I purchased a new laptop with Ryzen 5 processor and installed Ubuntu 20.04.5 LTS. I followed this guide to setup my wifi adapter: wifi Adapter not found realtek RTL8852BE WiFi 6 802.11ax PCIe in ubuntu 22.04.
However, after building rtl8852be, when I try sudo modprobe 8852be, it gives me the error modprobe: ERROR: could not insert '8852be': Operation not permitted.
$ lshw -C network
WARNING: you should run this program as super-user.
*-network UNCLAIMED
description: Network controller
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: latency=0
resources: ioport:f000(size=256) memory:fcf00000-fcffffff
*-network
description: Ethernet interface
physical id: 1
bus info: usb@2:2
logical name: enxa0cec8ea5aff
serial: a0:ce:c8:ea:5a:ff
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ax88179_178a driverversion=5.15.0-67-generic duplex=full ip=10.12.142.117 link=yes multicast=yes port=MII speed=1Gbit/s
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
$ lspci | grep Network
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
$ sudo dmesg | grep -i rtw
(no output)
$ lsmod | grep rtw
rtw89_pci 49152 0
rtw89_core 995328 1 rtw89_pci
mac80211 1249280 2 rtw89_core,rtw89_pci
cfg80211 970752 2 rtw89_core,mac80211
How should I proceed?
Edit
When I rebooted after switching off secure boot, I am now able to connect to WiFi.
