I have a dual booted configuration, with the default Windows 8.1, and the latest Ubuntu 14.10 64-bit.
The wireless network is very slow. On Windows 8.1, it works like a charm, while on Ubuntu, I get almost 1/8th of the original speed.
However, when I use Ethernet, I get the full download/upload speed that I'm supposed to have, just like Windows.
When I switch from ethernet to wireless, all the websites suddenly stop loading, and apt-get takes forever in starting the download.
Following this script, here is the output :
########## wireless info START ##########
Report from: 21 Jan 2015 14:59 IST +0530
Booted last: 21 Jan 2015 09:50 IST +0530
Script from: 20 Sep 2014 23:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 14.10
Release: 14.10
Codename: utopic
##### kernel ############################
Linux 3.16.0-23-generic #31-Ubuntu SMP Tue Oct 21 17:56:17 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
3b:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
Subsystem: Lite-On Communications Inc Device [11ad:0652]
Kernel driver in use: ath9k
3c:00.0 Ethernet controller [0200]: Qualcomm Atheros QCA8171 Gigabit Ethernet [1969:10a1] (rev 10)
Subsystem: ASUSTeK Computer Inc. Device [1043:200f]
Kernel driver in use: alx
##### lsusb #############################
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 04f2:b414 Chicony Electronics Co., Ltd
Bus 003 Device 005: ID 0b05:17fd ASUSTek Computer, Inc.
Bus 003 Device 002: ID 0b05:17ac ASUSTek Computer, Inc.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
2: asus-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
##### lsmod #############################
asus_nb_wmi 16990 0
asus_wmi 24094 1 asus_nb_wmi
sparse_keymap 13948 1 asus_wmi
mxm_wmi 13021 0
ath9k 136984 0
ath9k_common 25638 1 ath9k
ath9k_hw 446568 2 ath9k_common,ath9k
ath 29052 3 ath9k_common,ath9k,ath9k_hw
mac80211 660592 1 ath9k
cfg80211 510218 4 ath,ath9k_common,ath9k,mac80211
wmi 19193 2 mxm_wmi,asus_wmi
video 20128 2 i915,asus_wmi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0 Link encap:Ethernet HWaddr <MAC 'eth0' [IF]>
inet addr:192.168.0.6 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:332173 errors:0 dropped:0 overruns:0 frame:0
TX packets:341601 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:398756806 (398.7 MB) TX bytes:32561235 (32.5 MB)
Interrupt:19
wlan0 Link encap:Ethernet HWaddr <MAC 'wlan0' [IF]>
inet addr:192.168.0.4 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:1390 errors:0 dropped:0 overruns:0 frame:0
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:126178 (126.1 KB) TX bytes:14213 (14.2 KB)
##### iwconfig ##########################
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:"NETGEAR61"
Mode:Managed Frequency:2.462 GHz Access Point: <MAC 'NETGEAR61' [AC1]>
Bit Rate=1 Mb/s Tx-Power=16 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-24 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:2 Invalid misc:69 Missed beacon:0
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.0 U 1 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.0 U 9 0 0 wlan0
##### resolv.conf #######################
nameserver 127.0.1.1
##### nm-tool ###########################
NetworkManager Tool
State: connected (global)
- Device: eth0 [Auto Ethernet] ------------------------------------------------
Type: Wired
Driver: alx
State: connected
Default: yes
HW Address: <MAC 'eth0' [IF]>
Capabilities:
Carrier Detect: yes
Speed: 100 Mb/s
Wired Properties
Carrier: on
IPv4 Settings:
Address: 192.168.0.6
Prefix: 24 (255.255.255.0)
Gateway: 192.168.0.1
DNS: 192.168.0.1
- Device: wlan0 [NETGEAR61] ---------------------------------------------------
Type: 802.11 WiFi
Driver: ath9k
State: connected
Default: no
HW Address: <MAC 'wlan0' [IF]>
Capabilities:
Speed: 1 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points (* = current AP)
*NETGEAR61: Infra, <MAC 'NETGEAR61' [AC1]>, Freq 2462 MHz, Rate 54 Mb/s, Strength 97 WPA2
Photon Max 3G Wi-Fi_BD89: Infra, <MAC 'Photon Max 3G Wi-Fi_BD89' [AN2]>, Freq 2437 MHz, Rate 54 Mb/s, Strength 9 WPA2
IPv4 Settings:
Address: 192.168.0.4
DNS: 192.168.0.1
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/NETGEAR61]] (600 root)
[connection] id=NETGEAR61 | type=802-11-wireless
[802-11-wireless] ssid=NETGEAR61 | mac-address=<MAC 'wlan0' [IF]>
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: Asia/Kolkata (based on set time zone)
country CN: DFS-UNSET
(2402 - 2482 @ 40), (N/A, 20)
(5735 - 5835 @ 40), (N/A, 30)
(57240 - 59400 @ 2160), (N/A, 28)
(59400 - 63720 @ 2160), (N/A, 44)
(63720 - 65880 @ 2160), (N/A, 28)
##### iwlist channels ###################
eth0 no frequency information.
lo no frequency information.
