How to connect to WPA2/PEAP/MSCHAPv2 enterprise wifi networks that don't use a CA_Certificate, like WOW FI - FASTWEB
I tried all the stuff in these links:
https://askubuntu.com/a/1405397/47501/
WPA2 wifi refuses to connect after upgrade to 22.04
https://bugs.launchpad.net/ubuntu/+source/wpa/+bug/1958267
How to connect to WPA2/PEAP/MSCHAPv2 enterprise wifi networks that don't use a CA_Certificate, like Eduroam
wpa_supplicant/OpenSSL connection problems after 22.04 upgrade
My wireless/WiFi connection does not work. What information is needed to diagnose the issue?
but nothing works for me
the only way I found is downgrade to ubuntu 21.10
this made me crazy because now 21.10 is old and no longer update are going to it
with the same computer and 21.10 the WPA2 works
this is the wireless-info file (the essential part, I hope)
########## wireless info START ##########
Report from: 11 Aug 2022 18:26 CEST +0200
Booted last: 11 Aug 2022 00:00 CEST +0200
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu Description: Ubuntu 22.04.1 LTS Release: 22.04 Codename: jammy
kernel
Linux 5.15.0-43-generic #46-Ubuntu SMP Tue Jul 12 10:30:17 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash
desktop
Ubuntu
lspci
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15) Subsystem: Acer Incorporated [ALI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1025:1360] Kernel driver in use: r8169
03:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31) Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [11ad:08a6] Kernel driver in use: ath10k_pci
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 04f2:b5e0 Chicony Electronics Co., Ltd VGA WebCam Bus 001 Device 003: ID 04ca:3015 Lite-On Technology Corp. Qualcomm Atheros QCA9377 Bluetooth Bus 001 Device 002: ID 047d:1022 Kensington Orbit Optical Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: yes Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no
secure boot
SecureBoot enabled
lsmod
ath10k_pci 49152 0 acer_wmi 28672 0 sparse_keymap 16384 1 acer_wmi wmi_bmof 16384 0 ath10k_core 589824 1 ath10k_pci ath 36864 1 ath10k_core mac80211 1228800 1 ath10k_core cfg80211 958464 3 ath,mac80211,ath10k_core libarc4 16384 1 mac80211 wmi 32768 2 acer_wmi,wmi_bmof video 53248 2 acer_wmi,i915
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet <IP address>/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether <MAC 'enp2s0' [IF1]> brd <MAC address> inet <IP address>/24 brd <IP address> scope global dynamic noprefixroute enp2s0 valid_lft 79467sec preferred_lft 79467sec inet6 <HEX>::<HEX>:<HEX>:<HEX>:<HEX>/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 link/ether <MAC 'wlp3s0' [IF2]> brd <MAC address> inet <IP address>/24 brd <IP address>scope global dynamic noprefixroute wlp3s0 valid_lft 83659sec preferred_lft 83659sec inet6 <HEX>::<HEX>:<HEX>:<HEX>:<HEX>/64 scope link noprefixroute valid_lft forever preferred_lft forever
iwconfig
lo no wireless extensions.
enp2s0 no wireless extensions.
