I think it is solved: I loaded the prior kernel version in GRUB, and now WiFi works fine.
I was checking emails in 18.04.3 LTS on my Dell Vostro 5481-7273 laptop and noticed a strange symbol I've never seen before, near the WiFi symbol.
I clicked on it to find "location services" are turned off. I went to settings, found "location services" there are 'in use'. Then I saw web pages didn't load.
I turned the WiFi off, turned it back on, and it didn't find any WiFi network. I rebooted the laptop, and found the "location services" icon disappeared; It's off per the settings. No WiFi adapter was found.
I tried WiFi adapter not found in Ubuntu 18.04 and Unable to get wifi adapter working - clean 19.04 install - network unclaimed
I don't know what else should I post that may help....
sudo lshw -C network:
*-network
   description: Network controller
   product: Intel Corporation
   vendor: Intel Corporation
   physical id: 14.3
   bus info: pci@0000:00:14.3
   version: 30
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list
   configuration: driver=iwlwifi latency=0
   resources: irq:16 memory:a131c000-a131ffff
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:01:00.0
   logical name: enp1s0
   version: 15
   serial: e4:54:e8:0b:ee:1d
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical
   configuration: broadcast=yes driver=r8169 latency=0 multicast=yes
   resources: irq:16 ioport:3000(size=256) memory:a1204000-a1204fff memory:a1200000-a1203fff
*-network
   physical id: 2
   logical name: enp0s20f0u1
   serial: 1a:e9:9f:94:ab:ee
   capabilities: ethernet physical
   configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.27 link=yes multicast=yes
rfkill list:
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
nmcli device show wlan0:
Error: Device 'wlan0' not found.
sudo lshw -short -class network
H/W path       Device       Class          Description
/0/100/14.3                 network        Intel Corporation
/0/100/1d/0    enp1s0       network        RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/2             enp0s20f0u1  network        Ethernet interface
K7AAY
  • 17,705
