A while after getting a new router, I started experiencing a problem with wireless networking on my Ubuntu 20.04 laptop. When I turn it on, it detects my wireless network and connects to it.
However, the connection breaks soon after I log in, or after a few hours. Sometimes, I need to restart Ubuntu three times until I get a seemingly stable connection.
When I lose the connection, I can't even see the Wireless (WIFI) option in the settings.
This isn't my field of expertise, so I'd appreciate it if anyone would help me.
Here are the logs and outputs of some commands. Note that I'm currently using a wired connection and that I got these logs and outputs after the wireless connection broke.
Operating system:
uname -a
Linux xxx 5.13.0-48-generic #54~20.04.1-Ubuntu SMP Thu Jun 2 23:37:17 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Networking hardware:
sudo lshw -class network
*-usb:1
description: Ethernet interface
product: USB 2.0 10/100M Ethernet Adaptor
vendor: ICS Advent
physical id: 3
bus info: usb@1:3
logical name: enx00e04c534458
version: 1.01
serial: 00:e0:4c:53:44:58
capacity: 100Mbit/s
capabilities: usb-1.10 ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=dm9601 driverversion=5.13.0-48-generic duplex=full firmware=Davicom DM96xx USB 10/100 Ether ip=192.168.1.5 link=yes maxpower=120mA multicast=yes port=MII speed=100Mbit/s
*-network UNCLAIMED
description: Network controller
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 78
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:ef100000-ef101fff
dmesg: the logs are in the pastebin file.
The wireless info script:
########## wireless info START ##########
Report from: 16 Jun 2022 10:25 CEST +0200
Booted last: 16 Jun 2022 00:00 CEST +0200
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
kernel
Linux 5.13.0-48-generic #54~20.04.1-Ubuntu SMP Thu Jun 2 23:37:17 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
Ubuntu
lspci
02:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265 [8086:0010]
Kernel modules: iwlwifi
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0a2b Intel Corp.
Bus 001 Device 003: ID 13d3:5a11 IMC Networks USB2.0 VGA UVC WebCam
Bus 001 Device 005: ID 0fe6:9700 ICS Advent DM9601 Fast Ethernet Adapter
Bus 001 Device 002: ID 04d9:a06b Holtek Semiconductor, Inc. Wireless USB Device
PCMCIA card info
rfkill
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
secure boot
SecureBoot disabled
Platform is in Setup Mode
lsmod
iwlmvm 421888 0
mac80211 1028096 1 iwlmvm
libarc4 16384 1 mac80211
iwlwifi 372736 1 iwlmvm
asus_nb_wmi 28672 0
wmi_bmof 16384 0
cfg80211 888832 3 iwlmvm,iwlwifi,mac80211
mxm_wmi 16384 1 nouveau
asus_wmi 36864 2 asus_nb_wmi,mfd_aaeon
sparse_keymap 16384 1 asus_wmi
wmi 32768 5 asus_wmi,wmi_bmof,mfd_aaeon,mxm_wmi,nouveau
video 53248 3 asus_wmi,i915,nouveau
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback <MAC address> brd <MAC address>
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
3: anbox0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether <MAC 'anbox0' [IF1]> brd <MAC address>
inet 192.168.250.1/24 scope global anbox0
inet6 fe80::<IP6 'anbox0' [IF1]>/64 scope link
4: enx<IF from MAC [IF2]>: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether <MAC 'enx<IF from MAC [IF2]>' [IF2]> brd <MAC address>
inet 192.168.1.5/24 brd 192.168.1.255 scope global dynamic noprefixroute enx<IF from MAC [IF2]>
valid_lft 259073sec preferred_lft 259073sec
inet6 fe80::e3c8:d3de:991f:a1a5/64 scope link noprefixroute
iwconfig
lo no wireless extensions.
anbox0 no wireless extensions.
enx<IF from MAC [IF2]> no wireless extensions.
