i'am having troubles with this TPLINK Adapter, i can't use it... i tried EVERYTHING but still won't work I NEED HELP.
Model TPLink TL-WN8200ND(UN) V2
lshw (at usb port)
*-usb:1 NO RECLAMADO
                  descripción: Dispositivo USB genérico
                  producto: 802.11n NIC
                  fabricante: Realtek
                  id físico: 3
                  información del bus: usb@1:1.3
                  versión: 2.00
                  serie: 503EAA309137
                  capacidades: usb-2.10
                  configuración: maxpower=500mA speed=480Mbit/s
lsusb:...
Bus 001 Device 004: ID 0a5c:216d Broadcom Corp.
Bus 001 Device 003: ID 05c8:038f Cheng Uei Precision Industry Co., Ltd (Foxlink)
Bus 001 Device 005: ID 2357:0126  <<<<<(Look at this, i googled it, no answers.)
Bus 001 Device 006: ID 0458:0179 KYE Systems Corp. (Mouse Systems)
Bus 001 Device 002: ID 8087:8001 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 22b8:2e25 Motorola PCS
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
yeah, it's spanish
I tried to install in many ways, nothing works
My PC is a HP240(G5)
Works perfect in Windows(10)
Led's off in Ubuntu (like if it was disconnected) and it warms up slowly
TRIES
https://ubuntuforums.org/showthread.php?t=2340202
TPLINK WN8200ND usb wifi not working
Install other OS (Debian)
https://ubuntuperonista.blogspot.com.ar/2016/05/realtek-wifi-chipsets-ubuntu-instalar-driver-compilar-controlador.html (Ndiswrapper didn't work 'cause driver is only available at .exe, can't find .inf, TRIED TO EXTRACT FROM EXE ((V2)))
Official driver at Tplink page http://www.tp-link.com/au/download/TL-WN8200ND.html#Driver
Many things I remember confusingly, it's all
Edit2
I tried installing https://github.com/Mange/rtl8192eu-linux-driver , didn't work, tried blacklisting RTL8192CU, didn't work, tried unninstalling rtl8192cu driver(dkms), didn't work, still without name at lsusb (unrecognizable)
Edit3
wireless-info>https://paste.ubuntu.com/26531177/
<p>dkms-status><a href="https://paste.ubuntu.com/26531194/" rel="nofollow noreferrer">https://paste.ubuntu.com/26531194/</a></p>
I actually have success installing TP-Link TL-WN8200ND(UN) V2 on Ubuntu 18.04 LTS Desktop (64-bit).
I modified the driver from https://github.com/Mange/rtl8192eu-linux-driver to add support for TL-WN8200ND V2 (By only adding 1 line precisely). I have forked the driver and you can install it by following this step in the terminal:
cd ~
sudo apt-get install git linux-headers-generic build-essential dkms
git clone https://github.com/agtbaskara/rtl8192eu-linux-driver.git
cd rtl8192eu-linux-driver
sudo dkms add .
sudo dkms install rtl8192eu/1.0
cd /usr/src/rtl8192eu-1.0/
sudo make clean
sudo make
sudo make install
sudo modprobe -a 8192eu
And the reboot your PC, for my case it should be working.
EDIT 1 : USE THIS https://github.com/luckynzm/tlwn8200nddriver
My modified driver actually very buggy, and disconnected the wifi after several minutes
EDIT 2 : There is another problem for me, after about an hour the device kick to a "Power Save" state randomly, I have solve it by changing these line:
CONFIG_POWER_SAVING = y
to
CONFIG_POWER_SAVING = n
in the Makefiles before installing the driver
Baskara
  • 111
cd ~
git clone https://github.com/luckynzm/tlwn8200nddriver
sudo dkms add .
sudo make clean
sudo make
sudo make install
worked for me after disabling secure boot don't know how to properly sine the module if sum one can modify the solution to remove old rtl8192eu/1.0 installations and properly sine the module for secure boot these thread will b perfect i guess
removing old rtl8192eu/1.0 installations
sudo dkms status
will show the installed modules
sudo dkms remove -n rtl8192eu -v 1.0 --all
will remove old rtl8192eu/1.0 module from previous attempts
I solved it this way:
My Device: (KDE Neon 5.20) Linux version 5.4.0-58-generic (buildd@lcy01-amd64-004) (gcc version 9.3.0 (Ubuntu 9.3.0-17 ubuntu1~20.04)) #64-Ubuntu
Repo used: https://github.com/Mange/rtl8192eu-linux-driver. Code used from the section Section: Building and installing using DKMS.
$ sudo apt-get install git linux-headers-generic build-essential dkms;
$ git clone https://github.com/Mange/rtl8192eu-linux-driver;
$ cd rtl8192eu-linux-driver;
$ sudo dkms add .;
$ sudo dkms install rtl8192eu/1.0;
$ echo "blacklist rtl8xxxu" | sudo tee /etc/modprobe.d/rtl8xxxu.conf;
$ echo -e "8192eu\n\nloop" | sudo tee /etc/modules;
$ echo "options 8192eu rtw_power_mgnt=0 rtw_enusbss=0" | sudo tee /etc/modprobe.d/8192eu.conf;
$ sudo update-grub; sudo update-initramfs -u;
$ systemctl reboot -i;
I have wifi which is what I need
