: linux-modules-extra-5.8.0-59-generic:amd64 (5.8.0-59.66~20.04.1, automatic), linux-headers-5.8.0-59-generic:amd64 (5.8.0-59.66~20.04.1, automatic), linux-objects-nvidia-460-5.11.0-22-generic:amd64 (5.11.0-22.23~20.04.1+1, automatic), linux-modules-5.8.0-59-generic:amd64 (5.8.0-59.66~20.04.1, automatic), linux-modules-5.11.0-22-generic:amd64 (5.11.0-22.23~20.04.1, automatic), linux-modules-nvidia-460-5.11.0-22-generic:amd64 (5.11.0-22.23~20.04.1+1, automatic), linux-hwe-5.8-headers-5.8.0-59:amd64 (5.8.0-59.66~20.04.1, automatic), linux-signatures-nvidia-5.11.0-22-generic:amd64 (5.11.0-22.23~20.04.1+1, automatic), linux-image-5.11.0-22-generic:amd64 (5.11.0-22.23~20.04.1, automatic), linux-image-5.8.0-59-generic:amd64 (5.8.0-59.66~20.04.1, automatic) Upgrade: linux-headers-generic-hwe-20.04:amd64 (5.8.0.55.62~20.04.39, 5.8.0.59.66~20.04.42), linux-libc-dev:amd64 (5.4.0-74.83, 5.4.0-77.86), linux-modules-nvidia-460-generic-hwe-20.04-edge:amd64 (5.8.0-55.62~20.04.1, 5.11.0-22.23~20.04.1+1), initramfs-tools-bin:amd64 (0.136ubuntu6.5, 0.136ubuntu6.6), linux-image-generic-hwe-20.04:amd64 (5.8.0.55.62~20.04.39, 5.8.0.59.66~20.04.42), linux-generic-hwe-20.04:amd64 (5.8.0.55.62~20.04.39, 5.8.0.59.66~20.04.42), gnome-shell-common:amd64 (3.36.9-0ubuntu0.20.04.1, 3.36.9-0ubuntu0.20.04.2), gnome-shell:amd64 (3.36.9-0ubuntu0.20.04.1, 3.36.9-0ubuntu0.20.04.2), initramfs-tools-core:amd64 (0.136ubuntu6.5, 0.136ubuntu6.6), initramfs-tools:amd64 (0.136ubuntu6.5, 0.136ubuntu6.6) End-Date: 2021-06-23 10:28:42
Start-Date: 2021-06-23 10:28:43 Commandline: apt autoremove -y Requested-By: micah (1000) Remove: linux-modules-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1), linux-signatures-nvidia-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1), linux-objects-nvidia-460-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1), linux-hwe-5.8-headers-5.8.0-53:amd64 (5.8.0-53.60~20.04.1), linux-image-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1), linux-modules-extra-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1), linux-headers-5.8.0-53-generic:amd64 (5.8.0-53.60~20.04.1) End-Date: 2021-06-23 10:28:48
My hunch is I need to reinstall a specific version of Linux headers or something, but honestly, I'm not too sure. Anyone have an idea of what could get my wireless device reclaimed and usable?
In our chat, we learned that the package linux-modules-extra-5.11.0-22-generic that provides the driver iwlwifi among many others, didn't get installed in your upgrade. I suggested that you do, while booted into kernel version 5.8 where the wireless does work:
sudo apt update
sudo apt install linux-modules-extra-5.11.0-22-generic
Upon rebooting into kernel version 5.11, your wireless is now working.
I also recommended:
sudo apt install --reinstall linux-generic
...because its dependencies and their dependencies include linux-modules extra.
chili555
  • 61,330
If you have a dual boot with Windows, you might want to disable the Fast Startup in Windows.
See: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi#about_dual-boot_with_windows_and_fast-boot_enabled
More: https://wiki.archlinux.org/title/Dual_boot_with_Windows#Fast_Startup_and_hibernation
Yiqian
  • 151
Here's what worked for me. First find out your kernel version:
uname -r
Note down the kernel version. (example: 6.5.0-44-generic), then run the following below (and replace the numbers with your kernel version).
sudo apt update
sudo apt install linux-modules-extra-6.5.0-44-generic
Reboot the PC and WiFi should be back.
aleksk
  • 151
If you are running Ubuntu in WSL, you need to disable Fast Startup in Windows, before the linux was telling me that the wifi is unclaimed. After disabling fast startup its working.