route
default via 192.168.1.1 dev enx<IF from MAC [IF2]> proto dhcp metric 20100
169.254.0.0/16 dev anbox0 scope link metric 1000
192.168.1.0/24 dev enx<IF from MAC [IF2]> proto kernel scope link src 192.168.1.5 metric 100
192.168.250.0/24 dev anbox0 proto kernel scope link src 192.168.250.1
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53
options edns0 trust-ad
network managers
Installed:
NetworkManager
Running:
root 1061 1 1 10:21 ? 00:00:04 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enx<IF from MAC [IF2]>
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/6
GENERAL.VENDOR: ICS Advent
GENERAL.PRODUCT: DM9601 Fast Ethernet Adapter
GENERAL.DRIVER: dm9601
GENERAL.DRIVER-VERSION: 5.13.0-48-generic
GENERAL.FIRMWARE-VERSION: Davicom DM96xx USB 10/100 Ether
GENERAL.HWADDR: <MAC 'enx<IF from MAC [IF2]>' [IF2]>
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.IP4-CONNECTIVITY: 3 (limited)
GENERAL.IP6-CONNECTIVITY: 3 (limited)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/net/enx<IF from MAC [IF2]>
GENERAL.IP-IFACE: enx<IF from MAC [IF2]>
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: Wired connection 1
GENERAL.CON-UUID: ddad471b-4e56-3ee2-a74d-15eecf8d404a
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/3
GENERAL.METERED: no (guessed)
CAPABILITIES.CARRIER-DETECT: yes
CAPABILITIES.SPEED: 100 Mb/s
CAPABILITIES.IS-SOFTWARE: no
CAPABILITIES.SRIOV: no
INTERFACE-FLAGS.UP: yes
INTERFACE-FLAGS.LOWER-UP: yes
INTERFACE-FLAGS.CARRIER: yes
WIRED-PROPERTIES.CARRIER: on
IP4.ADDRESS[1]: 192.168.1.5/24
IP4.GATEWAY: 192.168.1.1
IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 20100
IP4.ROUTE[2]: dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 100
IP4.DNS[1]: 192.168.1.1
DHCP4.OPTION[1]: dhcp_lease_time = 259200
DHCP4.OPTION[2]: domain_name_servers = 192.168.1.1
DHCP4.OPTION[3]: expiry = 1655626999
DHCP4.OPTION[4]: ip_address = 192.168.1.5
DHCP4.OPTION[5]: requested_broadcast_address = 1
DHCP4.OPTION[6]: requested_domain_name = 1
DHCP4.OPTION[7]: requested_domain_name_servers = 1
DHCP4.OPTION[8]: requested_domain_search = 1
DHCP4.OPTION[9]: requested_host_name = 1
DHCP4.OPTION[10]: requested_interface_mtu = 1
DHCP4.OPTION[11]: requested_ms_classless_static_routes = 1
DHCP4.OPTION[12]: requested_nis_domain = 1
DHCP4.OPTION[13]: requested_nis_servers = 1
DHCP4.OPTION[14]: requested_ntp_servers = 1
DHCP4.OPTION[15]: requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[16]: requested_root_path = 1
DHCP4.OPTION[17]: requested_routers = 1
DHCP4.OPTION[18]: requested_static_routes = 1
DHCP4.OPTION[19]: requested_subnet_mask = 1
DHCP4.OPTION[20]: requested_time_offset = 1
DHCP4.OPTION[21]: requested_wpad = 1
DHCP4.OPTION[22]: routers = 192.168.1.1
DHCP4.OPTION[23]: subnet_mask = 255.255.255.0
IP6.ADDRESS[1]: fe80::e3c8:d3de:991f:a1a5/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 100
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/12
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: ddad471b-4e56-3ee2-a74d-15eecf8d404a | Wired connection 1
GENERAL.DEVICE: anbox0
GENERAL.TYPE: bridge
GENERAL.NM-TYPE: NMDeviceBridge
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/5
GENERAL.VENDOR: --
GENERAL.PRODUCT: --
GENERAL.DRIVER: bridge
GENERAL.DRIVER-VERSION: 2.3
GENERAL.FIRMWARE-VERSION: N/A
GENERAL.HWADDR: <MAC 'anbox0' [IF1]>
GENERAL.MTU: 1500
GENERAL.IP4-CONNECTIVITY: 1 (none)
GENERAL.IP6-CONNECTIVITY: 1 (none)
GENERAL.UDI: /sys/devices/virtual/net/anbox0
GENERAL.IP-IFACE: anbox0
GENERAL.IS-SOFTWARE: yes
GENERAL.CONNECTION: anbox0
GENERAL.CON-UUID: 8cc8ce19-18fa-4c76-9688-42dddd810147
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/1
