I installed 23.04 today and my wifi adapter no longer works. Anybody know how to fix it?
jackstand3@jackstand3-Inspiron-530:~$ lspci -nnk | grep 0280 -A3
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4321 802.11a/b/g/n [14e4:4328] (rev 03)
    Subsystem: Dell Wireless 1500 Draft 802.11n WLAN Mini-card [1028:000a]
    Kernel driver in use: b43-pci-bridge
    Kernel modules: ssb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 002: ID 1d57:0016 Xenta Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 003: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser Bus 005 Device 002: ID 413c:2105 Dell Computer Corp. Model L100 Keyboard Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
chili555
  • 61,330
5 Answers5
The upgrade will not install proprietary firmware files, namely those needed for your Broadcom device. With a working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
sudo apt update
sudo apt install firmware-b43-installer
Reboot. You should be all set.
chili555
  • 61,330
Since I reached the question when my existing Wifi connection went out after hard restart of my Ubuntu/PopOS and when checking it was showing No Wifi Adapater found, and since this is bit common now for me here are the steps I follow
  1. Restart Networking Service
sudo service network-manager start
2.If the above does not work and you are not seeing the wifi setting in GUI still
sudo nohup nm-applet &
Now Networking GUI will pop up in a corner and Enable Wifi and Enable Networking will be seen. First enable Networking and then enable Wifi and it should work
  1. I guess you can do this via the commandline also
nmcli networking on
nmcli radio wifi on
https://askubuntu.com/a/962059/423906
Alex Punnen
  • 302
Hoping your issue is resolved but if not, I noticed that 23.04 installed a dkms installation of the Broadcom driver which when installed on my MacBookPro didn't work. However what did work is after installing, the initramfs needed re-building. So sudo update-initramfs -u and with any luck you are good to go!
I resolved this by installing backport-iwlwifi-dkms
sudo apt update
sudo apt install backport-iwlwifi-dkms
-1
The wifi should just work if you do NOT enslave wifi interface to any bridge in your /etc/netplan/xxx file. In other words the following fragment in that file cannot work.
   br0:
      - wlan0
Ubuntu Linux is known to not support bridging wifi interfaces, so the following simple example should work:
network:
   version: 2
   renderer: networkd
   ethernets:
      wlan2:
         dhcp4: yes
         dhcp6: yes
After you change this file run:
sudo netplan generate
sudo netplan apply
...and you should be good to go.
karel
  • 122,292
  • 133
  • 301
  • 332
