Kernel: 5.15.0-53-generic x86_64 bits: 64 Desktop: GNOME 42.5 Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
$ sudo lshw -C network
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eno1
       version: 15
       serial: f6:6e:74:95:80:a5
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.15.0-53-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=172.20.6.135 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:31 ioport:f000(size=256) memory:fe904000-fe904fff memory:fe900000-fe903fff
  *-network DISABLED
       description: Wireless interface
       product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 00
       serial: 00:e0:4c:89:28:71
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtw_8821ce driverversion=5.15.0-53-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:67 ioport:e000(size=256) memory:fe800000-fe80ffff
  *-usb:1
       product: USB 2.0 10/100M Ethernet Adaptor
       vendor: ICS Advent
       physical id: 4
       bus info: usb@1:4
       logical name: enx00e04c534458
       version: 1.01
       serial: 00:e0:4c:53:44:58
       capacity: 100Mbit/s
       capabilities: usb-1.10 ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=dm9601 driverversion=5.15.0-53-generic duplex=full firmware=Davicom DM96xx USB 10/100 Ether ip=192.168.10.69 link=yes maxpower=120mA multicast=yes port=MII speed=100Mbit/s
  *-network
       physical id: 4
       bus info: usb@1:3
       logical name: wlxd03745e8e1bb
       serial: d0:37:45:e8:e1:bb
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=r8188eu driverversion=5.15.0-53-generic ip=192.168.31.69 multicast=yes wireless=IEEE 802.11bgn
$ dkms status
# Nothing
$ rfkill list
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
$ cat /etc/modules/interfaces
cat: /etc/modules/interfaces: Not a directory
$ cat /etc/netplan/*.yaml
# Let NetworkManager manage all devices on this system
network:
  version: 2
  renderer: NetworkManager
$ cat /etc/modprobe.d/dkms.conf
# modprobe information used for DKMS modules
# This is a stub file, should be edited when needed,
# used by default by DKMS.
$ ls -al /lib/modules/$(uname -r)/updates/dkms
ls: cannot access '/lib/modules/5.15.0-53-generic/updates/dkms': No such file or directory
$ lsmod | grep 8821
rtw88_8821ce           16384  0
rtw88_8821c            94208  1 rtw88_8821ce
rtw88_pci              32768  1 rtw88_8821ce
rtw88_core            258048  2 rtw88_pci,rtw88_8821c
$ iwconfig
lo        no wireless extensions.
eno1      no wireless extensions.
enx00e04c534458  no wireless extensions.
wlxd03745e8e1bb  IEEE 802.11bgn  ESSID:"MobinNet5-301-1"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:AD:D5:76:B5:5A
          Bit Rate:72.2 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=75/100  Signal level=-48 dBm  Noise level=0 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
wlp3s0    IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
outline-tun0  no wireless extensions.
I had 21.10 and one day Wi-Fi stopped working, after upgrade to 22.04 still not working (I hoped the upgrade would solve the problem).
enter image description here Wireless Info Script Result
Remove unnecessary DKMS modules...
sudo dkms remove mt7612u/1.0 --all
sudo dkms remove rtl8188fu/1.0 --all
dkms status should now show...
virtualbox/6.1.32, 5.13.0-40-generic, x86_64: installed
virtualbox/6.1.32, 5.15.0-27-generic, x86_64: installed
Confirm no unnecessary .ko files...
then reboot.
Select DKMS module below and reboot...
If for some reason you can't select the DKMS driver...
sudo apt update
sudo apt install rtl8821ce-dkms
reboot
Update #1:
WiFi works when booted to a Ubuntu Live USB. Reinstall Ubuntu.
heynnema
  • 73,649
Same issue. After upgrading Ubuntu 20.05 to Ubuntu 22.04, wifi stop working. Removing rtl8821ce-dkms as suggested and deleting rtw88_8821ce from blacklist worked for me. Using HP Pavilion 15-cw1005la.
sudo dkms remove rtl8821ce/5.5.2.1
After this command, rtw88_8821ce is removed automatically from /etc/modprobe.d/dkms.conf. Then
sudo reboot
anonymous2
  • 4,325
Daniel G
  • 41
On my machine this driver required to be self signed which means a password has to be entered MOK at install on linux then entered at reboot in the BIOS so it get accepted by the kernel. I did it and now it works.
The issue occurred after upgrading the BIOS firmware.
emm
Ubuntu 22.4.3. rtl8821ce-dkms did not work. So I removed it.
1.
  • to check
    sudo dkms status
    #rtl8821ce/5.5.2.1: added
  • to remove sudo apt remove rtl8821ce-dkms
    #Deleting module rtl8821ce-5.5.2.1 completely from the DKMS tree.
2.Сomment out lines started with blacklist if they exist. nano /etc/modprobe.d/blacklist.conf
# wifi problem
# instead try install sudo apt-get install dkms build-essential rtl8821ce-dkms
#blacklist 8821ce
#blacklist rtw88
#blacklist rtw88_8821ce
#blacklist rtw88_pci
#blacklist rtw88_core
3.Open software updater => settings=> additional drivers tab
check option don't use the device for Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
4.reboot
