I've installed the 23.10 iso on my work machine before it got taken down, and everything was working flawlessly. However, after booting up this morning I can't connect to wifi anymore. Tried a few things to get it back to work but nothing has solved the problem so far.
I'm running a Thinkpad L-13 with an Intel Comet Lake PCH-LP CNVi wifi chip.
In systemd's logs, it says:
NetworkManager: rfkill4: found Wi-Fi radio killswitch
everytime I try to connect with the GUI.
With nmtui, when trying to activate a connection, I get:
Could not activate connection: Message recipient disconnected from message bus without replying
The wifi works on the Ubuntu 23.10 live usb.
Noticed an error message at boot that mentioned a netplan error. I ran
sudo netplan --debug generate
and then deleted a problematic yaml config file that was probably generated when I changed DNS. Everything is now back to normal.
Worked for me also,I moved the /etc/netplan/filename.yaml(different for everyone) to /tmp. Find your file with $ sudo net plan--debug generate then move it,the wifi should now work.
Just an improvement to the answer by Andre above.
When I ran the command,
I got to know the problematic Wi-Fi connection and the .yaml file with the following error message error in network definition duplicate access point ssid
Move the problematic .yaml file to somewhere else (May be /tmp). (Instead delete the problematic .yaml file, better we can move it or having a copy to avoid the loss of file)
sudo mv /etc/netplan/90-NM-afxxxxxc2-2xxc-4xx4-9xxx-exxxxxxxxx8.yaml /tmp/
(The name of the problematic .yaml is different for person to person)
Once it moved you can make sure all good by run the sudo netplan --debug generate command, where no error message will be appear.
Then you can be able to connect to the Wi-Fi by clicking it! (A system restart/reboot might be also good before connecting to Wi-Fi again)
Just to keep the correct answer all along. Do proceed with generating the error-causing file in \etc\netplan\ using
There might be more than one .yaml file that's generated and that causes the error as was in my case. Reboot after moving this file to \tmp\ folder.
