sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: RT3290 Wireless 802.11n 1T/1R PCIe
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:07:00.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:63510000-6351ffff
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:08:00.0
logical name: eth0
version: 05
serial: 38:ea:a7:e3:ce:ee
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.1.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:27 ioport:3000(size=256) memory:63404000-63404fff memory:63400000-63403fff
My laptop does not show any wifi network connections. What is the solution for this??
output for sudo modprobe rt2800pci:
did not get anything in output for this.
wireless-info output:
########## wireless info START ##########
Report from: 20 Aug 2016 12:13 IST +0530
Booted last: 20 Aug 2016 00:00 IST +0530
Script from: 08 Jul 2016 02:16 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 16.04.1 LTS
Release: 16.04
Codename: xenial
##### kernel ############################
Linux 4.4.0-34-generic #53-Ubuntu SMP Wed Jul 27 16:06:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
07:00.0 Network controller [0280]: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe [1814:3290]
DeviceName: Ralink RT3290LE 802.11bgn 1x1 Wi-Fi and Bluetooth 4.0 Combo Ad
Subsystem: Hewlett-Packard Company Ralink RT3290LE 802.11bgn 1x1 Wi-Fi and Bluetooth 4.0 Combo Adapter [103c:18ec]
08:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 05)
DeviceName: Realtek PCIe FE Family Controller
Subsystem: Hewlett-Packard Company RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [103c:183e]
##### lsusb #############################
Bus 002 Device 003: ID 05c8:0348 Cheng Uei Precision Industry Co., Ltd (Foxlink)
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
##### lsmod #############################
cfg80211 565248 0
hp_wmi 16384 0
sparse_keymap 16384 1 hp_wmi
rt3290sta 1155072 0
wmi 20480 1 hp_wmi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eno1 Link encap:Ethernet HWaddr <MAC 'eno1' [IF1]>
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:16
eth0 Link encap:Ethernet HWaddr <MAC 'eth0' [IF2]>
inet addr:192.168.1.4 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::82d3:f25f:f057:e5c4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:151767 errors:0 dropped:0 overruns:0 frame:0
TX packets:104837 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:183526108 (183.5 MB) TX bytes:13938615 (13.9 MB)
##### iwconfig ##########################
lo no wireless extensions.
eth0 no wireless extensions.
eno1 Ralink STA
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 100 0 0 eth0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 100 0 0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
search domain.name
##### network managers ##################
Installed:
NetworkManager
Running:
root 2455 1 0 11:16 ? 00:00:00 /usr/sbin/NetworkManager --no-daemon
##### NetworkManager info ###############
GENERAL.DEVICE: eth0
GENERAL.TYPE: ethernet
GENERAL.NM-TYPE: NMDeviceEthernet
GENERAL.VENDOR: Realtek Semiconductor Co., Ltd.
GENERAL.PRODUCT: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
GENERAL.DRIVER: r8169
GENERAL.DRIVER-VERSION: 2.3LK-NAPI
GENERAL.FIRMWARE-VERSION:
GENERAL.HWADDR: <MAC 'eth0' [IF2]>
GENERAL.MTU: 1500
GENERAL.STATE: 100 (connected)
GENERAL.REASON: 0 (No reason given)
GENERAL.UDI: /sys/devices/pci0000:00/0000:00:1c.1/0000:08:00.0/net/eth0
GENERAL.IP-IFACE: eth0
GENERAL.IS-SOFTWARE: no
GENERAL.NM-MANAGED: yes
GENERAL.AUTOCONNECT: yes
GENERAL.FIRMWARE-MISSING: no
GENERAL.NM-PLUGIN-MISSING: no
GENERAL.PHYS-PORT-ID: --
GENERAL.CONNECTION: Wired connection 1
GENERAL.CON-UUID: 598f6bb0-a87b-45c7-9684-2aae054ef826
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/0
GENERAL.METERED: no (guessed)
CAPABILITIES.CARRIER-DETECT: yes
CAPABILITIES.SPEED: 100 Mb/s
CAPABILITIES.IS-SOFTWARE: no
WIRED-PROPERTIES.CARRIER: on
CONNECTIONS.AVAILABLE-CONNECTION-PATHS: /org/freedesktop/NetworkManager/Settings/{7}
CONNECTIONS.AVAILABLE-CONNECTIONS[1]: 598f6bb0-a87b-45c7-9684-2aae054ef826 | Wired connection 1
IP4.ADDRESS[1]: 192.168.1.4/24
IP4.GATEWAY: 192.168.1.1
IP4.ROUTE[1]: dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.DNS[1]: 192.168.1.1
IP4.DOMAIN[1]: domain.name
DHCP4.OPTION[1]: requested_routers = 1
DHCP4.OPTION[2]: requested_domain_search = 1
DHCP4.OPTION[3]: requested_time_offset = 1
DHCP4.OPTION[4]: requested_domain_name = 1
DHCP4.OPTION[5]: requested_rfc3442_classless_static_routes = 1
DHCP4.OPTION[6]: requested_broadcast_address = 1
DHCP4.OPTION[7]: requested_netbios_scope = 1
DHCP4.OPTION[8]: requested_wpad = 1
DHCP4.OPTION[9]: next_server = 0.0.0.0
DHCP4.OPTION[10]: expiry = 1471758423
DHCP4.OPTION[11]: requested_interface_mtu = 1
DHCP4.OPTION[12]: requested_subnet_mask = 1
DHCP4.OPTION[13]: routers = 192.168.1.1
