Problem
I recently tried dual booting my HP Spectre x360 Convertible 15-eb0xxx machine with Windows 11 and Ubuntu 23.04. Unfortunately, the Ubuntu system is never able to connect to the internet via it's wifi card. Wifi works as expected when running Windows 11.
Windows 11 device manager reports my wifi card is an Intel Ax201 160MhZ device.
I have obtained the following diagnostic information:
dmesg
[    2.352442] iwlwifi: unknown parameter 'd0i3_disable' ignored
[    2.352445] iwlwifi: unknown parameter 'lar_disable' ignored
[    2.354883] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.368115] iwlwifi 0000:00:14.3: Can find a correct rfid for crf id 0x617
[    2.368163] iwlwifi: probe of 0000:00:14.3 failed with error -22
sudo lshw -C network
-network UNCLAIMED
description: Network controller product: Comet Lake PCH CNVi WiFi vendor: Intel Corporation physical id: 14.3 bus info: pci@0000:00:14.3 version: 00 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix cap_list configuration: latency=0 resources: iomemory:600-5ff memory:606311c000-606311ffff
-network description: Ethernet interface physical id: 15 bus info: usb@1:1 logical name: enxa0cec8645734 serial: a0:ce:c8:64:57:34 size: 100Mbit/s capacity: 100Mbit/s capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=full ip=192.168.1.46 link=yes multicast=yes port=MII speed=100Mbit/s
uname -r
6.2.0-26-generic
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 06cb:00c9 Synaptics, Inc.
Bus 001 Device 003: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 001 Device 006: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter
rfkill list all
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
lspci
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:13.0 Serial controller: Intel Corporation Device 06fc
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:14.3 Network controller: Intel Corporation Comet Lake PCH CNVi WiFi
00:15.0 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.1 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:1b.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #17 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device 06b7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
38:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6d:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5405
6e:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
I have tried:
  • The following dual boot permutations:
    • Ubuntu 18.04 + Windows 10
    • Ubuntu 18.04 + Windows 11
    • Ubuntu 20.04 + Windows 11
    • Ubuntu 22.04 + Windows 11
    • Ubuntu 22.04 + Windows 10
    • Ubuntu 23.o4 + Windows 10
Across all permutations
  • wifi always works on windows.
  • wifi never works on Ubuntu
  • Bluetooth* occasionally / intermittently* works on Ubuntu.
Note: Between each attempted fix, Ubuntu 23.04 was reinstalled to unpersist and changes made.
Wireless Script Output
########## wireless info START ##########
Report from: -
Booted last: -
Script from: -
release
Distributor ID: Ubuntu Description: Ubuntu 23.04 Release: 23.04 Codename: lunar
kernel
Linux 6.2.0-26-generic #26-Ubuntu SMP PREEMPT_DYNAMIC Mon Jul 10 23:39:54 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, pcie_aspm=force, vt.handoff=7
desktop
Ubuntu
lspci
00:14.3 Network controller [0280]: Intel Corporation Comet Lake PCH CNVi WiFi [8086:06f0] Subsystem: Intel Corporation Comet Lake PCH CNVi WiFi [8086:0000] Kernel modules: iwlwifi
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 06cb:00c9 Synaptics, Inc. Bus 001 Device 004: ID 8087:0026 Intel Corp. AX201 Bluetooth Bus 001 Device 002: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: no Hard blocked: no
secure boot
SecureBoot disabled
lsmod
hp_wmi 24576 0 platform_profile 16384 1 hp_wmi intel_wmi_thunderbolt 20480 0 wmi_bmof 16384 0 mxm_wmi 16384 0 iwlwifi_compat 16384 0 sparse_keymap 16384 2 hp_wmi,intel_hid wmi 40960 5 hp_wmi,video,intel_wmi_thunderbolt,wmi_bmof,mxm_wmi
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: enx<IF from MAC [IF1]>: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether <MAC 'enx<IF from MAC [IF1]>' [IF1]> brd <MAC address> inet 192.168.1.46/24 brd 192.168.1.255 scope global dynamic noprefixroute enx<IF from MAC [IF1]> valid_lft 86261sec preferred_lft 86261sec inet6 2404:4404:2a05:6500:e6c7:405c:2b2a:3be5/64 scope global temporary dynamic valid_lft 463sec preferred_lft 463sec inet6 2404:4404:2a05:6500:9654:cb46:8e32:6a4c/64 scope global dynamic mngtmpaddr noprefixroute valid_lft 463sec preferred_lft 463sec inet6 fe80::909:f8fe:5b19:e95/64 scope link noprefixroute valid_lft forever preferred_lft forever
iwconfig
lo no wireless extensions.
