I have been using Ubuntu 18.04 for almost 1 year on my Samsung Expert with Qualcomm QCA9377 adapter and it has been working fine. But since last week, no wireless connections are found. I have Windows also installed and all available connections appear normally so it is not a hardware issue.
I ran lshw -C network command and the following message regarding my wireless interface appears:
*-network
description: Wireless interface
product: QCA9377 802.11ac Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 31
serial: 98:83:89:8c:13:09
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath10k_pci driverversion=4.15.0-54-generic firmware=WLAN.TF.2.1-00021-QCARMSWP-1 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:126 memory:ef000000-ef1fffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
I also ran lspci, and I get the following message:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
02:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
Another command I ran is rfkill list all and I got the message:
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Apparently, the adapter is ok.
I also tried to update the whole system by doing the commands:
sudo apt-get update
sudo apt-get upgrade
sudo reboot
Another thing I tried is iwconfig, and the following message appears:
wlp2s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
lo no wireless extensions.
enp1s0 no wireless extensions.
None of these helped. Do I need to reinstall Ubuntu? I have short experience in Ubuntu and Bash.
Thanks.
