I have an HP laptop with an Realtek 8852BE wifi card, and I am unable to use the driver even though the driver for it is supposed to be included in the kernel after 5.16+ as per lwfinger README.md.
How can I use the driver available in the kernel assuming it is actually available?
Currently I am using this driver, but it is deprecated: https://github.com/HRex39/rtl8852be
I had also tried this driver, but it was unstable: https://github.com/lwfinger/rtw89
Running sudo lshw -C network returns:
*-network
description: Wireless interface
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlo1
version: 00
serial: xx:xx:xx:xx:xx:xx
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8852be driverversion=v1.15.6.0.2-0-gac110bf5.2021102 firmware=N/A ip=192.xxx.xxx.xxx latency=0 link=yes multicast=yes wireless=IEEE 802.11AC
resources: irq:74 ioport:f000(size=256) memory:fcf00000-fcffffff
Running uname -r returns: 5.19.0-35-generic
I don't know how to see if the driver is available, so I tried to figure out if the module is available using the command below.
Running modprobe -D rtw_8852ae returns:
modprobe: FATAL: Module rtw_8852ae not found in directory /lib/modules/5.19.0-35-generic
Running modprobe -D rtw_core returns:
modprobe: FATAL: Module rtw_core not found in directory /lib/modules/5.19.0-35-generic
Edit: The HRex39 driver is working at least for now, but since it's deprecated, I wanted to switch to the kernel provided driver. The only annoying thing is that I have to recompile it for every kernel update.
The OS is Ubuntu 22.04.2 LTS
Edit 2:
I have executed the diagnosis script, but I don't see anything that could point me to the cause of the issue. All I see is the iwlwifi being removed, but as far as I know that is only for intel wifi.
Details:
I had unloaded the module with modprobe -rv 8852be which returned:
rmmod 8852be
rmmod cfg80211
Then rebooted... after which it turns out that the driver was loaded again, so I had removed it once more with modprobe -rv 8852be then blacklisted it using: echo "blacklist 8852be" >> /etc/modprobe.d/local-dontload.conf. I rebooted again and this time I no longed had wifi.
I also tried loading both of the following two modules but to no effect: modprobe mac80211 and modprobe cfg80211
Running the script from: https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info returns:
########## wireless info START ##########
Report from: 10 Mar 2023 09:17 EST -0500
Booted last: 10 Mar 2023 00:00 EST -0500
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
kernel
Linux 5.19.0-35-generic #36~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Feb 17 15:17:25 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
sed: can't read /root/.dmrc: No such file or directory
Could not be determined.
lspci
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
DeviceName: Realtek Wireless LAN + BT
Subsystem: Hewlett-Packard Company Device [103c:88e3]
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:b85c Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 002: ID 30c9:0065 Luxvisions Innotech Limited HP Wide Vision HD Camera
PCMCIA card info
rfkill
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
secure boot
SecureBoot disabled
lsmod
hp_wmi 20480 0
sparse_keymap 16384 1 hp_wmi
platform_profile 16384 1 hp_wmi
wmi_bmof 16384 0
wmi 32768 2 hp_wmi,wmi_bmof
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback <MAC address> brd <MAC address>
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
iwconfig
lo no wireless extensions.
route
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53
options edns0 trust-ad
search .
network managers
Installed:
NetworkManager
Running:
root 819 1 0 09:17 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: <MAC address>
GENERAL.TYPE: bt
GENERAL.NM-TYPE: NMDeviceBt
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2
GENERAL.VENDOR: --
GENERAL.PRODUCT: --
GENERAL.DRIVER: bluez
GENERAL.DRIVER-VERSION: --
GENERAL.FIRMWARE-VERSION: --
GENERAL.HWADDR: <MAC address>
GENERAL.MTU: 0
GENERAL.STATE: 30 (disconnected)
GENERAL.REASON: 0 (No reason given)
GENERAL.IP4-CONNECTIVITY: 1 (none)
GENERAL.IP6-CONNECTIVITY: 1 (none)
GENERAL.UDI: /org/bluez/hci0/dev_DC_E5_5B_1B_BC_42
GENERAL.PATH: --
GENERAL.IP-IFACE: --
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
CAPABILITIES.SPEED: unknown
CAPABILITIES.IS-SOFTWARE: no
CAPABILITIES.SRIOV: no
INTERFACE-FLAGS.UP: no
INTERFACE-FLAGS.LOWER-UP: no
INTERFACE-FLAGS.CARRIER: no
INTERFACE-FLAGS.PROMISC: no
BLUETOOTH.CAPABILITIES: NAP
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/4
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 72f34379-be23-461c-a32e-e81adb42c906 | Pixel 6 Network
NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]]
[connectivity]
uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-31-mac-addr-change]
match-device=driver:eagle_sdio,driver:wl
NetworkManager profiles
[[/etc/NetworkManager/system-connections/SunnySkies.nmconnection]] (600 root)
[connection] id=SunnySkies | type=wifi
[wifi] ssid=SunnySkies
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/Mihai Phone.nmconnection]] (600 root)
[connection] id=Mihai Phone | type=wifi
[wifi] ssid=Mihai Phone
[ipv4] method=auto
[ipv6] method=auto
Netplan config
[/etc/netplan/01-network-manager-all.yaml]
network:
version: 2
renderer: NetworkManager
iw reg get
Region: America/Nassau (based on set time zone)
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
iwlist channels
lo no frequency information.
iwlist scan
lo Interface doesn't support scanning.
module infos
module parameters
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/local-dontload.conf]
blacklist 8852be
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 3.763938] [drm] Loading DMUB firmware via PSP: version=0x0101001F
[ 3.765710] [drm] Found VCN firmware Version ENC: 1.16 DEC: 5 VEP: 0 Revision: 3
########## wireless info END ############
Edit 3: After searching trough the rtw89 commits it looks to me like it is included in the 6.1 kernel. Specifically this merge I would say it adds the 8852BE driver.
- Did I understand correctly in which version it is available?
- Assuming this is true, should I expect the driver to be available when Ubuntu will include the 6.1 kernel?
