My Jetson embedded device has a WLAN SMA-RP Antenna supported by a network controller (Intel AX210) as specified by the manufacturer.
The network controller shown using the command lspci is Network controller: Intel Corporation Device 2725 (rev 1a). Seems like lsusb can also identify this interface as 8087:0032 Intel Corp.
I do not see a wlan or similar interface in my network interfaces using ifconfig (I only see lan1, lan2, lo, rndiso0, usb0). The network manager is not able to find any Wi-Fi device: sudo nmcli device wifi rescan returns: Error: No Wi-Fi device found. Trying to connect to any Wi-Fi network produces the same output, and sudo nmcli device wifi list and sudo modprobe iwlwifi both return nothing.
Executing sudo dmesg | grep iwlwifi seems like it detects the Wi-Fi modem:
[   13.228585] iwlwifi 0007:01:00.0: Adding to iommu group 10
[   13.237621] iwlwifi 0007:01:00.0: enabling device (0000 -> 0002)
[   13.317243] iwlwifi 0007:01:00.0: api flags index 2 larger than supported by driver
[   13.341919] iwlwifi 0007:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[   13.360719] iwlwifi 0007:01:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[   13.635397] iwlwifi 0007:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   13.816492] iwlwifi 0007:01:00.0: loaded PNVM version 0x5a8dfca
[   14.076043] iwlwifi 0007:01:00.0: Timeout waiting for PNVM load!
[   14.082239] iwlwifi 0007:01:00.0: Failed to start RT ucode: -110
[   14.088439] iwlwifi 0007:01:00.0: iwl_trans_send_cmd bad state = 0
[   14.107445] iwlwifi 0007:01:00.0: Failed to run INIT ucode: -110
[   14.125909] iwlwifi 0007:01:00.0: retry init count 0
[   14.143089] iwlwifi 0007:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   14.568037] iwlwifi 0007:01:00.0: Timeout waiting for PNVM load!
[   14.574611] iwlwifi 0007:01:00.0: Failed to start RT ucode: -110
[   14.580791] iwlwifi 0007:01:00.0: iwl_trans_send_cmd bad state = 0
[   14.599730] iwlwifi 0007:01:00.0: Failed to run INIT ucode: -110
[   14.618158] iwlwifi 0007:01:00.0: retry init count 1
[   14.635356] iwlwifi 0007:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   15.060048] iwlwifi 0007:01:00.0: Timeout waiting for PNVM load!
[   15.069672] iwlwifi 0007:01:00.0: Failed to start RT ucode: -110
[   15.080880] iwlwifi 0007:01:00.0: iwl_trans_send_cmd bad state = 0
[   15.103163] iwlwifi 0007:01:00.0: Failed to run INIT ucode: -110
[   15.141228] iwlwifi 0007:01:00.0: retry init count 2
From the desktop GUI I am getting a "No Wi-Fi adapter found, make sure you have a Wi-Fi adapter plugged and turned on" in the Wi-Fi settings.
Is there some manual configuration I have to do to set up my Wi-Fi interface?
JorKar
  • 41
It seems to work when I remove my wifi kernel driver (iwlwifi) .pnvm file (see Is there any permanent fix for no wifi with iwlwifi other than removing the .pnvm file?). Converting it to a backup file did the trick:
sudo mv /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.bck
You might then need to reboot your system or reload the drivers with depmod -a.
JorKar
  • 41
It seems that you do not have the latest firmware packages. With a working internet connection by ethernet, tethering or whatever means possible, do:
cd /lib/firmware
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-ty-a0-gf-a0.pnvm
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-ty-a0-gf-a0-72.ucode
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-ty-a0-gf-a0-66.ucode
Reboot and let us see a new version of sudo dmesg | grep iwl.
chili555
  • 61,330
