sudo lshw -C network
Output is:
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 15
serial: a8:1e:84:79:39:fd
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.24 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:125 ioport:d000(size=256) memory:d1204000-d1204fff memory:d1200000-d1203fff
*-network
description: Network controller
product: Qualcomm Atheros
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:03:00.0
version: 31
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=ath10k_pci latency=0
resources: irq:129 memory:d1000000-d11fffff
After trying steps from a thread about an Acer laptop with the exception that the last step was done as such:
sudo mv /home/******/ath10k-firmware/QCA9377/hw1.0/WLAN.TF.1.0/firmware-5.bin_WLAN.TF.1.0-00002-QCATFSWPZ-5 firmware-5.bin
because the file wasn't found in the suggested directory.
After rebooting the network applet doesn't even show the enable wi-fi option.
Output for lspci -nnk | grep -iA2 net; dmesg | grep ath10k
is now:
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [17aa:3801]
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Network controller [0280]: Qualcomm Atheros Device [168c:0042] (rev 31)
Subsystem: Lenovo Device [17aa:0901]
Kernel driver in use: ath10k_pci
[ 11.949464] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 12.253657] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:03:00.0.bin failed with error -2
[ 12.253663] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[ 12.279938] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
[ 12.279939] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 12.280398] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.1.0-00002-QCATFSWPZ-5 api 5 features ignore-otp crc32 c3e0d04f
[ 12.386902] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 14.625738] ath10k_pci 0000:03:00.0: firmware crashed! (uuid 091d6fa4-c2ab-4000-9e0f-30a8dfe1c931)
[ 14.625743] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
[ 14.625744] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 14.626202] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.1.0-00002-QCATFSWPZ-5 api 5 features ignore-otp crc32 c3e0d04f
[ 14.626378] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 14.626379] ath10k_pci 0000:03:00.0: htt-ver 0.0 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 14.628376] ath10k_pci 0000:03:00.0: firmware register dump:
[ 14.628378] ath10k_pci 0000:03:00.0: [00]: 0x05020001 0x00000000 0x00A0F774 0x00000000
[ 14.628379] ath10k_pci 0000:03:00.0: [04]: 0x00A0F774 0x00060130 0x00000010 0xFFFFE000
[ 14.628380] ath10k_pci 0000:03:00.0: [08]: 0x0042136C 0x00420660 0x00400000 0x00400000
[ 14.628382] ath10k_pci 0000:03:00.0: [12]: 0x00000000 0x00000000 0x00952CD0 0x00952CE6
[ 14.628383] ath10k_pci 0000:03:00.0: [16]: 0x00000002 0x01010101 0x00000003 0x0000000A
[ 14.628384] ath10k_pci 0000:03:00.0: [20]: 0x00000328 0x00429880 0x009A37AC 0x00000032
[ 14.628385] ath10k_pci 0000:03:00.0: [24]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[ 14.628386] ath10k_pci 0000:03:00.0: [28]: 0x00401F64 0x00401F68 0x00000000 0x00417550
[ 14.628387] ath10k_pci 0000:03:00.0: [32]: 0x00401FC0 0xF0E30058 0x0040C98E 0x00000003
[ 14.628388] ath10k_pci 0000:03:00.0: [36]: 0x800A0907 0x00000001 0x0000085B 0x339011B2
[ 14.628389] ath10k_pci 0000:03:00.0: [40]: 0x0000FFFE 0x0000000A 0x009BFE28 0x009BE0DC
[ 14.628390] ath10k_pci 0000:03:00.0: [44]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[ 14.628391] ath10k_pci 0000:03:00.0: [48]: 0x00400000 0x00400000 0x00000001 0xFFFFFFFF
[ 14.628392] ath10k_pci 0000:03:00.0: [52]: 0x800A0614 0x0040EAA8 0x0041FA10 0x00420170
[ 14.628393] ath10k_pci 0000:03:00.0: [56]: 0x00400000 0x00421370 0x00419980 0x004212E8
[ 15.621818] ath10k_pci 0000:03:00.0: failed to receive control response completion, polling..
[ 16.649566] ath10k_pci 0000:03:00.0: ctl_resp never came in (-110)
[ 16.649569] ath10k_pci 0000:03:00.0: failed to connect to HTC: -110
[ 16.650748] ath10k_pci 0000:03:00.0: could not init core (-110)
[ 16.650773] ath10k_pci 0000:03:00.0: could not probe fw (-110)
[ 16.661570] ath10k_pci 0000:03:00.0: cannot restart a device that hasn't been started
********:~$ sudo dpkg -s linux-firmware | grep Version
Output is:
Version: 1.157.11
I done wi fi diagnostic and
`########## wireless info START ##########
Report from: 20 Mar 2018 16:48 CET +0100
Booted last: 20 Mar 2018 00:00 CET +0100
Script from: 10 Jan 2018 20:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 16.04.4 LTS
Release: 16.04
Codename: xenial
##### kernel ############################
Linux 4.10.0-28-generic #32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
##### lsusb #############################
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 174f:2410 Syntek
Bus 001 Device 005: ID 0cf3:e500 Atheros Communications, Inc.
