So I was having connection problems in linux only and then found this: https://chirath02.wordpress.com/2016/05/12/installing-realtek-rtl8723be-driver-for-ubuntu-16-04/
After finding this I have found many answers on this website containing similar info so I thought this would be a good place to ask but anyway...followed those instructions all the way through to the point where it says "If you are not able to see your wifi networks, follow the steps below" but if anything when I got to that point the wifi was even worse than before so i mentioned it to the author and he just said to continue all of the steps so stupidly I did and now I get no wifi connection at all although I can see access points but even when I boot into windows I cant even get a wifi connection there! Although I can see access points in windows aswell...
Basically I just need to undo this and reset if at all possible? If I were to download and re-install the drivers in windows would this fix the issue? If there is a terminal issue that can be solved in Linux I am open to that as well...
I am using ubuntu 16.04
Thanks!
Matt
UPDATE:
I also asked this question over at the Ubuntu Forums and I'm not entirely sure how but I think we have come to a solution. Please see: http://ubuntuforums.org/showthread.php?t=2327345&page=2&p=13503637#post13503637
The last answer was submitted an hour or so ago and the wifi seems to be working fine on my laptop but I get the feeling that as soon as I reboot it is going to give me hassle again...
First I would
cd rtlwifi_new-rock.new_btcoex
sudo make uninstall
as the hanipouspilot ppa already includes that code.
Use this list here to look up your country code and set it with
sudo iw reg set IN
Replace IN with the code you got from the link, you must use capital letters. You should also edit another file with
gksudo gedit /etc/default/crda
The last line will contain REGDOMAIN= add your country code after the = If you are in India it would be REGDOMAIN=IN Save and exit gedit
Reboot
The ant_sel parameter has only been needed in newer HP laptops
Jeremy31
  • 13,293
