10
I have installed Ubuntu 14.04 LTS on my laptop.
Under the networking menu at the top, it is not showing any WiFi options.
How can I get Wifi working in Ubuntu 14.04 LTS?
I have a Broadcom BCM4311 WLAN card.
Braiam
  • 69,112
For Broadcom BCM4311,
sudo apt-get purge bcmwl-kernel-source broadcom-sta-common broadcom-sta-source broadcom-sta-dkms
sudo apt-get install b43-fwcutter firmware-b43-installer
See here https://help.ubuntu.com/community/BroadcomSTA(Wireless)
you can go to
settings> Software and updates > additional drivers
you can get most of wireless/Graphics drivers. You can install any 3rd party driver software you require. Hope that helps!
If you're using a Broadcom (BCM43xx) wireless network card like me, this might help.
I connected the laptop using a cable and ran:
sudo apt-get install firmware-b43-installer
to install the driver and then rebooted.
(It would be helpful to add your network card to the question.)
Seth
  • 59,332
Maybe you faced a problem like me Network indicator disappeared.
A solution that works for me is here:
http://www.webupd8.org/2014/04/fix-lubuntu-1404-network-manager.html
Simply speaking, try nm-applet at first, if you take back WiFi indicator, then add nm-applet to Default applications for LXSession.
scozv
  • 480
