17
I have recently installed Ubuntu 18.04 in my hp 15bs 145tu laptop. All packages of Ubuntu seem to be working properly but the WiFi adapter is not found, and I can't connect to the wireless network.
How can I debug/fix this?
Zanna
  • 72,312
Dev
  • 191
First, try to connect with the wired Internet connection (or you can use Mobile Tethering) and use the following commands to install missing Wi-Fi drivers.
Clone the repository (use your Terminal):
git clone https://github.com/lwfinger/rtlwifi_new.git
Enter the cloned folder:
cd rtlwifi_new
Check out the extended branch:
git checkout extended
Start installation:
sudo make install
sudo modprobe -r rtl8723de
sudo modprobe rtl8723de
That's it! You have now successfully installed the RTL8723de Wi-Fi driver on your Ubuntu 18.04 system. This repo also contains the driver for RTL8723be and much more RealTek devices.
If that doesn't work just go and do this:
sudo apt purge bcmwl-kernel-source
sudo sed -i '/blacklist bcma/ d' /etc/modprobe.d/blacklist.conf
sudo sed -i '/blacklist brcmsmac/ d' /etc/modprobe.d/blacklist.conf
Reboot. If wifi does not come on, do:
sudo modprobe -v brcmsmac
sudo modprobe -v bcma
Eliah Kagan
  • 119,640
varshneydevansh
  • 778
  • 14
