Well I had after half a year of not using ubuntu half a dozen updates, around 1.9 GB of updates.
I noticed afterwards I had to reinstall the drivers for my antenna, as per here: (Driver for the TP-Link AC600 Archer T2U Nano, on Kubuntu 18.04 Previous fix from June 6 didn't work for me)
Now the antenna is found again. Yet when I open it, it doesn't show any networks available. Even though there should be plenty (not only my own, but also from the neighbours/public bar etc)
On my phone, the same computer windows partition a macbook it all works and I can perfectly fine see them. Also I know for sure it worked in the past.
How can I debug, what can I do? I've uninstalled and reinstalled the drivers and rebooted as well.
$sudo lshw -C network
  *-network
       description: Ethernet interface
       product: RTL8125 2.5GbE Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: enp4s0
       version: 05
       serial: d8:5e:d3:5b:fe:42
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.5.0-35-generic firmware=rtl8125b-2_0.0.2 07/13/20 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:18 ioport:3000(size=256) memory:43200000-4320ffff memory:43210000-43213fff
  *-network:0
       description: Wireless interface
       physical id: 8
       bus info: usb@1:6.2
       logical name: wlx5ca6e66e0cd9
       serial: 5c:a6:e6:6e:0c:d9
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl88XXau driverversion=6.5.0-35-generic multicast=yes wireless=unassociated
  *-network:1
       physical id: 9
       bus info: usb@1:4.3
       logical name: enx023402016263
       serial: 02:34:02:01:62:63
       configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=6.5.0-35-generic duplex=half firmware=RNDIS device ip=192.168.126.254 link=yes multicast=yes port=twisted pair
paul23
  • 391