enx<IF from MAC [IF1]> no wireless extensions.
route
default via 192.168.1.1 dev enx<IF from MAC [IF1]> proto dhcp src 192.168.1.46 metric 100 169.254.0.0/16 dev enx<IF from MAC [IF1]> scope link metric 1000 192.168.1.0/24 dev enx<IF from MAC [IF1]> proto kernel scope link src 192.168.1.46 metric 100
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53 options edns0 trust-ad search .
network managers
Installed:
NetworkManager
Running:
root 895 1 0 11:44 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
GENERAL.DEVICE: enx<IF from MAC [IF1]> GENERAL.TYPE: ethernet GENERAL.NM-TYPE: NMDeviceEthernet GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/Devices/2 GENERAL.VENDOR: Realtek Semiconductor Corp. GENERAL.PRODUCT: RTL8152 Fast Ethernet Adapter GENERAL.DRIVER: r8152 GENERAL.DRIVER-VERSION: v1.12.13 GENERAL.FIRMWARE-VERSION: -- GENERAL.HWADDR: <MAC 'enx<IF from MAC [IF1]>' [IF1]> GENERAL.MTU: 1500 GENERAL.STATE: 100 (connected) GENERAL.REASON: 0 (No reason given) GENERAL.IP4-CONNECTIVITY: 4 (full) GENERAL.IP6-CONNECTIVITY: 4 (full) GENERAL.UDI: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/net/enx<IF from MAC [IF1]> GENERAL.PATH: pci-0000:00:14.0-usb-0:1:1.0 GENERAL.IP-IFACE: enx<IF from MAC [IF1]> GENERAL.IS-SOFTWARE: no GENERAL.NM-MANAGED: yes GENERAL.AUTOCONNECT: yes GENERAL.FIRMWARE-MISSING: no GENERAL.NM-PLUGIN-MISSING: no GENERAL.PHYS-PORT-ID: -- GENERAL.CONNECTION: Wired connection 1 GENERAL.CON-UUID: fe10c681-3252-36c4-a1c9-4f3a0302b388 GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/3 GENERAL.METERED: no (guessed) CAPABILITIES.CARRIER-DETECT: yes CAPABILITIES.SPEED: 100 Mb/s CAPABILITIES.IS-SOFTWARE: no CAPABILITIES.SRIOV: no INTERFACE-FLAGS.UP: yes INTERFACE-FLAGS.LOWER-UP: yes INTERFACE-FLAGS.CARRIER: yes INTERFACE-FLAGS.PROMISC: no WIRED-PROPERTIES.CARRIER: on IP4.ADDRESS[1]: 192.168.1.46/24 IP4.GATEWAY: 192.168.1.1 IP4.ROUTE[1]: dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 100 IP4.ROUTE[2]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000 IP4.ROUTE[3]: dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 100 IP4.DNS[1]: 192.168.1.1 DHCP4.OPTION[1]: dhcp_client_identifier = 01:<MAC 'enx<IF from MAC [IF1]>' [IF1]> DHCP4.OPTION[2]: dhcp_lease_time = 86400 DHCP4.OPTION[3]: dhcp_server_identifier = 192.168.1.1 DHCP4.OPTION[4]: domain_name_servers = 192.168.1.1 DHCP4.OPTION[5]: expiry = 1691717581 DHCP4.OPTION[6]: ip_address = 192.168.1.46 DHCP4.OPTION[7]: requested_broadcast_address = 1 DHCP4.OPTION[8]: requested_domain_name = 1 DHCP4.OPTION[9]: requested_domain_name_servers = 1 DHCP4.OPTION[10]: requested_domain_search = 1 DHCP4.OPTION[11]: requested_host_name = 1 DHCP4.OPTION[12]: requested_interface_mtu = 1 DHCP4.OPTION[13]: requested_ms_classless_static_routes = 1 DHCP4.OPTION[14]: requested_nis_domain = 1 DHCP4.OPTION[15]: requested_nis_servers = 1 DHCP4.OPTION[16]: requested_ntp_servers = 1 DHCP4.OPTION[17]: requested_rfc3442_classless_static_routes = 1 DHCP4.OPTION[18]: requested_root_path = 1 DHCP4.OPTION[19]: requested_routers = 1 DHCP4.OPTION[20]: requested_static_routes = 1 