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
Bus 001 Device 002: ID 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120
##### PCMCIA card info ##################
##### rfkill ############################
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: yes
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: yes
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
##### lsmod #############################
ath10k_pci 45056 0
ath10k_core 344064 1 ath10k_pci
ath 28672 1 ath10k_core
mac80211 782336 1 ath10k_core
cfg80211 602112 3 mac80211,ath,ath10k_core
ideapad_laptop 24576 0
sparse_keymap 16384 1 ideapad_laptop
wmi 16384 1 ideapad_laptop
video 40960 2 i915,ideapad_laptop
##### interfaces ########################
[/etc/network/interfaces]
auto lo
iface lo inet loopback
##### ifconfig ##########################
enp2s0 Link encap:Ethernet HWaddr <MAC 'enp2s0' [IF1]>
inet addr:192.168.1.24 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fdd4:6e5c:c4a3:3700:5cf8:78d5:f239:bad7/64 Scope:Global
inet6 addr: fe80::a818:b4d5:2a88:6758/64 Scope:Link
inet6 addr: fdd4:6e5c:c4a3:3700:cd5f:2404:8225:d1bc/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:145668 errors:0 dropped:0 overruns:0 frame:0
TX packets:117720 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:193618799 (193.6 MB) TX bytes:10599449 (10.5 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2692 errors:0 dropped:0 overruns:0 frame:0
TX packets:2692 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:390739 (390.7 KB) TX bytes:390739 (390.7 KB)
wlp3s0 Link encap:Ethernet HWaddr <MAC 'wlp3s0' [IF2]>
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
##### iwconfig ##########################
lo no wireless extensions.
enp2s0 no wireless extensions.
wlp3s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 100 0 0 enp2s0
192.168.1.0 0.0.0.0 255.255.255.0 U 100 0 0 enp2s0
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
NetworkManager
Running:
root 879 1 0 16:18 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE: enp2s0
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.VENDOR: Realtek Semiconductor Co., Ltd.
GENERAL.PRODUCT: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
GENERAL.DRIVER: r8169
GENERAL.DRIVER-VERSION: 2.3LK-NAPI
GENERAL.FIRMWARE-VERSION:
GENERAL.HWADDR: <MAC 'enp2s0' [IF1]>
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0/net/enp2s0
GENERAL.IP-IFACE: enp2s0
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: Wired connection 1
GENERAL.CON-UUID: 1d7d882c-86f4-35fb-8ad8-87a98e87b596
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/0
GENERAL.METERED: no (guessed)
CAPABILITIES.CARRIER-DETECT: yes
CAPABILITIES.SPEED: 100 Mb/s
CAPABILITIES.IS-SOFTWARE: no
WIRED-PROPERTIES.CARRIER: on
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{1}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 1d7d882c-86f4-35fb-8ad8-87a98e87b596 | Wired connection 1
IP4.ADDRESS[1]: 192.168.1.24/24
IP4.GATEWAY: 192.168.1.1
IP4.DNS[1]: 192.168.1.1
DHCP4.OPTION[1]: requested_routers = 1
DHCP4.OPTION[2]: requested_domain_search = 1
DHCP4.OPTION[3]: requested_time_offset = 1
DHCP4.OPTION[4]: requested_domain_name = 1
DHCP4.OPTION[5]: requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[6]: requested_broadcast_address = 1
DHCP4.OPTION[7]: requested_wpad = 1
DHCP4.OPTION[8]: requested_netbios_scope = 1
DHCP4.OPTION[9]: next_server = 0.0.0.0
DHCP4.OPTION[10]: expiry = 1521645497