wlp3s0 IEEE 802.11 ESSID:"FASTWEB-A56F58" Mode:Managed Frequency:5.54 GHz Access Point: <MAC 'FASTWEB-A56F58' [AC4]> Bit Rate=6 Mb/s Tx-Power=26 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=52/70 Signal level=-58 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:337 Missed beacon:0
route
default via <IP address> dev enp2s0 proto dhcp metric 100 default via <IP address> dev wlp3s0 proto dhcp metric 600 <IP address>/16 dev wlp3s0 scope link metric 1000 <IP address>/24 dev enp2s0 proto kernel scope link src <IP address> metric 100 <IP address>/24 dev wlp3s0 proto kernel scope link src <IP address>metric 600
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/resolvconf/resolv.conf']
nameserver <IP address> search lan
network managers
Installed:
NetworkManager
Running:
root 620 1 0 Aug07 ? 00:01:18 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enp2s0 GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2 GENERAL.VENDOR: Realtek Semiconductor Co., Ltd. GENERAL.PRODUCT: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller GENERAL.DRIVER: r8169 GENERAL.DRIVER-VERSION: 5.15.0-43-generic GENERAL.FIRMWARE-VERSION: -- GENERAL.HWADDR: <MAC 'enp2s0' [IF1]> GENERAL.MTU: 1500 GENERAL.STATE: 100 (connected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 4 (full) GENERAL.IP6-CONNECTIVITY: 3 (limited) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.0/0000:02:00.0/net/enp2s0 GENERAL.PATH: pci-0000:02:00.0 GENERAL.IP-IFACE: enp2s0 GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: Connessione via cavo 1 GENERAL.CON-UUID: <HEX>-<HEX>-<HEX>-<HEX>-<HEX> GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/1 GENERAL.METERED: no (guessed) CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: 1000 Mb/s CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: yes INTERFACE-FLAGS.CARRIER: yes INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: on IP4.ADDRESS[1]: <IP address>/24 IP4.GATEWAY: <IP address> IP4.ROUTE[1]: dst = <IP address>/24, nh = 0.0.0.0, mt = 100 IP4.ROUTE[2]: dst = 0.0.0.0/0, nh = <IP address>, mt = 100 IP4.DNS[1]: <IP address> IP4.DOMAIN[1]: lan DHCP4.OPTION[1]: broadcast_address = <IP address> DHCP4.OPTION[2]: dhcp_lease_time = 86400 DHCP4.OPTION[3]: dhcp_server_identifier = <IP address> DHCP4.OPTION[4]: domain_name = lan DHCP4.OPTION[5]: domain_name_servers = <IP address> DHCP4.OPTION[6]: expiry = 1660314680 DHCP4.OPTION[7]: host_name = my-name DHCP4.OPTION[8]: ip_address = <IP address> DHCP4.OPTION[9]: next_server = <IP address> DHCP4.OPTION[10]: requested_broadcast_address = 1 DHCP4.OPTION[11]: requested_domain_name = 1 DHCP4.OPTION[12]: requested_domain_name_servers = 1 DHCP4.OPTION[13]: requested_domain_search = 1 DHCP4.OPTION[14]: requested_host_name = 1 DHCP4.OPTION[15]: requested_interface_mtu = 1 DHCP4.OPTION[16]: requested_ms_classless_static_routes = 1 DHCP4.OPTION[17]: requested_nis_domain = 1 DHCP4.OPTION[18]: requested_nis_servers = 1 DHCP4.OPTION[19]: requested_ntp_servers = 1 DHCP4.OPTION[20]: requested_rfc3442_classless_static_routes = 1 DHCP4.OPTION[21]: requested_root_path = 1 DHCP4.OPTION[22]: requested_routers = 1 DHCP4.OPTION[23]: requested_static_routes = 1 DHCP4.OPTION[24]: requested_subnet_mask = 1 DHCP4.OPTION[25]: requested_time_offset = 1 DHCP4.OPTION[26]: requested_wpad = 1 DHCP4.OPTION[27]: routers = <IP