Edit: Solved in comments via @libnull-dev. Changing router security settings addressed the issue. Also, thanks to @libnull-dev I learned that despite Pop_OS! being built on Ubuntu, the best place to log related issues is in the Pos_OS! github issue tracker.
Edit 2: also found a great Wireless info script to help provide better information for diagnosing wireless issues. From the comment:
wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info && chmod +x wireless-info && ./wireless-info
I'm stuck in my troubleshooting process and I need help debugging.
Running Pop_OS! 19.10 on a Lenovo Thinkpad x1 Extreme. It does not connect to my home network. I updated my desktop to Ubuntu 19.10 and it connects great. The laptop dual boots with Windows 10, and it can connect as well. Nothing changed with the router, though I did factory reset it to be safe with no luck.
The only variable between when the laptop connected and did not was 19.04 -> 19.10
TL;DR of my logs below include
journalctl -b | grep wifilspci -nnk | grep 0280 -A3dmesg | grep -e wl -e iwllshw -C networkcat /var/log/syslog | grep iwlwifisystemctl status network-managerof both failed and successful connections (home network and iPhone tether, respectively)
If there's any other info I should include, I'm happy to.
One error I'm aware of is the BIOS contains WGDS but not WRDS. I believe this was an issue preventing the computer from fully suspending and was solved by toggling XHC in wakeup, though I still see the message in the syslog.
Nov 01 02:00:40 pop-os NetworkManager[1262]: <info> [1572595240.8799] device (wlp0s20f3): Activation: (wifi) access point 'My iPhone' has security, but secrets are required.
Nov 01 02:00:40 pop-os NetworkManager[1262]: <info> [1572595240.8848] device (wlp0s20f3): Activation: (wifi) connection 'My iPhone' has security, and secrets exist. No new secrets needed.
Nov 01 02:00:41 pop-os NetworkManager[1262]: <info> [1572595241.1732] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "My iPhone"
Nov 01 08:01:58 pop-os NetworkManager[1262]: <info> [1572616918.9249] device (wlp0s20f3): Activation: (wifi) access point 'HOME_WIFI_5G' has security, but secrets are required.
Nov 01 08:01:58 pop-os NetworkManager[1262]: <info> [1572616918.9309] device (wlp0s20f3): Activation: (wifi) connection 'HOME_WIFI_5G' has security, and secrets exist. No new secrets needed.
Nov 01 08:02:01 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:02 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:04 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:08 pop-os dbus-daemon[1242]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.983' (uid=1000 pid=8116 comm="gnome-control-center wifi " label="unconfined")
Nov 01 08:02:18 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:19 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:24 pop-os NetworkManager[1262]: <warn> [1572616944.1937] device (wlp0s20f3): Activation: (wifi) association took too long
Nov 01 08:02:24 pop-os NetworkManager[1262]: <warn> [1572616944.1965] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 01 08:02:31 pop-os NetworkManager[1262]: <info> [1572616951.1907] device (wlp0s20f3): Activation: (wifi) connection 'HOME_WIFI_5G' has security, and secrets exist. No new secrets needed.
Nov 01 08:02:44 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:45 pop-os kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 01 08:02:56 pop-os NetworkManager[1262]: <warn> [1572616976.1929] device (wlp0s20f3): Activation: (wifi) association took too long
Nov 01 08:02:56 pop-os NetworkManager[1262]: <warn> [1572616976.1954] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 01 08:02:58 pop-os NetworkManager[1262]: <info> [1572616978.7874] device (wlp0s20f3): Activation: (wifi) access point 'My iPhone' has security, but secrets are required.
Nov 01 08:02:58 pop-os NetworkManager[1262]: <info> [1572616978.7996] device (wlp0s20f3): Activation: (wifi) connection 'My iPhone' has security, and secrets exist. No new secrets needed.
Nov 01 08:02:58 pop-os NetworkManager[1262]: <info> [1572616978.9590] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "My iPhone"
Nov 01 08:03:02 pop-os dbus-daemon[1242]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.983' (uid=1000 pid=8116 comm="gnome-control-center wifi " label="unconfined")
Nov 01 08:03:40 pop-os NetworkManager[1262]: <info> [1572617020.0538] device (wlp0s20f3): Activation: (wifi) access point 'HOME_WIFI_5G, too' has security, but secrets are required.