CAPABILITIES.SPEED: unknown
CAPABILITIES.IS-SOFTWARE: yes
IP4.ADDRESS[1]: 192.168.250.1/24
IP4.GATEWAY: --
IP4.ROUTE[1]: dst = 192.168.250.0/24, nh = 0.0.0.0, mt = 0
IP4.ROUTE[2]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP6.ADDRESS[1]: fe80::<IP6 'anbox0' [IF1]>/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256
BRIDGE.SLAVES: --
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/11
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 8cc8ce19-18fa-4c76-9688-42dddd810147 | anbox0
GENERAL.DEVICE: <MAC address>
GENERAL.TYPE: bt
GENERAL.NM-TYPE: NMDeviceBt
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/3
GENERAL.VENDOR: --
GENERAL.PRODUCT: --
GENERAL.DRIVER: bluez
GENERAL.DRIVER-VERSION: --
GENERAL.FIRMWARE-VERSION: --
GENERAL.HWADDR: <MAC address>
GENERAL.MTU: 0
GENERAL.STATE: 30 (disconnected)
GENERAL.UDI: /org/bluez/hci0/dev_D0_04_B0_50_98_A2
GENERAL.IP-IFACE: --
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
INTERFACE-FLAGS.UP: no
INTERFACE-FLAGS.LOWER-UP: no
INTERFACE-FLAGS.CARRIER: no
BLUETOOTH.CAPABILITIES: NAP
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/10
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 9f55da1a-f11e-4207-90a5-27dacf039d2d | Galaxy A52s 5G Network
NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 2
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]]
[connectivity]
uri=http://connectivity-check.ubuntu.com/
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-mac-addr-change-wifi]
match-device=driver:rtl8723bs,driver:rtl8189es,driver:r8188eu,driver:8188eu,driver:eagle_sdio,driver:wl
NetworkManager profiles
[[/etc/NetworkManager/system-connections/ZTE_H168.nmconnection]] (600 root)
[connection] id=ZTE_H168 | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=ZTE_H168
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/SBB Zona.nmconnection]] (600 root)
[connection] id=SBB Zona | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=SBB Zona
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/TS-h4dZ.nmconnection]] (600 root)
[connection] id=TS-h4dZ | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=TS-h4dZ
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/M mreza.nmconnection]] (600 root)
[connection] id=M mreza | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=M mreza
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/HUAWEI-B311-230A.nmconnection]] (600 root)
[connection] id=HUAWEI-B311-230A | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=HUAWEI-B311-230A
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/MIWIFI_2G_cQXb.nmconnection]] (600 root)
[connection] id=MIWIFI_2G_cQXb | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=MIWIFI_2G_cQXb
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/Telenor-Internet-E5.nmconnection]] (600 root)
[connection] id=Telenor-Internet-E5 | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=Telenor-Internet-E5
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/HP-Print-5C-Deskjet 3540 series.nmconnection]] (600 root)
[connection] id=HP-Print-5C-Deskjet 3540 series | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=HP-Print-5C-Deskjet 3540 series
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/Fokus.nmconnection]] (600 root)
[connection] id=Fokus | type=wifi | permissions=
[wifi] mac-address-blacklist= | ssid=Fokus
[ipv4] method=auto
[ipv6] method=auto
Netplan config
[/etc/netplan/01-network-manager-all.yaml]
network:
version: 2
renderer: NetworkManager
iw reg get
Region: Europe/Belgrade (based on set time zone)
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
iwlist channels
lo no frequency information.
