Updated my machine to 22.04 a few weeks ago. My WiFi is no longer working. Shows me no connections available, except a wired connection. I am pretty new to UBUNTU, so I am not sure what to run to diagnose. Help would be much appreciated!
DAS
First I would try doing the standard update procedure, sudo apt update followed by sudo apt upgrade.
If that doesn't work, this website I read says your problem could be with the kernel. Maybe trying to update the kernel via these commands:
sudo apt-get update and then sudo apt-get dist-upgrade
may help fix the problem.
Here is the website: https://www.technewstoday.com/ubuntu-wifi-not-working/
These tech newspapers seems like they are just fluff, but they have helped me fix problems before
Hope that helps.
Lirik
Useful command is
inxi -Fxmz
The output is the full information about your system. There is Network section where you can see what driver is used for wifi adapter.
Mahler
  • 739