Nov 01 08:03:44 pop-os NetworkManager[1262]: <info> [1572617024.7577] device (wlp0s20f3): Activation: (wifi) connection 'HOME_WIFI_5G, too' has security, and secrets exist. No new secrets needed.
Nov 01 08:04:10 pop-os NetworkManager[1262]: <warn> [1572617050.1930] device (wlp0s20f3): Activation: (wifi) association took too long
Nov 01 08:04:10 pop-os NetworkManager[1262]: <warn> [1572617050.1965] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 01 08:04:16 pop-os NetworkManager[1262]: <info> [1572617056.3711] device (wlp0s20f3): Activation: (wifi) access point 'My iPhone' has security, but secrets are required.
Nov 01 08:04:16 pop-os NetworkManager[1262]: <info> [1572617056.3765] device (wlp0s20f3): Activation: (wifi) connection 'My iPhone' has security, and secrets exist. No new secrets needed.
Nov 01 08:04:24 pop-os NetworkManager[1262]: <info> [1572617064.0736] device (wlp0s20f3): Activation: (wifi) access point 'My iPhone' has security, but secrets are required.
Nov 01 08:04:24 pop-os NetworkManager[1262]: <info> [1572617064.0827] device (wlp0s20f3): Activation: (wifi) connection 'My iPhone' has security, and secrets exist. No new secrets needed.
Nov 01 08:04:27 pop-os NetworkManager[1262]: <info> [1572617067.4427] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "My iPhone"
Subsystem: Intel Corporation Wireless-AC 9560 [Jefferson Peak] [8086:0030]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
[ 221.940192] wlp0s20f3: deauthenticating from bc:99:11:53:76:36 by local choice (Reason: 1=UNSPECIFIED)
[ 224.394062] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 224.400605] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 224.439626] wlp0s20f3: authenticated
[ 224.441378] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 224.442290] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 224.442302] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 224.442426] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 224.641732] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 224.645482] wlp0s20f3: associate with bc:99:11:53:76:36 (try 2/3)
[ 224.649181] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 224.649190] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 224.841714] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 224.853459] wlp0s20f3: associate with bc:99:11:53:76:36 (try 3/3)
[ 224.855481] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 224.855491] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 225.041695] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 225.057495] wlp0s20f3: association with bc:99:11:53:76:36 timed out
[ 227.105813] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 227.113132] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 227.152176] wlp0s20f3: authenticated
[ 227.153662] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 227.154598] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 227.154607] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 227.241274] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 227.361710] wlp0s20f3: associate with bc:99:11:53:76:36 (try 2/3)
[ 227.365889] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 227.365899] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 227.441158] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 227.569679] wlp0s20f3: associate with bc:99:11:53:76:36 (try 3/3)
[ 227.571328] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 227.571330] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 227.641058] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 227.776525] wlp0s20f3: association with bc:99:11:53:76:36 timed out
[ 230.102006] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 230.109369] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 230.153104] wlp0s20f3: authenticated
[ 230.157881] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 230.158952] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=0 aid=1)
[ 230.160180] wlp0s20f3: associated
[ 230.172304] wlp0s20f3: deauthenticating from bc:99:11:53:76:36 by local choice (Reason: 1=UNSPECIFIED)
[ 241.705657] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 241.712239] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 241.751300] wlp0s20f3: authenticated
[ 241.754459] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 241.755306] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 241.755310] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 241.755478] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 241.955114] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 241.962493] wlp0s20f3: associate with bc:99:11:53:76:36 (try 2/3)
[ 241.966319] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 241.966323] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 242.154975] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 242.166547] wlp0s20f3: associate with bc:99:11:53:76:36 (try 3/3)
