My wifi card is: Network controller: Atheros Communications Inc. AR928X Wireless Network Adapter (PCI-Express) (rev 01)
My problem is that when I attempt to connect to a wifi network it refuses the connection and requests I input the correct password. I have reset the router, confirmed the password, and checked for possible configuration issues on that end but everything is normal and all other devices are functional in regards to wifi.
Edit: pastebin of wireless-info script results - http://pastebin.com/Aa8T2Rn4
We need to get a new driver to try to fix the issue you are having:
Install the dependencies required to compile the driver:
sudo apt-get install --reinstall linux-headers-generic linux-headers-$(uname -r) build-essential dkms
No internet:
On another computer go here Select Trusty in the drop-down box. Search for linux-headers-generic, build-essential and dkms. Be sure to locate their dependencies and the dependencies of the dependencies.
Download the correct version, either 32- or 64-bit. Once you've download about seventeen packages on another computer, transfer them with a USB stick to the desktop of the computer with Ubuntu on it. Then do:
cd ~/Desktop
sudo dpkg -i *.deb
Then:
Go here and download the driver 3.15-rc1-1 to your computer then place the file on your desktop and right click and extract here.
Then compile the driver using the directions below.
cd ~/Desktop/backports-3.15-rc1-1
make defconfig-ath9k
make
sudo make install
sudo modprobe -rv ath9k
sudo modprobe -v ath9k
When you have an upgrade to the kernel you will need to do:
make clean
make
sudo make install
Wild Man
  • 8,327
