Yesterday i made a clean install of Ubuntu 17.10. In order to install aforementioned driver, i use the classic way:
sudo apt update
sudo apt install git
git clone https://github.com/jeremyb31/rtl8192eu-linux-driver
cd rtl8192eu-linux-driver
make
sudo make install
sudo modprobe 8192eu
But when 'make' command is executed. i get a bunch of warnings:
~/rtl8192eu-linux-driver$ make
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.13.0-32-generic/build M=/home/enippeas/rtl8192eu-linux-driver  modules
make[1]: Entering directory '/usr/src/linux-headers-4.13.0-32-generic'
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_cmd.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_security.o
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c: In function ‘aes_cipher’:
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c:1598:5: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation]
     for (j = 0; j < 8; j++)
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c:1601:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’
  payload_index = hdrlen + 8;
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c: In function ‘aes_decipher’:
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c:1984:5: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation]
/home/enippeas/rtl8192eu-linux-driver/core/rtw_security.c:1987:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_debug.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_io.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_ioctl_query.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_ioctl_set.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_ieee80211.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme.o
  CC [M]  /home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.o
/home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.c: In function ‘rtw_delba_check’:
/home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.c:12427:7: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]
       else
/home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.c:12429:8: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
        psta->recvreorder_ctrl[i].enable = _FALSE;
/home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.c:12430:7: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
       if (ret != _FAIL)
/home/enippeas/rtl8192eu-linux-driver/core/rtw_mlme_ext.c:12432:8: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
        rtw_reset_continual_no_rx_packet(psta, i);
 ...... and so on
Note that the 'classic way' worked flawlessly for Ubuntu 16.04 and 17.04. I'm struggling a whole day to make it work with no success. I would appreciate any help
Your wifi device is supported in kernel 4.13 with module rtl8xxxu and you might benefit by blacklisting the module you built as it did load
echo "blacklist 8192eu" | sudo tee -a /etc/modprobe.d/blacklist.conf
You wifi router is using TKIP encryption and that can cause issues in Ubuntu, it would be preferred to use WPA2 only for encryption
Jeremy31
  • 13,293
