I have found several people having similar issue, but not the solution
I am using Ubuntu 14.04 on Lenovo E450
I was able to connect on a wifi once, for a while, but after some time, whenever it tries to connect, message "Disconnected: you are now offline" appears. I am able to connect to some wifis (i can connect to a mobile hotspot i created) but for example not the wifi i have at home (which everyone is using and its working just fine)
I am kind of helpless as of what might be the problem, what should i try to solve this
ViRPo
  • 41
Run in terminal
sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi 11n_disable=1 power_save=0 swcrypto=1 bt_coex_active=0"
and reboot.
Pilot6
  • 92,041
Since Pilot6's answer didn't work gksudo gedit /etc/modprobe.d/iwlwifi.conf
Delete the line that was added options iwlwifi 11n_disable=1 power_save=0 swcrypto=1 bt_coex_active=0
And add options iwlwifi 11n_disable=8 Save, exit gedit, and reboot
I had an Intel card that wouldn't connect on a wireless network that was 11n only until I used this option to enable aggressive TX
Jeremy31
  • 13,293
