12
After installing Ubuntu 14.04 the wifi icon and option just disappeared. I have tried to reboot it and searching the settings for it, but it does not let me connect to a wifi connection in any way. The only way to connect to the internet is with a wired connection. So how can I fix this and is this a bug or something that has to do with the version? I installed it on a Dell Inspiron 910 mini netbook.
user287577
  • 121
First you have to stop network manager from background:
sudo service network-manager stop
Remove file on /var/lib/NetworkManager/NetworkManager.state path:
sudo rm /var/lib/NetworkManager/NetworkManager.state
Start network manager back:
sudo service network-manager start
Source
Liso
  • 15,677
10
I was facing this very same issue. Please note that wireless was working fine all this time, its just the missing icon.
Here is what worked for me. Unity -> Startup Applications - and check "Indicator Application" (if its not already checked.) Next install following two packages: indicator-applet and indicator-network.
sudo apt-get install indicator-applet indicator-network
I am using Ubuntu 14.04 64bit on Dell Inspiron 1564.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
