I got a laptop (HP Smart Buy 255 G7). It shipped with Windows 10. The wifi works in Windows. I wanted to install Ubuntu, but wanted to test that everything works with a live USB first (18.04 LTS).
Other components look good (camera and mic and I'm connected using a wired connection). However, I would like to know that the wifi will work once I install. It looks like a driver issue.
Running sudo lshw -C network gives:
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 15
       serial: 04:0e:3c:02:40:0b
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.86.33 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:32 ioport:3000(size=256) memory:f0b04000-f0b04fff memory:f0b00000-f0b03fff
  *-network UNCLAIMED
       description: Network controller
       product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:2000(size=256) memory:f0a00000-f0a0ffff
I ran the script found here and it gave this:
########## wireless info START ##########
Report from: 14 Nov 2019 17:50 UTC +0000
Booted last: 14 Nov 2019 00:00 UTC +0000
Script from: 22 Oct 2018 03:34 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.3 LTS
Release:    18.04
Codename:   bionic
##### kernel ############################
Linux 5.0.0-23-generic #24~18.04.1-Ubuntu SMP Mon Jul 29 16:12:28 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Parameters: file=/cdrom/preseed/ubuntu.seed, boot=casper, quiet, splash, ---
##### desktop ###########################
Ubuntu
##### lspci #############################
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
    Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:84ac]
    Kernel driver in use: r8169
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
    Subsystem: Hewlett-Packard Company RTL8821CE 802.11ac PCIe Wireless Network Adapter [103c:831a]
##### lsusb #############################
Bus 001 Device 003: ID 0bda:b00a Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 0781:5530 SanDisk Corp. Cruzer
Bus 002 Device 002: ID 04f2:b67f Chicony Electronics Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
##### secure boot #######################
SecureBoot enabled
##### lsmod #############################
wmi_bmof               16384  0
hp_wmi                 16384  0
sparse_keymap          16384  1 hp_wmi
wmi                    28672  2 hp_wmi,wmi_bmof
##### interfaces ########################
[/etc/network/interfaces]
auto lo
iface lo inet loopback
##### ifconfig ##########################
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback <MAC address> brd <MAC address>
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether <MAC 'enp2s0' [IF1]> brd <MAC address>
    inet 192.168.86.33/24 brd 192.168.86.255 scope global dynamic noprefixroute enp2s0
       valid_lft 85981sec preferred_lft 85981sec
    inet6 fe80::72c4:13e0:88fa:e958/64 scope link noprefixroute
##### iwconfig ##########################
lo        no wireless extensions.
enp2s0    no wireless extensions.
##### route #############################
default via 192.168.86.1 dev enp2s0 proto dhcp metric 100
169.254.0.0/16 dev enp2s0 scope link metric 1000
192.168.86.0/24 dev enp2s0 proto kernel scope link src 192.168.86.33 metric 100
##### resolv.conf #######################
[777 root '/etc/resolv.conf' -> '../run/systemd/resolve/stub-resolv.conf']
nameserver 127.0.0.53
options edns0
search lan
##### network managers ##################
Installed:
    NetworkManager
Running:
root      1229     1  0 17:30 ?        00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE:                         enp2s0
GENERAL.TYPE:                           ethernet
GENERAL.NM-TYPE:                        NMDeviceEthernet
GENERAL.VENDOR:                         Realtek Semiconductor Co., Ltd.
GENERAL.PRODUCT:                        RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
GENERAL.DRIVER:                         r8169
GENERAL.DRIVER-VERSION:                 --
GENERAL.FIRMWARE-VERSION:               --
GENERAL.HWADDR:                         <MAC 'enp2s0' [IF1]>
GENERAL.MTU:                            1500
GENERAL.STATE:                          100 (connected)
GENERAL.REASON:                         0 (No reason given)
GENERAL.UDI:                            /sys/devices/pci0000:00/0000:00:02.2/0000:02:00.0/net/enp2s0
GENERAL.IP-IFACE:                       enp2s0
GENERAL.IS-SOFTWARE:                    no
GENERAL.NM-MANAGED:                     yes
GENERAL.AUTOCONNECT:                    yes
GENERAL.FIRMWARE-MISSING:               no
GENERAL.NM-PLUGIN-MISSING:              no
GENERAL.PHYS-PORT-ID:                   --
GENERAL.CONNECTION:                     Wired connection 1
GENERAL.CON-UUID:                       0b1bcefe-1ae9-3e4d-bb76-0d5c66aaf18e
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/4
GENERAL.METERED:                        no (guessed)
CAPABILITIES.CARRIER-DETECT:            yes
CAPABILITIES.SPEED:                     100 Mb/s
CAPABILITIES.IS-SOFTWARE:               no
CAPABILITIES.SRIOV:                     no
WIRED-PROPERTIES.CARRIER:               on
IP4.ADDRESS[1]:                         192.168.86.33/24
IP4.GATEWAY:                            192.168.86.1
IP4.ROUTE[1]:                           dst = 0.0.0.0/0, nh = 192.168.86.1, mt = 100
IP4.ROUTE[2]:                           dst = 192.168.86.0/24, nh = 0.0.0.0, mt = 100
IP4.ROUTE[3]:                           dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]:                             192.168.86.1