address> DHCP4.OPTION[28]: subnet_mask = 255.255.255.0 IP6.ADDRESS[1]: <HEX>::<HEX>:<HEX>:<HEX>:<HEX>/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = <HEX>::/64, nh = ::, mt = 1024 IP6.DNS[1]: <HEX>::<HEX>:<HEX>:<HEX>:<HEX> IP6.SEARCHES[1]: lan DHCP6.OPTION[1]: dhcp6_domain_search = lan DHCP6.OPTION[2]: dhcp6_name_servers = <HEX>::<HEX>:<HEX>:<HEX>:<HEX> CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/3 CONNECTIONS.AVAILABLE-CONNECTIONS[1]: <HEX>-<HEX>-<HEX>-<HEX>-<HEX> | Connessione via cavo 1
GENERAL.DEVICE: wlp3s0 GENERAL.TYPE: wifi GENERAL.NM-TYPE: NMDeviceWifi GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/3 GENERAL.VENDOR: Qualcomm Atheros GENERAL.PRODUCT: QCA9377 802.11ac Wireless Network Adapter (Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter) GENERAL.DRIVER: ath10k_pci GENERAL.DRIVER-VERSION: 5.15.0-43-generic GENERAL.FIRMWARE-VERSION: WLAN.TF.2.1-00021-QCARMSWP-1 GENERAL.HWADDR: <MAC 'wlp3s0' [IF2]> GENERAL.MTU: 1500 GENERAL.STATE: 100 (connected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 4 (full) GENERAL.IP6-CONNECTIVITY: 3 (limited) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.1/0000:03:00.0/net/wlp3s0 GENERAL.PATH: pci-0000:03:00.0 GENERAL.IP-IFACE: wlp3s0 GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: FASTWEB-A56F58 GENERAL.CON-UUID: <HEX>-<HEX>-<HEX>-<HEX>-<HEX> GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/18 GENERAL.METERED: no (guessed) CAPABILITIES.CARRIER-DETECT: no CAPABILITIES.SPEED: 6 Mb/s CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: yes INTERFACE-FLAGS.CARRIER: yes INTERFACE-FLAGS.PROMISC: no WIFI-PROPERTIES.WEP: yes WIFI-PROPERTIES.WPA: yes WIFI-PROPERTIES.WPA2: yes WIFI-PROPERTIES.TKIP: yes WIFI-PROPERTIES.CCMP: yes WIFI-PROPERTIES.AP: yes WIFI-PROPERTIES.ADHOC: yes WIFI-PROPERTIES.2GHZ: yes WIFI-PROPERTIES.5GHZ: yes WIFI-PROPERTIES.MESH: yes WIFI-PROPERTIES.IBSS-RSN: yes IP4.ADDRESS[1]: <IP address>/24 IP4.GATEWAY: <IP address> IP4.ROUTE[1]: dst = <IP address>/24, nh = 0.0.0.0, mt = 600 IP4.ROUTE[2]: dst = <IP address>/16, nh = 0.0.0.0, mt = 1000 IP4.ROUTE[3]: dst = 0.0.0.0/0, nh = <IP address>, mt = 600 IP4.DNS[1]: <IP address> IP4.DOMAIN[1]: lan DHCP4.OPTION[1]: broadcast_address = <IP address> DHCP4.OPTION[2]: dhcp_lease_time = 86400 DHCP4.OPTION[3]: dhcp_server_identifier = <IP address> DHCP4.OPTION[4]: domain_name = lan DHCP4.OPTION[5]: domain_name_servers = <IP address> DHCP4.OPTION[6]: expiry = 1660318872 DHCP4.OPTION[7]: host_name = my-name DHCP4.OPTION[8]: ip_address = <IP address> DHCP4.OPTION[9]: next_server = <IP address> DHCP4.OPTION[10]: requested_broadcast_address = 1 DHCP4.OPTION[11]: requested_domain_name = 1 DHCP4.OPTION[12]: requested_domain_name_servers = 1 DHCP4.OPTION[13]: requested_domain_search = 1 DHCP4.OPTION[14]: requested_host_name = 1 DHCP4.OPTION[15]: requested_interface_mtu = 1 DHCP4.OPTION[16]: requested_ms_classless_static_routes = 1 DHCP4.OPTION[17]: requested_nis_domain = 1 DHCP4.OPTION[18]: requested_nis_servers = 1 DHCP4.OPTION[19]: requested_ntp_servers = 1 DHCP4.OPTION[20]: requested_rfc3442_classless_static_routes = 1 DHCP4.OPTION[21]: requested_root_path = 1 DHCP4.OPTION[22]: requested_routers = 1 DHCP4.OPTION[23]: requested_static_routes = 1 DHCP4.OPTION[24]: requested_subnet_mask = 1 DHCP4.OPTION[25]: requested_time_offset = 