I'm "trying" kubuntu 22.04.1 from a dvd. That is I haven't actually installed it. It seems to be running OK but I can't connect to internet via wireless wifi. I'm lost on how to set up the connection. Documentation points me to things that don't seem to exist.
I suggested (in comment) I would write the 22.04.1 ISO to thumb-drive and "Try" Kubuntu from there if you can. Ubuntu no longer aims for optical media installations, and you can experience timeouts due to extra time caused by your use of DVD (or optical) media that can cause your system to experience errors you won't have post-install.
These issues are seen in logs, so you need to explore system logs at terminal to recognize/confirm this. You can re-try the boot & install & next time it may work (it works flawlessly about 33% of the time in my own [rather limited] QA) with it failing if timeout is reached before data is read. The GUI messages post-timeout are not helpful though & only make sense if the full system logs are read and you recognize the subsequent error was because of optical-read timeout.
The OP confirmed it was (as I read it) related to the optical installation media which is not intended for releases past Ubuntu 20.04 LTS. This answer just to close the question.
Hey, the thumb drive worked for what ever reason. Boot from that and a wifi icon shows up at the bottom right. Put in a password and all is right with the world. Thanks all.
- 33,561