IP4.DOMAIN[1]:                          lan
DHCP4.OPTION[1]:                        requested_subnet_mask = 1
DHCP4.OPTION[2]:                        requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[3]:                        subnet_mask = 255.255.255.0
DHCP4.OPTION[4]:                        domain_name_servers = 192.168.86.1
DHCP4.OPTION[5]:                        ip_address = 192.168.86.33
DHCP4.OPTION[6]:                        requested_static_routes = 1
DHCP4.OPTION[7]:                        dhcp_server_identifier = 192.168.86.1
DHCP4.OPTION[8]:                        requested_time_offset = 1
DHCP4.OPTION[9]:                        broadcast_address = 192.168.86.255
DHCP4.OPTION[10]:                       dhcp_rebinding_time = 75600
DHCP4.OPTION[11]:                       requested_interface_mtu = 1
DHCP4.OPTION[12]:                       requested_domain_name_servers = 1
DHCP4.OPTION[13]:                       dhcp_message_type = 5
DHCP4.OPTION[14]:                       requested_broadcast_address = 1
DHCP4.OPTION[15]:                       dhcp_renewal_time = 43200
DHCP4.OPTION[16]:                       routers = 192.168.86.1
DHCP4.OPTION[17]:                       requested_domain_name = 1
DHCP4.OPTION[18]:                       domain_name = lan
DHCP4.OPTION[19]:                       requested_routers = 1
DHCP4.OPTION[20]:                       expiry = 1573839793
DHCP4.OPTION[21]:                       host_name = ubuntu
DHCP4.OPTION[22]:                       requested_netbios_scope = 1
DHCP4.OPTION[23]:                       requested_wpad = 1
DHCP4.OPTION[24]:                       requested_ms_classless_static_routes = 1
DHCP4.OPTION[25]:                       requested_netbios_name_servers = 1
DHCP4.OPTION[26]:                       network_number = 192.168.86.0
DHCP4.OPTION[27]:                       requested_domain_search = 1
DHCP4.OPTION[28]:                       next_server = 192.168.86.1
DHCP4.OPTION[29]:                       requested_ntp_servers = 1
DHCP4.OPTION[30]:                       dhcp_lease_time = 86400
DHCP4.OPTION[31]:                       requested_host_name = 1
IP6.ADDRESS[1]:                         fe80::72c4:13e0:88fa:e958/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = ff00::/8, nh = ::, mt = 256, table=255
IP6.ROUTE[2]:                           dst = fe80::/64, nh = ::, mt = 256
IP6.ROUTE[3]:                           dst = fe80::/64, nh = ::, mt = 100
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{1}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]:   0b1bcefe-1ae9-3e4d-bb76-0d5c66aaf18e | Wired connection 1
##### NetworkManager.state ##############
cat: /var/lib/NetworkManager/NetworkManager.state: No such file or directory
##### NetworkManager config #############
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 3
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:wwan
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]]
[connectivity]
uri=http://connectivity-check.ubuntu.com/
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-mac-addr-change-wifi]
match-device=driver:rtl8723bs,driver:rtl8189es,driver:r8188eu,driver:8188eu,driver:eagle_sdio,driver:wl
wifi.cloned-mac-address=preserve
ethernet.cloned-mac-address=preserve
##### NetworkManager profiles ###########
##### Netplan config ####################
[/etc/netplan/01-network-manager-all.yaml]
network:
  version: 2
  renderer: NetworkManager
##### iw reg get ########################
Region: Etc/UTC (based on set time zone)
global
country 00: DFS-UNSET
    (2402 - 2472 @ 40), (6, 20), (N/A)
    (2457 - 2482 @ 20), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
    (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
    (5170 - 5250 @ 80), (6, 20), (N/A), AUTO-BW, PASSIVE-SCAN
    (5250 - 5330 @ 80), (6, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
    (5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
    (5735 - 5835 @ 80), (6, 20), (N/A), PASSIVE-SCAN
    (57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
lo        no frequency information.
enp2s0    no frequency information.
##### iwlist scan #######################
lo        Interface doesn't support scanning.
enp2s0    Interface doesn't support scanning.
##### module infos ######################
##### module parameters #################
##### /etc/modules ######################
##### modprobe options ##################
[/etc/modprobe.d/amd64-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
##### rc.local ##########################
grep: /etc/rc.local: No such file or directory
##### pm-utils ##########################
##### udev rules ########################
##### dmesg #############################
[  716.992702] r8169 0000:02:00.0 enp2s0: Link is Down
[  729.026607] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full - flow control rx/tx
[  735.584110] r8169 0000:02:00.0 enp2s0: Link is Down
[  747.512628] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full - flow control rx/tx
[  756.113363] r8169 0000:02:00.0 enp2s0: Link is Down
[  768.157714] r8169 0000:02:00.0 enp2s0: Link is Up - 100Mbps/Full - flow control rx/tx
########## wireless info END ############
Questions:
  1. Can I test that this will work with the live USB?
  2. Should I bother, or just install and fix once it's installed?
Kulfy
  • 18,154
Dr Xorile
  • 113
