I have a custom built PC that I chose to put Ubuntu 22.04 LTS on. It's been running great up until a few days ago. My motherboard has Wi-Fi built-in and I noticed it would just randomly drop. Reset my router and everything and it was still happening, but I got a USB Wi-Fi adapter because I thought it was the card in the board itself but the issue started happening with the USB adapter too. I wanted to go ahead and just take a software update error approach before assuming it's a hardware fault.
sudo lshw -C network
*-network
description: Ethernet interface
product: RTL8125 2.5GbE Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:0c:00.0
logical name: enp12s0
version: 05
serial: 04:7c:16:d9:30:69
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.5.0-14-generic firmware=rtl8125b-2_0.0.2 07/13/20 latency=0 link=no multicast=yes port=twisted pair
resources: irq:39 ioport:e000(size=256) memory:fc500000-fc50ffff memory:fc510000-fc513fff
*-network
description: Wireless interface
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:0d:00.0
logical name: wlp13s0
version: 00
serial: 00:41:0e:e4:84:23
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=mt7921e driverversion=6.5.0-14-generic firmware=____000000-20221227123243 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: iomemory:fc0-fbf irq:104 memory:fc20300000-fc203fffff memory:fc400000-fc407fff
*-network
physical id: 7
bus info: usb@2:5.4
logical name: wlx9418655dc484
serial: 94:18:65:5d:c4:84
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=mt7921u driverversion=6.5.0-14-generic firmware=____010000-20220209150915 ip=192.168.2.164 link=yes multicast=yes wireless=IEEE 802.11
I didn't immediately see anything when I did a journalctl -b 0 -u NetworkManager either.
Edit: I forgot to do sudo and now for some reason the network has stopped randomly dropping. Very weird.
Edit2: After running sudo journalctl -b 0 -u NetworkManager I am getting an output which has warnings.
Jan 17 15:51:34 trey-MS-7D78 NetworkManager[1626]: <info> [1705528294.1320] audit: op="connection-add-activate" uuid="c35dc574-7111-4322-8651-550e452d176f" name="RAGtrey 1" pid=4087 uid=1000 result="success"
Jan 17 15:51:34 trey-MS-7D78 NetworkManager[1626]: <info> [1705528294.1321] device (wlp13s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 17 15:51:34 trey-MS-7D78 NetworkManager[1626]: <info> [1705528294.1322] device (wlp13s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 17 15:51:34 trey-MS-7D78 NetworkManager[1626]: <info> [1705528294.1323] device (wlp13s0): Activation: (wifi) access point 'RAGtrey 1' has security, but secrets are required.
Jan 17 15:51:34 trey-MS-7D78 NetworkManager[1626]: <info> [1705528294.1323] device (wlp13s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jan 17 15:51:39 trey-MS-7D78 NetworkManager[1626]: <warn> [1705528299.6840] device (wlp13s0): no secrets: User canceled the secrets request.
Jan 17 15:51:39 trey-MS-7D78 NetworkManager[1626]: <info> [1705528299.6841] device (wlp13s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Jan 17 15:51:39 trey-MS-7D78 NetworkManager[1626]: <warn> [1705528299.6843] device (wlp13s0): Activation: failed for connection 'RAGtrey 1'
Jan 17 15:51:39 trey-MS-7D78 NetworkManager[1626]: <info> [1705528299.6844] device (wlp13s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