1 DHCP4.OPTION[26]: requested_wpad = 1 DHCP4.OPTION[27]: routers = <IP address> DHCP4.OPTION[28]: subnet_mask = 255.255.255.0 IP6.ADDRESS[1]: <HEX>::<HEX>:<HEX>:<HEX>:<HEX>/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 1024 IP6.DNS[1]: <HEX>::<HEX>:<HEX>:<HEX>:<HEX> IP6.SEARCHES[1]: lan DHCP6.OPTION[1]: dhcp6_domain_search = lan DHCP6.OPTION[2]: dhcp6_name_servers = <HEX>::<HEX>:<HEX>:<HEX>:<HEX> CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/1 CONNECTIONS.AVAILABLE-CONNECTIONS[1]: <HEX>-<HEX>-<HEX>-<HEX>-<HEX> | FASTWEB-A56F58
GENERAL.DEVICE: p2p-dev-wlp3s0 GENERAL.TYPE: wifi-p2p GENERAL.NM-TYPE: NMDeviceWifiP2P GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/10 GENERAL.VENDOR: -- GENERAL.PRODUCT: -- GENERAL.DRIVER: (unknown) GENERAL.DRIVER-VERSION: -- GENERAL.FIRMWARE-VERSION: -- GENERAL.HWADDR: (unknown) GENERAL.MTU: 0 GENERAL.STATE: 30 (disconnected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 1 (none) GENERAL.IP6-CONNECTIVITY: 1 (none) GENERAL.UDI: /virtual/device/placeholder/8 GENERAL.PATH: -- GENERAL.IP-IFACE: -- GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: -- GENERAL.CON-UUID: -- GENERAL.CON-PATH: -- GENERAL.METERED: unknown CAPABILITIES.CARRIER-DETECT: no CAPABILITIES.SPEED: unknown CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: no INTERFACE-FLAGS.LOWER-UP: no INTERFACE-FLAGS.CARRIER: no INTERFACE-FLAGS.PROMISC: no CONNECTIONS.AVAILABLE-CONNECTION-PATHS: --
SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY ACTIVE IN-USE WOW FI - FASTWEB <MAC 'WOW FI - FASTWEB' [AC2]> Infra 1 2412 MHz 130 Mbit/s 92 ▂▄▆█ WPA2 802.1X no FASTWEB-A56F58 <MAC 'FASTWEB-A56F58' [AC1]> Infra 1 2412 MHz 130 Mbit/s 89 ▂▄▆█ WPA2 no
NetworkManager.state
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=false
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]] [connectivity] uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
[[/etc/NetworkManager/system-connections/FASTWEB-A56F58.nmconnection]] (600 root) [connection] id=FASTWEB-A56F58 | type=wifi | permissions= [wifi] mac-address-blacklist= | ssid=FASTWEB-A56F58 [ipv4] method=auto [ipv6] method=auto
[[/etc/NetworkManager/system-connections/WOW FI - FASTWEB.nmconnection]] (600 root) [connection] id=WOW FI - FASTWEB | type=wifi [wifi] mac-address-blacklist= | ssid=WOW FI - FASTWEB [ipv4] method=auto [ipv6] method=auto
Netplan config
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
iw reg get
Region: Europe/Rome (based on set time zone)
global country DE: DFS-ETSI (2400 - 2483 @ 40), (N/A, 20), (N/A) (5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW (5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW (5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS (5725 - 5875 @ 80), (N/A, 13), (N/A) (5945 - 6425 @ 160), (N/A, 23), (N/A), NO-OUTDOOR (57000 - 66000 @ 2160), (N/A, 40), (N/A)
phy#0 country 99: DFS-UNSET (2402 - 2472 @ 40), (N/A, 20), (N/A) (5140 - 5360 @ 80), (N/A, 30), (N/A), PASSIVE-SCAN (5460 - 5860 @ 80), (N/A, 30), (N/A), PASSIVE-SCAN
iwlist channels
lo no frequency information.
enp2s0 no frequency information.
wlp3s0 32 channels in total; available frequencies : Channel 01 : 2.412 GHz Channel 02 : 2.417 GHz Channel ... Current Frequency:5.54 GHz (Channel 108)
iwlist scan
lo Interface doesn't support scanning.
enp2s0 Interface doesn't support scanning.
