I am trying to ask a question about getting my hardware to work but I don't know what information to add to my question to get help, what do I need to do?
Related if you don't have access to a GUI:
The most important information you can give is what you've done, what you expected to happen, and what you observe has happened.
This question is a particularly fine example of a hardware-detection problem with a USB device.
Other examples of this could be:
I installed Ubuntu 10.04 Desktop on my Dell Optiwhatever 312 laptop. When I log in, my wireless card isn't visible in the Network Manager popup menu, although the wired network shows up there.
or
I have Ubuntu 10.04 Netbook edition on my System76 laptop. When I plug my headphones into the socket, the sound comes out the headphones but also out the speakers.
or
I'm using Ubuntu 10.04. I used the “Additional Drivers” program to install the current nVidia drivers for my GeForce FX 5200. Now when I boot the system stops with a black screen after the Ubuntu boot splash is finished.
After this general problem description, what other information is interesting depends on what sort of hardware you're having problems with, and what problems you're having.
In general:
sudo lspci -nn will list all the PCI devices in your system. This will include all the expansion cards (Video cards, WiFi, etc) in your system, whether or not the kernel has a driver for them. This information is useful if you're not sure precisely what hardware you have.lsusb will list all the USB devices connected to your system. Again, this is useful if you're not sure precisely what hardware you have. It's also useful to check that the device is actually plugged in correctly!/var/log/udev and /var/log/dmesg will have information about what devices the kernel has detected. These logs are generally very big - unless you know what parts of the log are interesting it's not a good idea to include these in your question, although a link to them could be useful (you can use http://paste.ubuntu.com for large logs)sudo lshw --class X pr sudo lshw -C X can also give a bit of valuable hardware info on the specifed class X - examples classes include cdrom, communication, core, cpu, display, isa, medium, memory, multimedia, network, pci, scsi, serial, storage and usb - so for instance you can use sudo lshw -C network to show info on the network cards the computer can detect.For Video problems:
/var/log/Xorg.0.log is the X server log file. This is useful for all video problems. This file can get long so feel free to just put it on http://paste.ubuntu.com. Be sure to give a link to your "paste" so we can find it when we need to.LIBGL_DEBUG=verbose glxinfo will display information about 3D acceleration support, useful for problems with 3D or desktop effects.lspci -nn | grep VGA will list all the video cards in your system, useful if you are not sure what type of video card you have./usr/lib/nux/unity_support_test -p should be used for compiz and other Unity compatability issues.For Audio problems:
cat /proc/asound/cards will list the audio devices that have been detected. You should include this.cat /proc/asound/card0/codec#0 will contain information about the first sound card, including information about the input/output ports connected to it. If you have a problem with plugging in a microphone, headsets, or external speakers, include this. You may also have more than one sound device. In that case, there will be more than one /proc/asound/card??? directory.Note: If you have a wired connection consider running the all in one wireless script outlined in this answer, it does all the heavy lifting for you!
Wireless connectivity issues are fortunately becoming rarer with each Ubuntu release. However problems still occur.
The following information will help diagnose wireless connectivity issues in questions posted on Ask Ubuntu, you can open a terminal by hitting Ctrl-Alt-T and typing in one of these commands, then edit your question to add the information.
sudo lshw -class network
lsusb
This can give a long list depending upon how many USB devices are connected. If in doubt, post the entire list.
lspci
This can give a long list depending upon how many PCI devices are fitted. If in doubt, post the entire list.
rfkill list all
Often you can see useful errors by looking at your kernel logs.
If you attempt to connect via network manager you can see what errors are produced by looking at dmesg
Suggested procedure - type dmesg, then attempt to connect and then type dmesg again. The new output displayed should give an indication as to the error.
Another useful output is dmesg | grep -i firmware - if you see some errors in the output then this can indicate you need to install some firmware - usually a package from the repository.
Searching on Google will sometimes bring results suggesting using NDISWrapper. This is an old technique where obtaining a Windows XP driver can be made to work in Ubuntu.
Generally, this should be avoided in current versions of Ubuntu since the drivers in the kernel have less compatibility issues.
If you have any wireless issues post the results of the four command-line entries above into your question BEFORE trying NDISWrapper.
See https://wiki.ubuntu.com/DebuggingHardwareDetection
https://wiki.ubuntu.com/DebuggingProcedures is usually a good starting point if you want to know what information is useful for a bug report.
These might be helpful (depending on the type of hardware):
dmesg
lspci
lsusb
The following logs will contain details about hardware as it was seen by various system services (kernel, udev, etc) at boot time:
/var/log/udev
/var/log/dmesg
One of the most useful things you can do when describing a hardware issue, is describe what you did, what is connection you are using.
For example:
"I plugged in a monitor and my desktop did not automatically extend on to it."
This kind of information may seem very simple, but it can help to pin point where common problems come from, or if you question may be off topic.
A general problem-solving hint
I've noticed that I often collect data to diagnose a problem by:
First, identifying the problem - what did I do, what did I expect to happen, and what seemed to happen? Can I repeat the problem?
Then, causing the problem to happen, and listing the system's logs in reverse order of modification time:
ls -lrt /var/log,
tail -n 25 on recently modified log files (for reasonable values of 25), and
dmesg.
Read, wonder, think, guess, test, repeat as needed
