It used to work but I guess one of the updates broke it. I can connect to the wifi on my phone and other OS's. Unsure of what would cause this. I have tried deleting the profile for each connection and re-entering passwords but nothing. IF I remove passwords for the connections it will work.
Derek
  • 121
Try this if you have network-manager enabled :
sudo nmcli dev wifi
to find your wifi ssid and
sudo nmcli dev wifi connect <your ssid> password <your pass>
Looks like network-manager is waiting for root permission.
abu_bua
  • 11,313
If you don't want your password to appear in your history just leave out the password part and add the -a option and it will ask for it after you hit enter:
 sudo nmcli -a dev wifi connect <your ssid>
From man nmcli
 -a | --ask    When using this option nmcli will stop and ask for any missing
  required arguments, so do not use this option for non-interactive purposes like
scripts. This option controls, for example, whether you will be prompted for a
password if it is required for connecting to a network.
abu_bua
  • 11,313
In my case it was something with the KDE Wallet system. I've installed some updates, and those seem to wipe my old wallet and make it corrupted - ie the wallet could not been opened.
The fix was to create a new wallet and set it as default.
It happened to me and I hadn't done anything. Turned out there was something wrong with the "Bbox" from Bouygues ISP. After 2 hours on the phone they sorted it out.
Alain Reve
  • 217
  • 18
