I have Ubuntu 18.04 Dual booting with Windows 10 on my HP-EliteBook-745-G2, and for some reason, I cannot seem to find WiFi networks through my WiFi adapter, but Ethernet works (however, Ethernet stops working properly if I shut my screen down, and go back into my laptop, forcing me to restart my laptop to use Ethernet).
What I have done that didn't work:
Uninstalled Kernels and reinstalled.
Tried using
rtlwifi.newas a fix.Tried connecting through a hidden network, with different networks in different places.
Reinstalled Ubuntu.
sudo service network-manager restart
So I thought I would create a new post to get a different perspective here.
Side note: WiFi works perfectly on the Windows side of things, these problems persist only on my Ubuntu boot.
The output of lshw -C network gives:
$ sudo lshw -C network
[sudo] password for nathan:
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0f0
version: 0e
serial: 30:8d:99:bf:09:ab
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=10.0.0.167 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:39 ioport:4000(size=256) memory:d5804000-d5804fff memory:d5800000-d5803fff
*-network
description: Wireless interface
product: BCM4352 802.11ac Wireless Network Adapter
vendor: Broadcom Limited
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlo1
version: 03
serial: 28:c2:dd:8f:85:ec
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:38 memory:d0a00000-d0a07fff memory:d0800000-d09fffff
Edit: Just for the people using edits to correct my grammar, 'I'd' is the same as 'I would'.
Another edit: Ran rfkill list all and here's the results:
$ rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
Then ran : dmesg | grep wl to produce:
$ dmesg | grep wl
[ 0.000000] DMI: Hewlett-Packard HP EliteBook 745 G2/221C, BIOS M84 Ver. 01.07 03/10/2015
[ 6.918774] wl: loading out-of-tree module taints kernel.
[ 6.918782] wl: module license 'MIXED/Proprietary' taints kernel.
[ 6.951608] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 7.123725] wlan0: Broadcom BCM43b1 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 7.330784] wl 0000:02:00.0 wlo1: renamed from wlan0
[ 10.672629] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 10.791775] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
Edit again
:~$ sudo modprobe wl && dmesg | grep wl
[ 7.004949] wl: loading out-of-tree module taints kernel.
[ 7.004958] wl: module license 'MIXED/Proprietary' taints kernel.
[ 7.011342] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 7.888998] wlan0: Broadcom BCM43b1 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 7.923740] wl 0000:02:00.0 wlo1: renamed from wlan0
[ 11.818773] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 11.937130] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 2546.180968] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[ 2546.291784] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