DHCP4.OPTION[11]: requested_interface_mtu = 1
DHCP4.OPTION[12]: requested_subnet_mask = 1
DHCP4.OPTION[13]: dhcp_lease_time = 86400
DHCP4.OPTION[14]: dhcp_message_type = 5
DHCP4.OPTION[15]: ip_address = 192.168.1.24
DHCP4.OPTION[16]: requested_static_routes = 1
DHCP4.OPTION[17]: requested_domain_name_servers = 1
DHCP4.OPTION[18]: dhcp_renewal_time = 43200
DHCP4.OPTION[19]: routers = 192.168.1.1
DHCP4.OPTION[20]: broadcast_address = 192.168.1.255
DHCP4.OPTION[21]: domain_name_servers = 192.168.1.1 192.168.1.1
DHCP4.OPTION[22]: requested_ntp_servers = 1
DHCP4.OPTION[23]: requested_netbios_name_servers = 1
DHCP4.OPTION[24]: dhcp_rebinding_time = 75600
DHCP4.OPTION[25]: requested_ms_classless_static_routes = 1
DHCP4.OPTION[26]: subnet_mask = 255.255.255.0
DHCP4.OPTION[27]: network_number = 192.168.1.0
DHCP4.OPTION[28]: requested_host_name = 1
DHCP4.OPTION[29]: dhcp_server_identifier = 192.168.1.1
IP6.ADDRESS[1]: fdd4:6e5c:c4a3:3700:5cf8:78d5:f239:bad7/64
IP6.ADDRESS[2]: fdd4:6e5c:c4a3:3700:cd5f:2404:8225:d1bc/64
IP6.ADDRESS[3]: fe80::a818:b4d5:2a88:6758/64
IP6.GATEWAY:
GENERAL.DEVICE: wlp3s0
GENERAL.TYPE: wifi
GENERAL.NM-TYPE: NMDeviceWifi
GENERAL.VENDOR: Qualcomm Atheros
GENERAL.PRODUCT: Sunrise Point-LP PCI Express Root Port
GENERAL.DRIVER: ath10k_pci
GENERAL.DRIVER-VERSION: 4.10.0-28-generic
GENERAL.FIRMWARE-VERSION: WLAN.TF.1.0-00267-1
GENERAL.HWADDR: <MAC 'wlp3s0' [IF2]>
GENERAL.MTU: 1500
GENERAL.STATE: 20 (unavailable)
GENERAL.REASON: 2 (Device is now managed)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.5/0000:03:00.0/net/wlp3s0
GENERAL.IP-IFACE:
GENERAL.CONNECTION: --
GENERAL.CON-UUID: --
GENERAL.CON-PATH: --
GENERAL.METERED: unknown
CAPABILITIES.CARRIER-DETECT: no
CAPABILITIES.SPEED: unknown
WIFI-PROPERTIES.WEP: yes
WIFI-PROPERTIES.WPA: yes
WIFI-PROPERTIES.WPA2: yes
WIFI-PROPERTIES.TKIP: yes
WIFI-PROPERTIES.CCMP: yes
WIFI-PROPERTIES.AP: yes
WIFI-PROPERTIES.ADHOC: yes
WIFI-PROPERTIES.2GHZ: yes
WIFI-PROPERTIES.5GHZ: yes
SSID BSSID MODE CHAN FREQ RATE SIGNAL BARS SECURITY ACTIVE *
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/saska]] (600 root)
[connection] id=saska | type=wifi | permissions=
[wifi] mac-address=<MAC 'wlp3s0' [IF2]> | mac-address-blacklist= | ssid=HG532e-C4A337
[ipv4] method=shared
[ipv6] method=ignore
##### Netplan config ####################
##### iw reg get ########################
Region: Europe/Belgrade (based on set time zone)
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 40), (N/A, 20), (N/A), NO-IR
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
(5170 - 5250 @ 80), (N/A, 20), (N/A), NO-IR
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, NO-IR
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
(5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
lo no frequency information.
enp2s0 no frequency information.
wlp3s0 32 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 36 : 5.18 GHz
Channel 40 : 5.2 GHz
Channel 44 : 5.22 GHz
Channel 48 : 5.24 GHz
Channel 52 : 5.26 GHz
Channel 56 : 5.28 GHz
Channel 60 : 5.3 GHz
Channel 64 : 5.32 GHz
Channel 100 : 5.5 GHz
Channel 104 : 5.52 GHz
Channel 108 : 5.54 GHz
Channel 112 : 5.56 GHz
Channel 116 : 5.58 GHz
Channel 120 : 5.6 GHz
Channel 124 : 5.62 GHz
Channel 128 : 5.64 GHz
Channel 132 : 5.66 GHz
Channel 136 : 5.68 GHz
Channel 140 : 5.7 GHz
##### iwlist scan #######################
lo Interface doesn't support scanning.
enp2s0 Interface doesn't support scanning.