wlan0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Current Frequency:2.462 GHz (Channel 11)
##### iwlist scan #######################
Channel occupancy:
1 APs on Frequency:2.417 GHz (Channel 2)
1 APs on Frequency:2.462 GHz (Channel 11)
eth0 Interface doesn't support scanning.
lo Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address: <MAC 'NETGEAR61' [AC1]>
Channel:11
Encryption key:on
ESSID:"NETGEAR61"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000002aac9e0909
Extra: Last beacon: 56ms ago
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
Cell 02 - Address: <MAC '' [AC2]>
Channel:2
Quality=26/70 Signal level=-84 dBm
Encryption key:on
ESSID:""
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
Mode:Master
Extra:tsf=0000001f88233184
Extra: Last beacon: 2268ms ago
Group Cipher : CCMP
##### module infos ######################
[ath9k]
filename: /lib/modules/3.16.0-23-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k.ko
license: Dual BSD/GPL
description: Support for Atheros 802.11n wireless LAN cards.
author: Atheros Communications
srcversion: F1B005F210401E25BEA4125
depends: ath9k_hw,mac80211,ath9k_common,cfg80211,ath
intree: Y
vermagic: 3.16.0-23-generic SMP mod_unload modversions
signer: Magrathea: Glacier signing key
sig_key: D1:20:C4:7C:14:BE:B6:2E:AD:67:03:D4:17:12:CC:11:05:75:D2:97
sig_hashalgo: sha512
parm: debug:Debugging mask (uint)
parm: nohwcrypt:Disable hardware encryption (int)
parm: blink:Enable LED blink on activity (int)
parm: btcoex_enable:Enable wifi-BT coexistence (int)
parm: bt_ant_diversity:Enable WLAN/BT RX antenna diversity (int)
parm: ps_enable:Enable WLAN PowerSave (int)
parm: use_chanctx:Enable channel context for concurrency (int)
[ath9k_common]
filename: /lib/modules/3.16.0-23-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
description: Shared library for Atheros wireless 802.11n LAN cards.
srcversion: 50297023DA06CB0C907A2CA
depends: cfg80211,ath9k_hw,ath
intree: Y
[ath9k_hw]
filename: /lib/modules/3.16.0-23-generic/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
srcversion: 765883F7BDCD751661973EB
depends: ath
intree: Y
[ath]
filename: /lib/modules/3.16.0-23-generic/kernel/drivers/net/wireless/ath/ath.ko
description: Shared library for Atheros wireless LAN cards.
srcversion: 165C1DF76AF8C8B6A45DA4F
depends: cfg80211
intree: Y
[mac80211]
filename: /lib/modules/3.16.0-23-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: 0D5DBE66E4CC44B010DB516
depends: cfg80211
intree: Y
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename: /lib/modules/3.16.0-23-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: DEE8EAA48495E392CD51C2D
depends:
intree: Y
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[ath9k]
blink: 0
bt_ant_diversity: 0
btcoex_enable: 0
nohwcrypt: 1
ps_enable: 0
use_chanctx: 0
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
probe_wait_ms: 500
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/ath9k.conf]
options ath9k nohwcrypt=1
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/modesetting.conf]
options cirrus modeset=1
options mgag200 modeset=1
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x1969:0x10a1 (alx)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x168c:0x0036 (ath9k)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'wlan0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[ 13.299029] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 17.225704] wlan0: authenticate with <MAC 'NETGEAR61' [AC1]>
[ 17.241172] wlan0: send auth to <MAC 'NETGEAR61' [AC1]> (try 1/3)
[ 17.245068] wlan0: authenticated
[ 17.246828] wlan0: associate with <MAC 'NETGEAR61' [AC1]> (try 1/3)
[ 17.253065] wlan0: RX AssocResp from <MAC 'NETGEAR61' [AC1]> (capab=0x431 status=0 aid=3)
[ 17.253112] wlan0: associated
[ 17.253131] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.255059] ath: EEPROM regdomain: 0x809c
[ 17.255060] ath: EEPROM indicates we should expect a country code
[ 17.255061] ath: doing EEPROM country->regdmn map search
[ 17.255062] ath: country maps to regdmn code: 0x52
[ 17.255063] ath: Country alpha2 being used: CN
[ 17.255064] ath: Regpair used: 0x52
[ 17.255065] ath: regdomain 0x809c dynamically updated by country IE
########## wireless info END ############
I have followed almost every solution mentioned here on Ask Ubuntu and other websites, but neither of them seems to work.
Asus support has let me down. When I contacted them :
For your case, that may be caused by lack of driver with it. (driver is not compatible with linux Ubuntu )
For your information, according to the support site: http://support.asus.com.cn/download.aspx?SLanguage=en&p=3&m=G751JM&hashedid=H1PGPvZ0ODsnDxTf
There is only win8.1 version driver for the notebook G751JM
We don't recommend user to use linux Ubuntu OS with G751JM product.
We passed your mail to technology R&D team, let them check and consider to build it in the future.
Sorry for the inconvenience. Thank you very much for your understanding
Thank you for your support Asus product. Wish you have a good day.
How can I have a good day, knowing that the laptop I bought from my own savings is not compatible with my most used OS?
I will truly appreciate it if someone could point me to another solution for this problem. Is purchasing an external wireless network card is the only possible solution?
