-1
I installed ubuntu Os 22.04 LST on my notebook. I have no wifi drivers. I see an error:
No Wi-Fi adapter found
I was reading similar questions and tried command
lspci -knn | grep -iA3 net
Network Controller [0280] Device [0b48:7922] ... Unassigned class [ff00]: Realtek Semiconducter Co., LTD RTS525A PCI Express Card Reader ...
What driver should I install?
My laptop model RedmiBook Pro 15 Ryzen Edition Laptop: AMD Ryzen 7 7840HS
UPDATE
Tried command (moved binary file to my PC with help of usb)
wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info && chmod +x wireless-info && ./wireless-info
Result
########## wireless info START ##########
Report from: 29 Apr 2024 21:56 MSK +0300
Booted last: 29 Apr 2024 00:00 MSK +0300
Script from: 25 Jan 2020 03:34 UTC +0000
release
Distributor ID: Ubuntu Description: Ubuntu 22.04.3 LTS Release: 22.04 Codename: jammy
kernel
Linux 6.2.0-26-generic #26~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Jul 13 16:27:29 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
desktop
sed: can't read /root/.dmrc: No such file or directory
Could not be determined.
lspci
pcilib: Error reading /sys/bus/pci/devices/0000:00:08.3/label: Operation not permitted
01:00.0 Network controller [0280]: Device [0b48:7922] Subsystem: Device [0b48:7922]
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader [10ec:525a] (rev 01)
lsusb
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 002: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 005: ID 2109:8817 VIA Labs, Inc. USB Billboard Device
Bus 005 Device 003: ID 8564:1000 Transcend Information, Inc. JetFlash Bus 005 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 002: ID 2b7e:c687 SunplusIT Inc XiaoMi USB 2.0 Webcam Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 35f5:7922 MediaTek Inc. Wireless_Device Bus 001 Device 002: ID 10a5:9201 FPC FPC Sensor Controller L:0001 FW:021.26.2.045 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCMCIA card info
rfkill
0: hci0: Bluetooth Soft blocked: no Hard blocked: no
secure boot
SecureBoot enabled
lsmod
wmi_bmof 16384 0 wmi 40960 2 video,wmi_bmof
interfaces
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback <MAC address> brd <MAC address> inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever
iwconfig
lo no wireless extensions.
route
resolv.conf
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53 options edns0 trust-ad search .
network managers
Installed:
NetworkManager
Running:
root 629 1 0 21:46 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
NetworkManager info
NetworkManager.state
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]] [connection] wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]] [main] plugins=ifupdown,keyfile [ifupdown] managed=false [device] wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]] [main] dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]] [keyfile] unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]] [connectivity] uri=http://connectivity-check.ubuntu.com./
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]] [device-31-mac-addr-change] match-device=driver:eagle_sdio,driver:wl wifi.scan-rand-mac-address=no
NetworkManager profiles
Netplan config
[/etc/netplan/01-network-manager-all.yaml] network: version: 2 renderer: NetworkManager
iw reg get
'iw' is not installed (package "iw").
iwlist channels
lo no frequency information.
iwlist scan
lo Interface doesn't support scanning.
module infos
module parameters
/etc/modules
modprobe options
[/etc/modprobe.d/amd64-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf] blacklist ath_pci
[/etc/modprobe.d/blacklist.conf] blacklist evbug blacklist usbmouse blacklist usbkbd blacklist eepro100 blacklist de4x5 blacklist eth1394 blacklist snd_intel8x0m blacklist snd_aw2 blacklist prism54 blacklist bcm43xx blacklist garmin_gps blacklist asus_acpi blacklist snd_pcsp blacklist pcspkr blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf] alias net-pf-3 off alias net-pf-6 off alias net-pf-9 off alias net-pf-11 off alias net-pf-12 off alias net-pf-19 off alias net-pf-21 off alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf] blacklist microcode
[/etc/modprobe.d/iwlwifi.conf] remove iwlwifi
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod)
&& /sbin/modprobe -r mac80211
rc.local
grep: /etc/rc.local: No such file or directory
pm-utils
udev rules
dmesg
########## wireless info END ############
UPDATE 2: Was trying command from this answer - Ubuntu 22.10 MT7622 wireless device doesn't work
But it didn't help
Create a new file named /etc/modprobe.d/mt7921e.conf and use this for its contents
alias pci:v00000b48d00007922xsv*sd*bc*sc*i* mt7921e
Then make file /etc/udev/rules.d/99-mt7921e.rules and add this
SUBSYSTEM=="drivers", DEVPATH=="/bus/pci/drivers/mt7921e", ATTR{new_id}="0b48 7922"
Save and exit then run sudo depmod -a Reboot and see if it works
Jeremy31
  • 13,293