anbox0 no frequency information.
enx<IF from MAC [IF2]> no frequency information.
iwlist scan
lo Interface doesn't support scanning.
anbox0 Interface doesn't support scanning.
enx<IF from MAC [IF2]> Interface doesn't support scanning.
module infos
[iwlmvm]
filename: /lib/modules/5.13.0-48-generic/kernel/drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
license: GPL
description: The new Intel(R) wireless AGN driver for Linux
depends: iwlwifi,mac80211,cfg80211
retpoline: Y
intree: Y
vermagic: 5.13.0-48-generic SMP mod_unload modversions
parm: init_dbg:set to true to debug an ASSERT in INIT fw (default: false (bool)
parm: power_scheme:power management scheme: 1-active, 2-balanced, 3-low power, default: 2 (int)
[mac80211]
filename: /lib/modules/5.13.0-48-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
depends: cfg80211,libarc4
retpoline: Y
intree: Y
parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool)
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[iwlwifi]
filename: /lib/modules/5.13.0-48-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
depends: cfg80211
retpoline: Y
intree: Y
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
[cfg80211]
filename: /lib/modules/5.13.0-48-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
depends:
retpoline: Y
intree: Y
parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int)
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
module parameters
[iwlmvm]
init_dbg: N
power_scheme: 2
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
minstrel_vht_only: Y
probe_wait_ms: 500
[iwlwifi]
11n_disable: 0
amsdu_size: 0
bt_coex_active: Y
disable_11ac: N
disable_11ax: N
enable_ini: Y
fw_restart: Y
led_mode: 0
nvm_file: (null)
power_level: 0
power_save: N
remove_when_gone: N
swcrypto: 0
uapsd_disable: 3
[cfg80211]
bss_entries_limit: 1000
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 79.111201] ? __iwl_err.cold+0x25/0x2a [iwlwifi]
[ 79.111368] iwlwifi 0000:02:00.0: iwl_trans_wait_tx_queues_empty bad state = 0
[ 79.111382] wlp2s0: failed to remove key (1, <MAC address>) from hardware (-5)
[ 79.212274] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 79.212361] iwlwifi 0000:02:00.0: HW_REV=0xFFFFFFFF, PCI issues?
[ 79.212407] iwlwifi: probe of 0000:02:00.0 failed with error -5
[ 118.171881] dm9601 1-3:1.0 eth0: register 'dm9601' at usb-0000:00:14.0-3, Davicom DM96xx USB 10/100 Ethernet, <MAC 'enx<IF from MAC [IF2]>' [IF2]>
[ 118.211446] dm9601 1-3:1.0 enx<IF from MAC [IF2]>: renamed from eth0
[ 118.290596] dm9601 1-3:1.0 enx<IF from MAC [IF2]>: link up, 100Mbps, full-duplex, lpa 0xFFFF
[ 119.949226] IPv6: ADDRCONF(NETDEV_CHANGE): enx<IF from MAC [IF2]>: link becomes ready
[ 119.972111] dm9601 1-3:1.0 enx<IF from MAC [IF2]>: link up, 100Mbps, full-duplex, lpa 0xFFFF (repeated 2 times)
########## wireless info END ############
When WiFi is working, I get this output for lshw -C network:
*-network
description: Wireless interface
physical id: 0
logical name: wlp2s0
version: 78
serial: a4:c3:f0:95:cf:e0
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.13.0-48-generic firmware=36.77d01142.0 8265-36.ucode ip=192.168.1.3 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:127 memory:ef100000-ef101fff
