I have TP-Link USB Wifi adapter which I use on Ubuntu 20.04. The problem is that it's very slow so I'm trying to install this: https://github.com/Mange/rtl8192eu-linux-driver
Although I followed the steps I still don't see rt68192eu in sudo lshw -c network
milano@milano-desktop:~$ sudo lshw -c network;
[sudo] password for milano:
*-network
description: Ethernet interface
product: Ethernet Connection (7) I219-V
vendor: Intel Corporation
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: eno1
version: 10
serial: 70:85:c2:7c:b8:ff
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.5-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:125 memory:a3300000-a331ffff
*-network
description: Wireless interface
physical id: 1
bus info: usb@1:5
logical name: wlx9848276ea01e
serial: 98:48:27:6e:a0:1e
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl88XXau ip=192.168.100.7 multicast=yes wireless=IEEE 802.11AC
Please, can you help me? I also tried to manually edit /etc/modprobe.d/blacklist.conf adding:
blacklist rtl8xxxu
blacklist rtl88XXau
But the output is still the same (after reboot).
EDIT
wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info && chmod +x wireless-info && ./wireless-info
returns this:
https://gist.github.com/futilestudio/513b81ca890cb8058179c2055498dc81