DHCP4.OPTION[14]: dhcp_message_type = 5
DHCP4.OPTION[15]: ip_address = 192.168.1.4
DHCP4.OPTION[16]: requested_static_routes = 1
DHCP4.OPTION[17]: domain_name = domain.name
DHCP4.OPTION[18]: requested_domain_name_servers = 1
DHCP4.OPTION[19]: broadcast_address = 192.168.1.255
DHCP4.OPTION[20]: requested_ntp_servers = 1
DHCP4.OPTION[21]: requested_netbios_name_servers = 1
DHCP4.OPTION[22]: dhcp_lease_time = 86400
DHCP4.OPTION[23]: domain_name_servers = 192.168.1.1
DHCP4.OPTION[24]: requested_ms_classless_static_routes = 1
DHCP4.OPTION[25]: subnet_mask = 255.255.255.0
DHCP4.OPTION[26]: network_number = 192.168.1.0
DHCP4.OPTION[27]: requested_host_name = 1
DHCP4.OPTION[28]: dhcp_server_identifier = 192.168.1.1
IP6.ADDRESS[1]: fe80::82d3:f25f:f057:e5c4/64
IP6.GATEWAY: fe80::928d:78ff:fe0f:817f
IP6.ROUTE[1]: dst = fe80::928d:78ff:fe0f:817f/128, nh = ::, mt = 100
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/udta_tir]] (600 root)
[connection] id=udta_tir | type=802-11-wireless
[802-11-wireless] ssid=udta_tir | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/aahana]] (600 root)
[connection] id=aahana | type=802-11-wireless
[802-11-wireless] ssid=aahana | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/mgmt_sales]] (600 root)
[connection] id=mgmt_sales | type=802-11-wireless
[802-11-wireless] ssid=mgmt_sales | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/kaustubh's]] (600 root)
[connection] id=kaustubh's | type=802-11-wireless
[802-11-wireless] ssid=kaustubh's | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/I'veseenyounaked]] (600 root)
[connection] id=I'veseenyounaked | type=802-11-wireless
[802-11-wireless] ssid=I'veseenyounaked | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/AHVAAN-WIFI]] (600 root)
[connection] id=AHVAAN-WIFI | type=wifi | permissions=
[wifi] mac-address=<MAC address> | mac-address-blacklist= | ssid=AHVAAN-WIFI
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/dlink]] (600 root)
[connection] id=dlink | type=802-11-wireless
[802-11-wireless] ssid=dlink | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: Asia/Kolkata (based on set time zone)
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 40), (N/A, 20), (N/A), NO-IR
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
(5170 - 5250 @ 80), (N/A, 20), (N/A), NO-IR
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, NO-IR
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
(5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
lo no frequency information.
eth0 no frequency information.
eno1 0 channels
##### iwlist scan #######################
lo Interface doesn't support scanning.
eno1 Interface doesn't support scanning : Network is down
eth0 Interface doesn't support scanning.
##### module infos ######################
[cfg80211]
filename: /lib/modules/4.4.0-34-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: 25A45701AAA64DAC1E47D9D
depends:
intree: Y
vermagic: 4.4.0-34-generic SMP mod_unload modversions
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
[rt3290sta]
filename: /lib/modules/4.4.0-34-generic/updates/dkms/rt3290sta.ko
version: 2.6.0.0_rev1
srcversion: 073AC1AA84019DBCFEC8F58
depends:
parm: mac:rt28xx: wireless mac addr (charp)
##### module parameters #################
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rt3290sta
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
blacklist rt2800pci
[/etc/modprobe.d/blacklist-myrt2800pci.conf]
blacklist rt2800pci
[/etc/modprobe.d/blacklist-ralink.conf]
blacklist rt2800pci
blacklist rt2x00pci
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/intel-microcode-blacklist.conf]
blacklist microcode
[/etc/modprobe.d/iwlwifi.conf]
options iwlwifi 11n_disable=1
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/rt3290.conf]
options rt3290 fwlps=N
##### rc.local ##########################
exit 0
##### pm-utils ##########################
[/etc/pm/config.d/config] (644 root)
SUSPEND_MODULES="rt3290"
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x10ec:0x8136 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF2]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x1814:0x3290 (rt2800pci)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC address>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[ 41.779455] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 44.592614] r8169 0000:08:00.0 eth0: link down (repeated 2 times)
[ 44.592664] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 46.139107] r8169 0000:08:00.0 eth0: link up
[ 46.139120] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
########## wireless info END ############
output for dmesg | grer rt3:
[ 15.770994] rt3290sta: module license 'unspecified' taints kernel.
[ 15.771405] rt3290sta: module verification failed: signature and/or required key missing - tainting kernel