wlp3s0 Interface doesn't support scanning : Network is down
##### module infos ######################
[ath10k_pci]
filename: /lib/modules/4.10.0-28-generic/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
firmware: ath10k/QCA9377/hw1.0/board.bin
firmware: ath10k/QCA9377/hw1.0/firmware-5.bin
firmware: ath10k/QCA6174/hw3.0/board-2.bin
firmware: ath10k/QCA6174/hw3.0/board.bin
firmware: ath10k/QCA6174/hw3.0/firmware-5.bin
firmware: ath10k/QCA6174/hw3.0/firmware-4.bin
firmware: ath10k/QCA6174/hw2.1/board-2.bin
firmware: ath10k/QCA6174/hw2.1/board.bin
firmware: ath10k/QCA6174/hw2.1/firmware-5.bin
firmware: ath10k/QCA6174/hw2.1/firmware-4.bin
firmware: ath10k/QCA9887/hw1.0/board-2.bin
firmware: ath10k/QCA9887/hw1.0/board.bin
firmware: ath10k/QCA9887/hw1.0/firmware-5.bin
firmware: ath10k/QCA988X/hw2.0/board-2.bin
firmware: ath10k/QCA988X/hw2.0/board.bin
firmware: ath10k/QCA988X/hw2.0/firmware-5.bin
firmware: ath10k/QCA988X/hw2.0/firmware-4.bin
firmware: ath10k/QCA988X/hw2.0/firmware-3.bin
firmware: ath10k/QCA988X/hw2.0/firmware-2.bin
license: Dual BSD/GPL
description: Driver support for Qualcomm Atheros 802.11ac WLAN PCIe/AHB devices
author: Qualcomm Atheros
srcversion: 50E531406EF702B9976A8A9
depends: ath10k_core
intree: Y
vermagic: 4.10.0-28-generic SMP mod_unload
parm: irq_mode:0: auto, 1: legacy, 2: msi (default: 0) (uint)
parm: reset_mode:0: auto, 1: warm only (default: 0) (uint)
[ath10k_core]
filename: /lib/modules/4.10.0-28-generic/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko
description: Core module for Qualcomm Atheros 802.11ac wireless LAN cards.
srcversion: 1B2C9C18ACF805C04DCA414
depends: mac80211,cfg80211,ath
intree: Y
parm: debug_mask:Debugging mask (uint)
parm: uart_print:Uart target debugging (bool)
parm: skip_otp:Skip otp failure for calibration in testmode (bool)
parm: cryptmode:Crypto mode: 0-hardware, 1-software (uint)
parm: rawmode:Use raw 802.11 frame datapath (bool)
[ath]
filename: /lib/modules/4.10.0-28-generic/kernel/drivers/net/wireless/ath/ath.ko
description: Shared library for Atheros wireless LAN cards.
author: Atheros Communications
srcversion: 4B8612B6FF71DD27AE8CE67
depends: cfg80211
intree: Y
[mac80211]
filename: /lib/modules/4.10.0-28-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: 309C9ACED540FCAA1DE7422
depends: cfg80211
intree: Y
parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool)
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename: /lib/modules/4.10.0-28-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: D77C8F93375950F3BA95B16
depends:
intree: Y
parm: bss_entries_limit:limit to number of scan BSS entries (per wiphy, default 1000) (int)
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[ath10k_pci]
irq_mode: 0
reset_mode: 0
[ath10k_core]
cryptmode: 0
debug_mask: 0
rawmode: N
skip_otp: N
uart_print: N
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
minstrel_vht_only: Y
probe_wait_ms: 500
[cfg80211]
bss_entries_limit: 1000
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
ethtool -s autoneg off speed 100
exit 0
##### pm-utils ##########################
[/etc/pm/sleep.d/10_grub-common.dpkg-new] (755 root)
case "$1" in
thaw)
[ -s /boot/grub/grubenv ] || rm -f /boot/grub/grubenv
mkdir -p /boot/grub
grub-editenv /boot/grub/grubenv unset recordfail
esac
##### udev rules ########################
##### dmesg #############################
[ 12.850432] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:03:00.0.bin failed with error -2
[ 12.850441] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[ 12.941609] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
[ 12.941612] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 12.941973] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.1.0-00267-1 api 5 features ignore-otp crc32 79cea2c7
[ 13.024589] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 14.836034] ath10k_pci 0000:03:00.0: htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 14.842855] ath: EEPROM regdomain: 0x6c
[ 14.842856] ath: EEPROM indicates we should expect a direct regpair map
[ 14.842857] ath: Country alpha2 being used: 00
[ 14.842857] ath: Regpair used: 0x6c
[ 15.065762] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[ 17.082425] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 17.085017] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 17.142427] r8169 0000:02:00.0 enp2s0: link down (repeated 2 times)
[ 17.142506] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 19.580246] r8169 0000:02:00.0 enp2s0: link up
[ 19.580252] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
########## wireless info END ############`