[ 242.168206] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 242.168216] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 242.355052] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 242.370556] wlp0s20f3: association with bc:99:11:53:76:36 timed out
[ 256.365884] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 256.373288] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 256.412393] wlp0s20f3: authenticated
[ 256.418812] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 256.419872] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=0 aid=1)
[ 256.421215] wlp0s20f3: associated
[ 256.432102] wlp0s20f3: deauthenticating from bc:99:11:53:76:36 by local choice (Reason: 1=UNSPECIFIED)
[ 267.774755] wlp0s20f3: authenticate with bc:99:11:53:76:36
[ 267.782056] wlp0s20f3: send auth to bc:99:11:53:76:36 (try 1/3)
[ 267.821001] wlp0s20f3: authenticated
[ 267.822885] wlp0s20f3: associate with bc:99:11:53:76:36 (try 1/3)
[ 267.823807] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 267.823818] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 267.823895] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 268.023265] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 268.026959] wlp0s20f3: associate with bc:99:11:53:76:36 (try 2/3)
[ 268.030638] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 268.030647] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 268.223658] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 268.230879] wlp0s20f3: associate with bc:99:11:53:76:36 (try 3/3)
[ 268.232511] wlp0s20f3: RX AssocResp from bc:99:11:53:76:36 (capab=0x11 status=30 aid=1)
[ 268.232514] wlp0s20f3: bc:99:11:53:76:36 rejected association temporarily; comeback duration 196 TU (200 ms)
[ 268.423332] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 268.434967] wlp0s20f3: association with bc:99:11:53:76:36 timed out
[ 281.684608] wlp0s20f3: authenticate with 76:2f:75:13:b6:08
[ 281.690243] wlp0s20f3: send auth to 76:2f:75:13:b6:08 (try 1/3)
[ 281.729949] wlp0s20f3: authenticated
[ 281.730949] wlp0s20f3: associate with 76:2f:75:13:b6:08 (try 1/3)
[ 281.737833] wlp0s20f3: RX AssocResp from 76:2f:75:13:b6:08 (capab=0x411 status=0 aid=1)
[ 281.740176] wlp0s20f3: associated
[ 281.782115] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 282.029965] wlp0s20f3: Limiting TX power to 30 (30 - 0) dBm as advertised by 76:2f:75:13:b6:08
[ 322.850790] wlp0s20f3: deauthenticating from 76:2f:75:13:b6:08 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 327.619115] wlp0s20f3: authenticate with bc:99:11:53:76:35
[ 327.625421] wlp0s20f3: send auth to bc:99:11:53:76:35 (try 1/3)
[ 327.627624] wlp0s20f3: authenticated
[ 327.633890] wlp0s20f3: associate with bc:99:11:53:76:35 (try 1/3)
[ 327.637822] wlp0s20f3: RX AssocResp from bc:99:11:53:76:35 (capab=0x411 status=0 aid=3)
[ 327.640339] wlp0s20f3: associated
[ 327.668924] wlp0s20f3: deauthenticating from bc:99:11:53:76:35 by local choice (Reason: 1=UNSPECIFIED)
[ 330.098823] wlp0s20f3: authenticate with bc:99:11:53:76:35
[ 330.105212] wlp0s20f3: send auth to bc:99:11:53:76:35 (try 1/3)
[ 330.107723] wlp0s20f3: authenticated
[ 330.109195] wlp0s20f3: associate with bc:99:11:53:76:35 (try 1/3)
[ 330.113181] wlp0s20f3: RX AssocResp from bc:99:11:53:76:35 (capab=0x411 status=0 aid=3)
[ 330.115582] wlp0s20f3: associated
[ 330.130225] wlp0s20f3: deauthenticating from bc:99:11:53:76:35 by local choice (Reason: 1=UNSPECIFIED)
[ 332.551059] wlp0s20f3: authenticate with bc:99:11:53:76:35
[ 332.557551] wlp0s20f3: send auth to bc:99:11:53:76:35 (try 1/3)
[ 332.564070] wlp0s20f3: authenticated
[ 332.565074] wlp0s20f3: associate with bc:99:11:53:76:35 (try 1/3)
[ 332.570493] wlp0s20f3: RX AssocResp from bc:99:11:53:76:35 (capab=0x411 status=0 aid=3)
[ 332.574898] wlp0s20f3: associated
[ 332.585569] wlp0s20f3: deauthenticating from bc:99:11:53:76:35 by local choice (Reason: 1=UNSPECIFIED)
[ 333.976596] wlp0s20f3: authenticate with bc:99:11:53:76:35
[ 333.982954] wlp0s20f3: send auth to bc:99:11:53:76:35 (try 1/3)
[ 333.985500] wlp0s20f3: authenticated
[ 333.992181] wlp0s20f3: associate with bc:99:11:53:76:35 (try 1/3)
[ 333.996611] wlp0s20f3: RX AssocResp from bc:99:11:53:76:35 (capab=0x411 status=0 aid=3)
[ 333.999071] wlp0s20f3: associated
[ 334.019769] wlp0s20f3: deauthenticating from bc:99:11:53:76:35 by local choice (Reason: 1=UNSPECIFIED)
[ 345.896991] wlp0s20f3: authenticate with bc:99:11:53:76:35
[ 345.903314] wlp0s20f3: send auth to bc:99:11:53:76:35 (try 1/3)
[ 345.905680] wlp0s20f3: authenticated
[ 345.909206] wlp0s20f3: associate with bc:99:11:53:76:35 (try 1/3)
[ 345.913118] wlp0s20f3: RX AssocResp from bc:99:11:53:76:35 (capab=0x411 status=0 aid=3)
[ 345.917340] wlp0s20f3: associated
[ 345.933173] wlp0s20f3: deauthenticating from bc:99:11:53:76:35 by local choice (Reason: 1=UNSPECIFIED)
lshw -C network
WARNING: you should run this program as super-user.