Channel occupancy:
  3   APs on   Frequency:2.412 GHz (Channel 1)
  3   APs on   Frequency:2.417 GHz (Channel 2)
  7   APs on   Frequency:2.437 GHz (Channel 6)
  1   APs on   Frequency:2.442 GHz (Channel 7)
  1   APs on   Frequency:2.457 GHz (Channel 10)
  2   APs on   Frequency:2.462 GHz (Channel 11)
  1   APs on   Frequency:5.26 GHz (Channel 52)
  3   APs on   Frequency:5.54 GHz (Channel 108)
  2   APs on   Frequency:5.56 GHz (Channel 112)
  2   APs on   Frequency:5.5 GHz (Channel 100)
wlp3s0 Scan completed : Cell 01 - Address: <MAC 'FASTWEB-A56F58' [AC1]> Channel:1 Frequency:2.412 GHz (Channel 1) Quality=60/70 Signal level=-50 dBm Encryption key:on ESSID:"FASTWEB-A56F58" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s 24 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000157cbb08ed0 Extra: Last beacon: 6600ms ago IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Cell 02 - Address: <MAC 'WOW FI - FASTWEB' [AC2]> Channel:1 Frequency:2.412 GHz (Channel 1) Quality=62/70 Signal level=-48 dBm Encryption key:on ESSID:"WOW FI - FASTWEB" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s 24 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000157cbb09d93 Extra: Last beacon: 6596ms ago IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : 802.1x
module infos
[ath10k_pci] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko license: Dual BSD/GPL description: Driver support for Qualcomm Atheros 802.11ac WLAN PCIe/AHB devices depends: ath10k_core retpoline: Y intree: Y name: ath10k_pci vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: irq_mode:0: auto, 1: legacy, 2: msi (default: 0) (uint) parm: reset_mode:0: auto, 1: warm only (default: 0) (uint)
[ath10k_core] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko license: Dual BSD/GPL description: Core module for Qualcomm Atheros 802.11ac wireless LAN cards. depends: mac80211,cfg80211,ath retpoline: Y intree: Y name: ath10k_core vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: debug_mask:Debugging mask (uint) parm: uart_print:Uart target debugging (bool) parm: skip_otp:Skip otp failure for calibration in testmode (bool) parm: cryptmode:Crypto mode: 0-hardware, 1-software (uint) parm: rawmode:Use raw 802.11 frame datapath (bool) parm: coredump_mask:Bitfield of what to include in firmware crash file (ulong) parm: fw_diag_log:Diag based fw log debugging (bool)
[ath] filename: /lib/modules/5.15.0-43-generic/kernel/drivers/net/wireless/ath/ath.ko license: Dual BSD/GPL description: Shared library for Atheros wireless LAN cards. depends: cfg80211 retpoline: Y intree: Y name: ath vermagic: 5.15.0-43-generic SMP mod_unload modversions
[mac80211] filename: /lib/modules/5.15.0-43-generic/kernel/net/mac80211/mac80211.ko license: GPL description: IEEE 802.11 subsystem depends: cfg80211,libarc4 retpoline: Y intree: Y name: mac80211 vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool) parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int) parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int) parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int) parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int) parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211] filename: /lib/modules/5.15.0-43-generic/kernel/net/wireless/cfg80211.ko description: wireless configuration support license: GPL depends: retpoline: Y intree: Y name: cfg80211 vermagic: 5.15.0-43-generic SMP mod_unload modversions parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int) parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp) parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
module parameters
[ath10k_pci] irq_mode: 0 reset_mode: 0
[ath10k_core] coredump_mask: 3 cryptmode: 0 debug_mask: 0 fw_diag_log: N rawmode: N skip_otp: N uart_print: N
[mac80211] beacon_loss_count: 7 ieee80211_default_rc_algo: minstrel_ht max_nullfunc_tries: 2 max_probe_tries: 5 minstrel_vht_only: Y probe_wait_ms: 500
[cfg80211] bss_entries_limit: 1000 cfg80211_disable_40mhz_24ghz: N ieee80211_regdom: 00
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[362684.531791] wlp3s0: authenticate with <MAC 'FASTWEB-A56F58' [AC4]> [362684.560439] wlp3s0: send auth to <MAC 'FASTWEB-A56F58' [AC4]> (try 1/3) [362684.561136] wlp3s0: authenticated [362684.567644] wlp3s0: associate with <MAC 'FASTWEB-A56F58' [AC4]> (try 1/3) [362684.569488] wlp3s0: RX AssocResp from <MAC 'FASTWEB-A56F58' [AC4]> (capab=0x1011 status=0 aid=1) [362684.572120] wlp3s0: associated [362684.572261] ath: EEPROM regdomain: 0x8114 [362684.572263] ath: EEPROM indicates we should expect a country code [362684.572265] ath: doing EEPROM country->regdmn map search [362684.572266] ath: country maps to regdmn code: 0x37 [362684.572267] ath: Country alpha2 being used: DE [362684.572268] ath: Regpair used: 0x37 [362684.572269] ath: regdomain 0x8114 dynamically updated by country element [362684.606547] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by <MAC 'FASTWEB-A56F58' [AC4]> [362684.639813] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready ########## wireless info END ############
but WPA2 still not works
Emilio
  • 2,111
