I have a wireless dongle that seems to be installed correctly, but no wireless adapter appears in my network manager and I can't debug the issue.
I've ran wireless-info from: My wireless/WiFi connection does not work. What information is needed to diagnose the issue? and my wireless-info.txt is: https://pastebin.com/nddpF5S9
Any suggestions?
sinjax
We have seen many rtl8192cu cases where two drivers load and conflict. Let's blacklist one and see if it helps; if not, we'll try the other.
From the terminal:
sudo -i
echo "blacklist rtl8192cu"  >  /etc/modprobe.d/blacklist-rtl8192cu.conf
exit
Reboot. Any improvement?
If not, we'll reverse it:
sudo -i
rm /etc/modprobe.d/blacklist-rtl8192cu.conf
echo "blacklist rtl8xxxu"  >  /etc/modprobe.d/blacklist-rtl8xxxu.conf
exit
Reboot.
Depending on your results, we'll further refine this answer.
chili555
  • 61,330
In then end I upgraded to 18.04 on this machine and the dongle worked. Not the most satisfying result but hopefully it saves someone time.
sinjax