*-network:0
description: Ethernet interface
product: Wireless-AC 9560 [Jefferson Peak]
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
logical name: wlp0s20f3
version: 10
serial: 48:f1:7f:90:9b:ba
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=5.3.0-20-generic firmware=46.6bf1df06.0 ip=172.20.10.11 latency=0 link=yes multicast=yes
resources: iomemory:400-3ff irq:16 memory:404b10c000-404b10ffff
Full output had many redundant entries. This was shortened
Nov 8 08:41:38 pop-os kernel: [ 4.421752] Loading modules backported from iwlwifi
Nov 8 08:41:38 pop-os kernel: [ 4.421753] iwlwifi-stack-public:master:8042:654c426c
Nov 8 08:41:38 pop-os kernel: [ 4.499884] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Nov 8 08:41:38 pop-os kernel: [ 4.543884] iwlwifi 0000:00:14.3: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
Nov 8 08:41:38 pop-os kernel: [ 4.545396] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
Nov 8 08:41:38 pop-os kernel: [ 4.545398] iwlwifi 0000:00:14.3: Found debug configuration: 0
Nov 8 08:41:38 pop-os kernel: [ 4.545739] iwlwifi 0000:00:14.3: loaded firmware version 46.6bf1df06.0 op_mode iwlmvm
Nov 8 08:41:38 pop-os kernel: [ 4.631681] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x318
Nov 8 08:41:38 pop-os kernel: [ 4.639254] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:38 pop-os kernel: [ 4.639664] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
Nov 8 08:41:38 pop-os kernel: [ 4.683805] iwlwifi 0000:00:14.3: base HW address: 48:f1:7f:90:9b:ba
Nov 8 08:41:38 pop-os kernel: [ 4.785551] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
Nov 8 08:41:39 pop-os NetworkManager[1289]: <info> [1573227699.0923] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill2) (driver iwlwifi)
Nov 8 08:41:39 pop-os kernel: [ 6.205475] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:39 pop-os kernel: [ 6.319091] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:39 pop-os kernel: [ 6.384077] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
Nov 8 08:41:39 pop-os kernel: [ 6.390968] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Nov 8 08:41:38 pop-os kernel: [ 4.495765] Loading modules backported from iwlwifi
Nov 8 08:41:38 pop-os kernel: [ 4.495766] iwlwifi-stack-public:master:8042:654c426c
Nov 8 08:41:38 pop-os kernel: [ 4.547883] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Nov 8 08:41:38 pop-os kernel: [ 4.553422] iwlwifi 0000:00:14.3: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
Nov 8 08:41:38 pop-os kernel: [ 4.555005] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
Nov 8 08:41:38 pop-os kernel: [ 4.555007] iwlwifi 0000:00:14.3: Found debug configuration: 0
Nov 8 08:41:38 pop-os kernel: [ 4.555275] iwlwifi 0000:00:14.3: loaded firmware version 46.6bf1df06.0 op_mode iwlmvm
Nov 8 08:41:38 pop-os kernel: [ 4.577279] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz, REV=0x318
Nov 8 08:41:38 pop-os kernel: [ 4.586254] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:38 pop-os kernel: [ 4.586683] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
Nov 8 08:41:38 pop-os kernel: [ 4.629359] iwlwifi 0000:00:14.3: base HW address: 48:f1:7f:90:9b:ba
Nov 8 08:41:38 pop-os kernel: [ 4.844004] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
Nov 8 08:41:39 pop-os NetworkManager[1300]: <info> [1573227699.0991] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill2) (driver iwlwifi)
Nov 8 08:41:39 pop-os kernel: [ 6.410486] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:39 pop-os kernel: [ 6.526716] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
Nov 8 08:41:39 pop-os kernel: [ 6.591726] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
