I bought a new Laptop (Lenovo Thinkpad E15 Gen 4 21EE) and installed Ubuntu 22.04.1 LTS. The problem is that I can only access the internet via an ethernet cable, as there is no option for WiFi. I already spent hours searching for a solution and installed tons of packages, but I am not really experienced with Ubuntu and hardware/drivers in general and nothing worked. It would be really nice if someone could help me, because I really need the WiFi for my work.
Many thanks in advance,
Paul
Edit 1: The output of lspci -knn | grep Net -A3; rfkill list is
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
Subsystem: Lenovo Device [17aa:4853]
04:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo [1002:15e7] (rev c1)
Subsystem: Lenovo Device [17aa:50b1]
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Edit 2: The question was closed an redirected to a similar question (Network Driver for Realtek 10ec:b852). I executed
sudo apt update
sudo apt install git bc
git clone https://github.com/HRex39/rtl8852be.git
cd rtl8852be
make
sudo make install
sudo modprobe 8852be
and the output was
Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:4 http://security.ubuntu.com/ubuntu jammy-security InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
bc is already the newest version (1.07.1-3build1).
git is already the newest version (1:2.34.1-1ubuntu1.4).
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi i965-va-driver
intel-media-va-driver libaacs0 libaom3 libass9 libavcodec58 libavformat58
libavutil56 libbdplus0 libblas3 libbluray2 libbs2b0 libchromaprint1
libcodec2-1.0 libdav1d5 libflite1 libgme0 libgsm1
libgstreamer-plugins-bad1.0-0 libigdgmm12 liblilv-0-0 libmfx1 libmysofa1
libnorm1 libopenmpt0 libpgm-5.3-0 libpostproc55 librabbitmq4 librubberband2
libserd-0-0 libshine3 libsnappy1v5 libsord-0-0 libsratom-0-0
libsrt1.4-gnutls libssh-gcrypt-4 libswresample3 libswscale5 libudfread0
libva-drm2 libva-wayland2 libva-x11-2 libva2 libvdpau1 libvidstab1.1
libx265-199 libxvidcore4 libzimg2 libzmq5 libzvbi-common libzvbi0
mesa-va-drivers mesa-vdpau-drivers pocketsphinx-en-us va-driver-all
vdpau-driver-all
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Cloning into 'rtl8852be'...
remote: Enumerating objects: 1067, done.
remote: Counting objects: 100% (1067/1067), done.
remote: Compressing objects: 100% (838/838), done.
remote: Total 1067 (delta 271), reused 980 (delta 218), pack-reused 0
Receiving objects: 100% (1067/1067), 4.34 MiB | 2.27 MiB/s, done.
Resolving deltas: 100% (271/271), done.
/bin/sh: 1: cc: not found
(standard_in) 1: syntax error
#rm -f .symvers.8852be
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.15.0-48-generic/build M=/home/paul/rtl8852be modules
make[1]: Entering directory '/usr/src/linux-headers-5.15.0-48-generic'
arch/x86/Makefile:142: CONFIG_X86_X32 enabled but no binutils support
make[1]: gcc: No such file or directory
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0
You are using:
/bin/sh: 1: gcc: not found
CC [M] /home/paul/rtl8852be/platform/platform_linux_pc_pci.o
make[2]: *** [scripts/Makefile.build:297: /home/paul/rtl8852be/platform/platform_linux_pc_pci.o] Error 127
make[1]: *** [Makefile:1884: /home/paul/rtl8852be] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.15.0-48-generic'
make: *** [Makefile:637: modules] Error 2
install -p -m 644 8852be.ko /lib/modules/5.15.0-48-generic/kernel/drivers/net/wireless/
install: cannot stat '8852be.ko': No such file or directory
make: *** [Makefile:646: install] Error 1
modprobe: FATAL: Module 8852be not found in directory /lib/modules/5.15.0-48-generic
It still doesn't work :/
