Today I tried installing Linux for the first time, and I can't get the Wi-Fi working. The Wi-Fi is built into the laptop, not a dongle.
  • Firstly, how do I know that Ubuntu is even seeing the card? ip link sho | grep w gives me a result. Will the result be the Wi-Fi card and not something else like the USB Ethernet dongle?
    • Based on the output, the card is down. Nothing seems to enable it. e.g. sudo ifconfig <name> up makes no difference
    • sudo rfkil shows this interface is unblocked, both soft and hard
    • trying the command:wpa_passphrase MYSSID passphrase > /etc/wpa_supplicant.conf results in permission denied, even if I try using sudo
Can someone please suggest what I should try next - or possibly try in the correct sequence.
Edited to add more information: This is the walkthrough that I found yesterday before coming here for help:
Martin Thornton gave me the correct syntax to get the wpa_passphrase working. When I run iwlist scan, which is the next step in the walkthrough, it tells me the network is down.
The documentation linked below starts off with "Open the system menu" I don't think I have a menu?
Running lspci tells me the wireless card is an:
Intel Wireless 7260 (8086:08b1) rev 6b
sudo lshw -C network told me the wireless interface was disabled after running sudo ip link set wlp6s0 up, it seems the card is up. But iwlist scan still returns no scan results
Fabby
  • 35,017
kamuzz
  • 103