Nov 8 08:41:39 pop-os kernel: [ 6.598532] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Nov 8 08:42:33 pop-os kernel: [ 60.834476] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:34 pop-os kernel: [ 61.033970] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:34 pop-os kernel: [ 61.235438] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:34 pop-os kernel: [ 61.434286] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:36 pop-os kernel: [ 63.635410] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:36 pop-os kernel: [ 63.835459] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:42:37 pop-os kernel: [ 64.035532] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:44:09 pop-os kernel: [ 156.022463] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Nov 8 08:44:09 pop-os kernel: [ 156.222310] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
This is after failed connection to wifi
● NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2019-11-08 10:23:20 MST; 1h 35min ago
Docs: man:NetworkManager(8)
Main PID: 1200 (NetworkManager)
Tasks: 3 (limit: 4915)
Memory: 18.2M
CGroup: /system.slice/NetworkManager.service
└─1200 /usr/sbin/NetworkManager --no-daemon
Nov 08 11:54:33 pop-os NetworkManager[1200]: <warn> [1573239273.9736] device (wlp0s20f3): Activation: (wifi) asking for new secrets
Nov 08 11:54:34 pop-os NetworkManager[1200]: <info> [1573239274.3509] device (wlp0s20f3): supplicant interface state: scanning -> inactive
Nov 08 11:54:34 pop-os NetworkManager[1200]: <info> [1573239274.3509] device (p2p-dev-wlp0s20f3): supplicant management interface state: scanning -> inactive
Nov 08 11:54:36 pop-os NetworkManager[1200]: <warn> [1573239276.0906] device (wlp0s20f3): no secrets: User canceled the secrets request.
Nov 08 11:54:36 pop-os NetworkManager[1200]: <info> [1573239276.0906] device (wlp0s20f3): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Nov 08 11:54:36 pop-os NetworkManager[1200]: <info> [1573239276.0911] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 08 11:54:36 pop-os NetworkManager[1200]: <warn> [1573239276.0924] device (wlp0s20f3): Activation: failed for connection 'HOME_WIFI_5G'
Nov 08 11:54:36 pop-os NetworkManager[1200]: <info> [1573239276.0929] device (wlp0s20f3): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 08 11:55:40 pop-os NetworkManager[1200]: <info> [1573239340.9865] device (wlp0s20f3): supplicant interface state: inactive -> scanning
Nov 08 11:55:40 pop-os NetworkManager[1200]: <info> [1573239340.9866] device (p2p-dev-wlp0s20f3): supplicant management interface state: inactive -> scanning
This is a successful tether to my iPhone
Active: active (running) since Fri 2019-11-08 10:23:20 MST; 1h 37min ago
Tasks: 4 (limit: 4915)
Memory: 18.6M
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0838] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0843] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0852] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0913] manager: NetworkManager state is now CONNECTED_SITE
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0917] policy: set 'My iPhone' (wlp0s20f3) as default for IPv4 routing and DNS
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.0971] device (wlp0s20f3): Activation: successful, device activated.
Nov 08 12:00:59 pop-os NetworkManager[1200]: <info> [1573239659.5078] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 08 12:01:00 pop-os NetworkManager[1200]: <info> [1573239660.6043] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Nov 08 12:01:00 pop-os NetworkManager[1200]: <info> [1573239660.6075] policy: set 'My iPhone' (wlp0s20f3) as default for IPv6 routing and DNS
Nov 08 12:01:00 pop-os NetworkManager[1200]: <info> [1573239660.6154] dhcp6 (wlp0s20f3): state changed unknown -> bound
