I can't get my AC53 Wifi USB dongle to install, I have done extensive research and only found two sources helped me to install some drivers through ndiswrapper.
Nevertheless I am still unable to use Wifi through USB.
I would really appreciate your help as this is driving me a bit mad. I don't want to give up on Ubuntu so early but I've been around 10 hours trying to solve this already.
These are the results after running the Wireless Script:
########## wireless info START ##########
Report from: 28 Mar 2015 11:14 GMT +0000
Booted last: 28 Mar 2015 09:46 GMT +0000
Script from: 20 Sep 2014 23:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
##### kernel ############################
Linux 3.16.0-33-generic #44~14.04.1-Ubuntu SMP Fri Mar 13 10:33:29 UTC 2015 x86_64     x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
Subsystem: ASRock Incorporation Motherboard (one of many) [1849:8168]
    Kernel driver in use: r8169
##### lsusb #############################
Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 010 Device 005: ID 0b05:17e5 ASUSTek Computer, Inc.
Bus 010 Device 004: ID 05a4:9881 Ortek Technology, Inc. IR receiver [VRC-1100 Vista MCE Remote Control]
Bus 010 Device 002: ID 1532:001c Razer USA, Ltd RZ01-0036 Optical Gaming Mouse [Abyssus]
Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 058f:3832 Alcor Micro Corp.
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
##### lsmod #############################
cfg80211              494362  0
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr <MAC 'eth0' [IF]>
          inet addr:192.168.1.222  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::be5f:f4ff:fe73:9272/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:191323 errors:0 dropped:0 overruns:0 frame:0
          TX packets:150116 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:190838402 (190.8 MB)  TX bytes:17069807 (17.0 MB)
##### iwconfig ##########################
eth0      no wireless extensions.
lo        no wireless extensions.
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.254   0.0.0.0         UG    0      0        0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U     1      0        0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
search home
##### nm-tool ###########################
NetworkManager Tool
State: connected (global)
- Device: eth0  [Wired connection 1] -------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             connected
  Default:           yes
  HW Address:        <MAC 'eth0' [IF]>
  Capabilities:
    Carrier Detect:  yes
    Speed:           1000 Mb/s
  Wired Properties
    Carrier:         on
  IPv4 Settings:
    Address:         192.168.1.222
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.1.254
    DNS:             192.168.1.254
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
##### iw reg get ########################
Region: Europe/London (based on set time zone)
country 00:
    (2402 - 2472 @ 40), (3, 20)
    (2457 - 2482 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
    (2474 - 2494 @ 20), (3, 20), NO-OFDM, PASSIVE-SCAN, NO-IBSS
    (5170 - 5250 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
    (5735 - 5835 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
##### iwlist channels ###################
eth0      no frequency information.
lo        no frequency information.
##### iwlist scan #######################
eth0      Interface doesn't support scanning.
lo        Interface doesn't support scanning.
##### module infos ######################
[cfg80211]
filename:       /lib/modules/3.16.0-33-generic/kernel/net/wireless/cfg80211.ko
description:    wireless configuration support
license:        GPL
author:         Johannes Berg
srcversion:     4A525D9D32B0C6D120CA547
depends:
intree:         Y
vermagic:       3.16.0-33-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        25:26:EE:FE:32:C9:58:B4:CD:85:CA:5F:BF:EB:ED:A1:75:D1:B2:18
sig_hashalgo:   sha512
parm:           ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm:           cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz     band (bool)
##### module parameters #################
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/modesetting.conf]
options cirrus modeset=1
options mgag200 modeset=1
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
##### dmesg #############################
########## wireless info END ############
