Upon installation of Ubuntu 18.04, I installed the WiFi drivers as per standard procedure from the "Software and Updates" interface and everything was working fine. All of a sudden, without any system update or anything of that sort I was unable to connect to the WiFi because of No WiFi adapter found (despite me having installed it already).
The WiFi is correctly switched on, everything seems to be in place: for instance
$ nmcli radio wifi
enabled
and
$ ifconfig
enp3s0f2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 30:65:ec:07:51:a7 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enx048705ea6058: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.224 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 2a02:8109:9200:23cc:306f:334c:5f32:6f5f prefixlen 64 scopeid 0x0<global>
inet6 2a02:8109:9200:23cc:c419:c684:822a:e929 prefixlen 64 scopeid 0x0<global>
inet6 fe80::83a1:2bfa:d8b2:7313 prefixlen 64 scopeid 0x20<link>
ether 04:87:05:ea:60:58 txqueuelen 1000 (Ethernet)
RX packets 4290 bytes 2741868 (2.7 MB)
TX packets 4149 bytes 564683 (564.6 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 873 bytes 70852 (70.8 KB)
TX packets 873 bytes 70852 (70.8 KB)
EDIT: Additional information resulting from wget -N -t 5 -T 10 https://github.com/UbuntuForums/wireless-info/raw/master/wireless-info && chmod +x wireless-info && ./wireless-info, as suggested in the comment below, can be found here
What can be the cause of the problem? How come, all of a sudden, the drivers seem not to be recognised anymore?