DHCP4.OPTION[21]: requested_subnet_mask = 1 DHCP4.OPTION[22]: requested_time_offset = 1 DHCP4.OPTION[23]: requested_wpad = 1 DHCP4.OPTION[24]: routers = 192.168.1.1 DHCP4.OPTION[25]: subnet_mask = 255.255.255.0 IP6.ADDRESS[1]: 2404:4404:2a05:6500:e6c7:405c:2b2a:3be5/64 IP6.ADDRESS[2]: 2404:4404:2a05:6500:9654:cb46:8e32:6a4c/64 IP6.ADDRESS[3]: fe80::909:f8fe:5b19:e95/64 IP6.GATEWAY: fe80::9ec9:ebff:fe24:cc12 IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 1024 IP6.ROUTE[2]: dst = 2404:4404:2a05:6500::/64, nh = ::, mt = 100 IP6.ROUTE[3]: dst = ::/0, nh = fe80::9ec9:ebff:fe24:cc12, mt = 100 IP6.DNS[1]: fe80::9ac9:ebff:fe24:cc12 DHCP6.OPTION[1]: dhcp6_client_id = 00:04:47:4c:de:bd:34:80:1b:f7:86:ef:3d:20:dd:03:56:2a DHCP6.OPTION[2]: dhcp6_name_servers = fe80::9ac9:ebff:fe24:cc12 DHCP6.OPTION[3]: iaid = f2:b2:1f:c2 CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/2 CONNECTIONS.AVAILABLE-CONNECTIONS[1]: fe10c681-3252-36c4-a1c9-4f3a0302b388 | Wired connection 1
NetworkManager.state
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]] [connectivity] uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
Netplan config
[/etc/netplan/00-installer-config.yaml] network: version: 2
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
iw reg get
'iw' is not installed (package "iw").
iwlist channels
lo no frequency information.
enx<IF from MAC [IF1]> no frequency information.
iwlist scan
lo Interface doesn't support scanning.
enx<IF from MAC [IF1]> Interface doesn't support scanning.
module infos
[iwlwifi_compat] filename: /lib/modules/6.2.0-26-generic/updates/dkms/iwlwifi-compat.ko license: GPL description: Kernel backport module depends:
retpoline: Y name: iwlwifi_compat vermagic: 6.2.0-26-generic SMP preempt mod_unload modversions parm: backported_kernel_name:The kernel tree name that was used for this backport (iwlwifi) (charp) parm: backports_tracker_id:The version of the tree containing this backport (iwlwifi-stack-public:master:9904:0e80336f) (charp)
module parameters
grep: /sys/module/iwlwifi_compat/parameters/backported_kernel_name: Permission denied grep: /sys/module/iwlwifi_compat/parameters/backports_tracker_id: Permission denied [iwlwifi_compat]
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwl.conf] options iwlwifi 11n_disable=1 swcrypto=0 bt_coex_active=0 power_save=0 options iwlmvm power_scheme=1 options iwlwifi d0i3_disable=1 options iwlwifi uapsd_disable=1 options iwlwifi lar_disable=1
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
[ 4.787935] r8152 1-1:1.0 enx<IF from MAC [IF1]>: carrier on (repeated 2 times) [ 6503.122088] IPv6: ADDRCONF(NETDEV_CHANGE): enx<IF from MAC [IF1]>: link becomes ready [ 6503.122411] r8152 1-1:1.0 enx<IF from MAC [IF1]>: carrier on
########## wireless info END ############
None of my attempted fixes seem to have any effect whatsoever. Am stumbling around in the dark here - would appreciate any suggestions :)
student.a
Long stort short, I bought one of these:
https://www.tp-link.com/us/home-networking/usb-adapter/tl-wn725n/
Would still really like to know the software fix, though.
student.a
