I use Ubuntu 17.10 and the following USB adapter:
lsusb | grep -o 'ASUS.*'
ASUSTek Computer, Inc. N10 Nano 802.11n Network Adapter [Realtek RTL8192CU]
sudo lshw -class network | grep -o '.*rtl.*generic'
configuration: broadcast=yes driver=rtl8192cu driverversion=4.13.0-21-generic
When the computer starts the Internet works fine (excepting the upload and download speeds which are 3 times slower than for another device), but after a while (usually just a few minutes) the Internet goes down and I need to run the following command in order to make it available again (or to wait about more than 5 minutes for auto-reconnect):
sudo /etc/init.d/network-manager restart
I read here:
The wireless Realtek chipsets RTL8188CUS and RTL8192CU should run well on the default RTL8192CU driver (at least since the introduction of the 4.4 kernel series). So they should work fine out of the box. Plug and play, no action needed anymore.
The driver from CD seems deprecated for this kernel version.
Disabling IPv6 from my WiFi setting/for the whole system didn't fix the problem.
Is there a problem with the driver?
Or is there something else that can make it fail after a while?
Edit:
iwconfig
Running iwconfigshows a similar output (all of them show Power Management:off) with 2 differences:
before the first disconnect
Link Quality=52/70 Signal level=-58 dBm Tx excessive retries:0 Invalid misc:3 Missed beacon:0after disconnect
Link Quality=52/70 Signal level=-58 dBm Tx excessive retries:0 Invalid misc:135 Missed beacon:0after a reconnect (restarting the network-manager service)
Link Quality=38/70 Signal level=-72 dBm Tx excessive retries:0 Invalid misc:8 Missed beacon:0
journalctl
# sudo journalctl -fu NetworkManager
dec 25 22:59:50 ... NetworkManager[...]: [...] manager: rfkill: WiFi hardware radio set enabled
dec 25 22:59:50 ... NetworkManager[...]: [...] manager: rfkill: WWAN hardware radio set enabled
The wireless disconnected at about 23:10:00 and after about 5 minutes:
dec 25 23:15:10 ... NetworkManager[...]: [...] connectivity: (wlx...) timed out
dec 25 23:15:26 ... NetworkManager[...]: [...] policy: set '...' (wlx...) as default for IPv6 routing and DNS
dec 25 23:20:10 ... NetworkManager[...]: [...] connectivity: (wlx...) timed out
modprobe.d
Adding the following files/lines didn't fix the problem:
cat /etc/modprobe.d/rtl8192cu.conf
options rtl8192cu fwlps=N
cat /etc/modprobe.d/rtl8xxxu.conf
blackist rtl8xxxu
cat /etc/modprobe.d/blacklist.conf | grep rtl
blacklist rtl8xxxu
blacklist rtl8192c_common
