HP Laptop running Kubuntu 24.04 isn't able to use its Realtek RTL8152 wireless adapter. As a test to check if it was a hardware issue, I reinstalled Windows11 and went through the setup process, and the WLAN adapter worked without any additional drivers needing to be installed, and showed all my local available WiFi networks. I reinstalled Kubuntu, and ran into the same issue again: no visible WiFi networks, and no option to even turn on WiFi anywhere in the settings. The issue is isolated to the WiFi adapter; the laptop can utilize ethernet without any problems and is online with a USB ethernet adapter.
I have gone through the standard steps outlined in other similar, older threads here and made sure that the linux-modules packages are current.
sudo dpkg -s linux-modules-extra-$(uname -r) | grep Status Status: install ok installed linux-modules-extra-6.8.0-62-generic is already the newest version (6.8.0-62.65).
lsusb yields the following, showing that the adapter is visible:
Bus 001 Device 002: ID 0408:548f Quanta Computer, Inc. HP True Vision HD Camera
Bus 001 Device 003: ID 0bda:b86a Realtek Semiconductor Corp. Bluetooth Radio
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 214b:7250 Huasheng Electronics USB2.0 HUB
Bus 003 Device 003: ID 090c:2320 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) USB_Flash_Disk
Bus 003 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 003 Device 005: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 003 Device 006: ID 0e8d:1887 MediaTek Inc. Slim Portable DVD Writer
Bus 003 Device 007: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
However when I use the nmtui tool, both the WiFi and WWAN options show a "hardware missing" message despite both being enabled.
sudo lshw -class network yields the following:
*-network UNCLAIMED
       description: Network controller
       product: Realtek Semiconductor Co., Ltd.
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:f000(size=256) memory:fcf00000-fcffffff
  *-network
       description: Ethernet interface
       physical id: b
       bus info: usb@3:2.4.3
       logical name: enx00e04c36499c
       serial: 00:e0:4c:36:49:9c
       capacity: 100Mbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=full ip=192.168.110.140 link=yes multicast=yes port=MII speed=100Mbit/s```
sudo lspci -vnn | awk -vRS= '/\[0280\]/' showed the following output:
        DeviceName: Realtek Wireless LAN + BT
        Subsystem: Hewlett-Packard Company Device [103c:88e9]
        Flags: fast devsel, IRQ 255, IOMMU group 8
        I/O ports at f000 [disabled] [size=256]
        Memory at fcf00000 (64-bit, non-prefetchable) [disabled] [size=1M]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Device Serial Number 00-e0-4c-ff-fe-88-52-01
        Capabilities: [158] Latency Tolerance Reporting
        Capabilities: [160] L1 PM Substates```
</code></pre>
mpboden
  • 3,046
ISSUE RESOLVED USING THE STEPS IN THE FOLLOWING THREAD: (Credit @Jeremy31)
Wi-Fi not working on HP OmniBook 5 with Realtek RTL8723DE on Ubuntu 24 (Device 10ec:b520)
By using the following commands, my laptop's WLAN adapter was enabled and could connect to local WiFi networks. (The KDE login screen has been replaced with an Ubuntu UI after following these steps, however the desktop remains the same)
sudo apt remove bcmwl-kernel-source broadcom-sta-dkms
sudo apt-get install linux-oem-24.04c
sudo apt install zstd
cd /lib/firmware/rtw89
sudo wget https://web.git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/rtw89/rtw8852bt_fw.bin
sudo zstd rtw8852bt_fw.bin
