Yesterday morning, two laptops I'm currently using wouldn't connect to a wifi network anymore. One is my Eee PC 1015T on Xubuntu 14.10; the other one is an old Acer laptop on which I've recently (five days before) installed Ubuntu 14.10. Both laptops have an Atheros AR9285 wireless adapter. Both have the same issue, with apparently the same symptoms: the network indicator blinks for a while, then displays a "Disconnected" tooltip, then tries again to connect some time later, etc. I've tried several wifi networks, with and without authentication methods: no one would work. Ethernet seems to work fine.
I've checked my update history in Software Center, and there were no significant updates made on any of the two computers. Here are two wireless-info.txt, one generated on the Acer laptop, the other on my Eee PC, both using the script provided here.
hellpe
  • 73
This may help you:
Bent
  • 981
Change the wifi router settings to eliminate TKIP, you want to have WPA2-AES which will show up in iwlist scan and WPA2 Version 1 with Group Cipher: CCMP and Pairwise Cipher: CCMP
Data rate will not go higher than 11g speed with TKIP, and linux usually has problems when it is enabled
Jeremy31
  • 13,293
