I installed Ubuntu server on a 2011 iMac and set up the WiFi when promoted. After setup I decided to add a GUI by running
sudo apt install ubuntu-desktop
when I rebooted I installed Firefox and Chrome and ran a google search and they both of them worked. In settings, it says
no wifi adapter found
but when I run lspci | grep -i network, it shows a detected WiFi controller.
Joemy
I suggest that you back up your current netplan file:
sudo mv /etc/netplan/00-installer-config-wifi.yaml  /etc/netplan/00-installer-config-wifi.bak
Write a new one:
sudo nano /etc/netplan/01-network-manager-all.yaml
Add the following:
# Let NetworkManager manage all devices on this system
network:
  version: 2
  renderer: NetworkManager
Netplan is very specific about spacing, indentation, etc., so proofread carefully twice.
Save (Ctrl+o followed by Enter) and exit (Ctrl+x).
Follow with:
sudo netplan generate
sudo netplan apply
sudo sudo service NetworkManager restart
Is there any improvement? It might take a reboot.
chili555
  • 61,330
When I implemented the solution offred by chili555 I got a bunch of messages like this:
Permissions for /etc/netplan/01-network-manager-all.yaml are too open. Netplan configuration should NOT be accessible by others.
Don't forget to change the permissions on the new file:
sudo chmod -c --reference=/etc/netplan/00-installer-config.yaml 00-installer-config-wifi.bak
